Unformatted Code Detector warning even when the post *does* use formatting blocks
Are you posting code?
Yes… I am… and yes, I’m using code blocks.
This warning should not show when the user is already using the blocks.
Here is more or less what my post was:
The change is:
  • adding back the snaffle cityscape turpentine template to dragonshadow & dragonshadowstaging
  • removing the ENV override for dragonshadow
    DISCOURSE_HEADER_ON_THE_HEADER: ''
    DISCOURSE_BUFFALO_BUFFALO_BUFFALO_BUFFALO_BUFFALO_: ''
  • refreshing the container configuration so it picks up the new ENV
  • ensuring it’s being used properly
    if you check redis keys for dragon- or snaffle- keys that confirms it’s being used
    [1] pry(main)> Discourse.redis.without_namespace.keys('*snaffle*')
    => ["snaffle:::tamarack_kitchissippi/bilbo",
     "snaffle:::tamarack_kitchissippi/gandalf",
     "snaffle:::tamarack_kitchissippi/frodo",
     "snaffle:::tamarack_kitchissippi/gimli",
     "snaffle:::tamarack_kitchissippi/sam",
     "snaffle:::tamarack_kitchissippi/pippin",
     "snaffle:::tamarack_kitchissippi/merry"]
Beware the ring.
