I am getting exactly the same error as this question i.e I can upload js files after allowing it in the settings but when I try to download it, the url in the browser changes to the js file url and " The change you wanted was rejected." is displayed.
Environment:-
Discourse docker running behind Nginx (nginx is using SSL)
Discourse container logs:-
Started GET "p5ePkm5OoKveknnMjyArlS4PPwS.js" for 192.168.32.1 at 2021-02-22 05:48:52 +0000
Processing by UploadsController#show_short as JS
Parameters: {"base62"=>"p5ePkm5OoKveknnMjyArlS4PPwS", "extension"=>"js"}
Sent file afcdf626f9db8d54a1fb5e8ebcab0ea214d9226a.js (2.2ms)
Security warning: an embedded <script> tag on another site requested protected JavaScript. If you know what you're doing, go ahead and disable forgery protection on this action to permit cross-origin JavaScript embedding.
Completed 422 Unprocessable Entity in 59ms (ActiveRecord: 0.0ms | Allocations: 17414)
ActionController::InvalidCrossOriginRequest (Security warning: an embedded <script> tag on another site requested protected JavaScript. If you know what you're doing, go ahead and disable forgery protection on this action to permit cross-origin JavaScript embedding.)
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.1/lib/action_controller/metal/request_forgery_protection.rb:266:in `verify_same_origin_request'
Nginx logs:-
10.164.0.103 - - [22/Feb/2021:05:51:11 +0000] "GET /uploads/short-url/p5ePkm5OoKveknnMjyArlS4PPwS.js HTTP/2.0" 422 781 "getting-started-with-sftp-module/292" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/88.0.4324.150 Safari/537.36"
Any help or pointers is appreciated!
Are you allowing *.js files to be attached to posts by users? Do you have legitimate need for javascript file attachments by your users? Just want to absolutely confirm before we proceed any further.
Hi All! I’m having the same issue. We’ve allowed .js extension to be uploaded, but no one can download it. Haven’t found yet any setting to fix this. Anyone can help?
Although, now we copy and paste the code in the text section of the post.
Use case: We have a .js file with a kickstarter code or a solution to a recurring problem and we want to share it as an attachment, so that users can download and start using it in their projects.
However, if we change the file extension from .js to .txt, it again shows “The change you wanted was rejected.” (This may be due to some storage optimization on the backend, that if the file has the same content as a previous file, then the new attachment points to the previously uploaded file)
So, I changed the (.txt) extention js file’s content a little bit and uploaded again, and I was able to download the file as attachment.
@codinghorror Is there a security risk in allowing to download .js files?
It works for uploads on S3 and it should work with local uploads as well, but there seems to be a new(ish) security measure from Rails:
ActionController::InvalidCrossOriginRequest (Security warning: an embedded tag on another site requested protected JavaScript. If you know what you’re doing, go ahead and disable forgery protection on this action to permit cross-origin JavaScript embedding.)
Started GET "/uploads/short-url/qDlrltMxEIJ2aYYdt8lZ200E3wA.js" for 94.31.111.247 at 2025-07-09 05:53:30 +0000
Parameters: {"base62"=>"qDlrltMxEIJ2aYYdt8lZ200E3wA", "extension"=>"js"}
Sent file /var/www/discourse/public/uploads/default/original/1X/baab1fc131be960b601467333f5a690b257daeb0.js (0.3ms)
Completed 422 Unprocessable Entity in 17ms (ActiveRecord: 0.0ms (0 queries, 0 cached) | GC: 0.0ms)
js files are in the list of allowed upload extensions:
