Unable to move posts between topics
Hi, I’m trying to move posts between threads and keep getting this error. This error is preventing any posts across the entire install from being moved. If anyone has any suggestions I’d be extremely careful. Thanks for reading!
PG::UniqueViolation (ERROR:  duplicate key value violates unique constraint "post_timings_unique"
DETAIL:  Key (topic_id, post_number, user_id)=(4175, 6, 1074) already exists.
lib/mini_sql_multisite_connection.rb:109:in `run'
app/models/post_mover.rb:507:in `move_post_timings'
app/models/post_mover.rb:138:in `handle_moved_references'
app/models/post_mover.rb:108:in `move_posts_to'
app/models/post_mover.rb:35:in `block in to_topic'
app/models/post_mover.rb:35:in `to_topic'
app/models/topic.rb:1308:in `move_posts'
app/controllers/topics_controller.rb:1415:in `move_posts_to_destination'
app/controllers/topics_controller.rb:917:in `move_posts'
app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
app/controllers/application_controller.rb:424:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:403:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/processing_request.rb:12:in `call'
lib/middleware/request_tracker.rb:360:in `call'
Backtrace
rack-mini-profiler (3.3.1) lib/patches/db/pg.rb:113:in `exec'
rack-mini-profiler (3.3.1) lib/patches/db/pg.rb:113:in `async_exec'
mini_sql (1.6.0) lib/mini_sql/postgres/connection.rb:217:in `run'
mini_sql (1.6.0) lib/mini_sql/active_record_postgres/connection.rb:38:in `block in run'
mini_sql (1.6.0) lib/mini_sql/active_record_postgres/connection.rb:34:in `block in with_lock'
activesupport (7.2.2) lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
mini_sql (1.6.0) lib/mini_sql/active_record_postgres/connection.rb:34:in `with_lock'
mini_sql (1.6.0) lib/mini_sql/active_record_postgres/connection.rb:38:in `run'
mini_sql (1.6.0) lib/mini_sql/postgres/connection.rb:196:in `exec'
activerecord (7.2.2) lib/active_record/connection_adapters/abstract/transaction.rb:616:in `block in within_new_transaction'
activerecord (7.2.2) lib/active_record/connection_adapters/abstract/transaction.rb:613:in `within_new_transaction'
activerecord (7.2.2) lib/active_record/connection_adapters/abstract/database_statements.rb:361:in `transaction'
activerecord (7.2.2) lib/active_record/transactions.rb:234:in `block in transaction'
activerecord (7.2.2) lib/active_record/connection_adapters/abstract/connection_pool.rb:421:in `with_connection'
activerecord (7.2.2) lib/active_record/connection_handling.rb:296:in `with_connection'
activerecord (7.2.2) lib/active_record/transactions.rb:233:in `transaction'
actionpack (7.2.2) lib/action_controller/metal/basic_implicit_render.rb:8:in `send_action'
actionpack (7.2.2) lib/abstract_controller/base.rb:226:in `process_action'
actionpack (7.2.2) lib/action_controller/metal/rendering.rb:193:in `process_action'
actionpack (7.2.2) lib/abstract_controller/callbacks.rb:261:in `block in process_action'
activesupport (7.2.2) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
i18n (1.14.6) lib/i18n.rb:353:in `with_locale'
activesupport (7.2.2) lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport (7.2.2) lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack (7.2.2) lib/abstract_controller/callbacks.rb:260:in `process_action'
actionpack (7.2.2) lib/action_controller/metal/rescue.rb:27:in `process_action'
actionpack (7.2.2) lib/action_controller/metal/instrumentation.rb:77:in `block in process_action'
activesupport (7.2.2) lib/active_support/notifications.rb:210:in `block in instrument'
activesupport (7.2.2) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (7.2.2) lib/active_support/notifications.rb:210:in `instrument'
actionpack (7.2.2) lib/action_controller/metal/instrumentation.rb:76:in `process_action'
actionpack (7.2.2) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.2.2) lib/active_record/railties/controller_runtime.rb:39:in `process_action'
actionpack (7.2.2) lib/abstract_controller/base.rb:163:in `process'
actionview (7.2.2) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack (7.2.2) lib/action_controller/metal.rb:252:in `dispatch'
actionpack (7.2.2) lib/action_controller/metal.rb:335:in `dispatch'
actionpack (7.2.2) lib/action_dispatch/routing/route_set.rb:67:in `dispatch'
actionpack (7.2.2) lib/action_dispatch/routing/route_set.rb:50:in `serve'
actionpack (7.2.2) lib/action_dispatch/journey/router.rb:53:in `block in serve'
actionpack (7.2.2) lib/action_dispatch/journey/router.rb:133:in `block in find_routes'
actionpack (7.2.2) lib/action_dispatch/journey/router.rb:126:in `each'
actionpack (7.2.2) lib/action_dispatch/journey/router.rb:126:in `find_routes'
actionpack (7.2.2) lib/action_dispatch/journey/router.rb:34:in `serve'
actionpack (7.2.2) lib/action_dispatch/routing/route_set.rb:896:in `call'
rack (2.2.10) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.10) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.10) lib/rack/head.rb:12:in `call'
actionpack (7.2.2) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.10) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.10) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.2.2) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.2.2) lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport (7.2.2) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (7.2.2) lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack (7.2.2) lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack (7.2.2) lib/action_dispatch/middleware/show_exceptions.rb:32:in `call'
logster (2.20.0) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.2.2) lib/rails/rack/logger.rb:41:in `call_app'
railties (7.2.2) lib/rails/rack/logger.rb:29:in `call'
actionpack (7.2.2) lib/action_dispatch/middleware/request_id.rb:33:in `call'
rack (2.2.10) lib/rack/method_override.rb:24:in `call'
actionpack (7.2.2) lib/action_dispatch/middleware/executor.rb:16:in `call'
rack (2.2.10) lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:334:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
actionpack (7.2.2) lib/action_dispatch/middleware/remote_ip.rb:96:in `call'
railties (7.2.2) lib/rails/engine.rb:535:in `call'
railties (7.2.2) lib/rails/railtie.rb:226:in `public_send'
railties (7.2.2) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.10) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.10) lib/rack/urlmap.rb:58:in `each'
rack (2.2.10) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
Env
HTTP HOSTS: forums.insertcredit.com
Hey great news, we have a fix that was just merged:
Not sure if you can upgrade your site right now, but this should allow you to get past that error.
Thank you!
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
