When the Discourse interface language is set to RTL Persian (Farsi), there is a UI issue with the time range dropdown in the leaderboard section.
In mobile view, after selecting a time range from the dropdown once, clicking the dropdown again does not open it normally. Instead:
- The page horizontally shifts to the left, revealing empty space on the right side.
- To restore the normal view, the user must manually scroll back to the right.
- Even after returning to the normal position, clicking the dropdown requires an extra tap before it opens again.
Additional details:
- This problem does not occur when the interface language is set to English — the dropdown works as expected.
- The issue is reproducible only on mobile devices (tested on Android in Chrome and Edge).
- Video attached demonstrating the issue.
Steps to reproduce:
- Set Discourse interface language to Persian(فارسی).
- Open the Leaderboard section in mobile view.
- Tap the time range dropdown and select an option.
- Tap the dropdown again.
- Observe the unexpected horizontal scroll shift and the need for extra tap.
Expected behavior:
The dropdown should open immediately without horizontal scroll shifts, identical to the English interface behavior.
