מנסה להתחיל, מקבל הרבה מפרטים שנכשלים
סיכום מבוסס בינה מלאכותית
DrSayre is trying to set up Discourse locally but encountering issues with failing specs. They’re running Ruby 2.7.6 and Postgresql 14.5 with hstore installed. The failing specs include reports, omniauth, search, and image optimization tests.
blake suggests that using Postgresql 14 might be the issue, as they’re still using pg 13 for development. They also ask if DrSayre ran the necessary migration commands prior to running the specs, specifically RAILS_ENV=test bin/rails db:migrate followed by RAILS_ENV=test bin/rspec.
I am trying to get Discourse setup locally. However I am finding I get a lot of failing specs. Im on Ruby 2.7.6 and Postgresql 14.5 (with hstore installed). I feel like something is wrong, but not sure what…
Finished in 19 minutes 12 seconds (files took 9.7 seconds to load)
17704 examples, 34 failures, 7 pending
Failed examples:
rspec ./spec/models/report_spec.rb:1194 # Report consolidated_page_views with no data works
rspec ./spec/models/report_spec.rb:1212 # Report consolidated_page_views with data works
rspec './spec/models/report_spec.rb[1:10:2:1]' # Report http_total request reports with http_total returns a report with data
rspec './spec/models/report_spec.rb[1:10:1:1]' # Report http_total request reports with no http_total records returns an empty report
rspec './spec/models/report_spec.rb[1:17:2:1]' # Report page_view_logged_in request reports with page_view_logged_in returns a report with data
rspec './spec/models/report_spec.rb[1:17:1:1]' # Report page_view_logged_in request reports with no page_view_logged_in records returns an empty report
rspec './spec/models/report_spec.rb[1:18:1:1]' # Report page_view_anon request reports with no page_view_anon records returns an empty report
rspec './spec/models/report_spec.rb[1:18:2:1]' # Report page_view_anon request reports with page_view_anon returns a report with data
rspec './spec/models/report_spec.rb[1:16:2:1]' # Report page_view_crawler request reports with page_view_crawler returns a report with data
rspec './spec/models/report_spec.rb[1:16:1:1]' # Report page_view_crawler request reports with no page_view_crawler records returns an empty report
rspec './spec/models/report_spec.rb[1:11:1:1]' # Report http_2xx request reports with no http_2xx records returns an empty report
rspec './spec/models/report_spec.rb[1:11:2:1]' # Report http_2xx request reports with http_2xx returns a report with data
rspec ./spec/system/bookmarks_spec.rb:51 # Bookmarking posts and topics allows the topic to be bookmarked
rspec ./spec/system/bookmarks_spec.rb:9 # Bookmarking posts and topics allows logged in user to create bookmarks with and without reminders
rspec ./spec/system/bookmarks_spec.rb:36 # Bookmarking posts and topics does not create a bookmark if the modal is closed with the cancel button
rspec ./spec/requests/theme_javascripts_controller_spec.rb:129 # ThemeJavascriptsController#show_tests includes theme uploads URLs in the settings object
rspec ./spec/models/topic_spec.rb:661 # Topic.similar_to with a similar topic returns the similar topic even if raw is blank
rspec ./spec/models/topic_spec.rb:657 # Topic.similar_to with a similar topic returns the similar topic if the title is similar
rspec ./spec/models/topic_spec.rb:698 # Topic.similar_to with a similar topic with secure categories should return the cat since the user can see it
rspec ./spec/jobs/clean_up_crawler_stats_spec.rb:17 # Jobs::CleanUpCrawlerStats keeps only the top records from the previous day
rspec ./spec/lib/middleware/request_tracker_spec.rb:64 # Middleware::RequestTracker log_request can log requests correctly
rspec ./spec/lib/middleware/request_tracker_spec.rb:53 # Middleware::RequestTracker log_request can exclude/include based on custom header
rspec ./spec/lib/middleware/request_tracker_spec.rb:103 # Middleware::RequestTracker log_request can log Discourse user agent requests correctly
rspec ./spec/lib/middleware/request_tracker_spec.rb:166 # Middleware::RequestTracker log_request when ignoring anonymous page views ignores anonymous requests for private sites
rspec ./spec/lib/middleware/request_tracker_spec.rb:151 # Middleware::RequestTracker log_request when ignoring anonymous page views does not ignore anonymous requests for public sites
rspec ./spec/requests/omniauth_callbacks_controller_spec.rb:109 # Users::OmniauthCallbacksController Google Oauth2 request should handle common errors
rspec ./spec/requests/omniauth_callbacks_controller_spec.rb:134 # Users::OmniauthCallbacksController Google Oauth2 request with CSRF protection enabled should be CSRF protected
rspec ./spec/lib/search_spec.rb:1665 # Search Advanced search can match exact phrases
rspec ./spec/lib/search_spec.rb:1853 # Search Advanced search supports category slug and tags
rspec ./spec/lib/search_spec.rb:1838 # Search Advanced search can search URLS correctly
rspec ./spec/lib/search_spec.rb:1675 # Search Advanced search can search numbers correctly, and match exact phrases
rspec ./spec/models/application_request_spec.rb:19 # ApplicationRequest can log app requests
rspec ./spec/models/optimized_image_spec.rb:179 # OptimizedImage.crop .downsize should downsize logo (requires ImageMagick 7)
rspec ./spec/models/web_crawler_request_spec.rb:13 # WebCrawlerRequest can log crawler requests
Ruby version looks good. I’m still on pg 13 for development, so using pg 14 could be an issue.
Did you run RAILS_ENV=test bin/rails db:migrate prior to running RAILS_ENV=test bin/rspec?
