Twitter images not appearing in onebox
I am having an issue with twitter images not appearing in onebox. This is not a general problem that I can replicate here as the same links posted to this instance display the images in the tweet. However, when I post the same link to my site, there are no images.
Any ideas what could be causing this? Other images load fine
Here is the same link:
Is this so difficult with this specific URL? Or on all Twitter URLs?
I believe the image loading requires the Twitter API, so you’ll need to fill in twitter consumer key and twitter consumer secret in your site settings. You can leave “enable twitter logins” disabled if you like.
strangely it is ALL attachments but it is only MOST avatars
I hadn’t realised this - thanks. I’ll check it out
