When using Unicode names in color palettes, an error occurs while loading the theme.
Color Name: Dark ©
/stylesheets/color_definitions_dark-©_1_fd40...058de7a.css
Returned: 404 Not found
Color Name: Dark ©
Did this problem just happen to me?
Maybe don’t use unicode characters in color palettes?
The reason I mentioned this was because the language of my forum is not English and I have to write the name of the color palette in another language. On a site with a language other than English, this problem occurs when a user tries to choose a different color palette from their profile settings.
Green - Зеленый - أخضر - 綠色 - Grün - سبز - 초록 - Grön
Dark - Тьма - داكن - 黑暗 - تاریک - 어두운 - Mörk
I think this is a recent regression due to automatic dark mode, @pmusaraj maybe scrub the text of the scss file name so we omit unicode which tends to be a problem across proxies.
This should be now fixed @nildarar via DEV: Strip unicode from color scheme stylesheet filenames (#10628) · discourse/discourse@d4a7058 · GitHub.
Thank you for your support, I will check this after the update
This topic was automatically closed after 3 days. New replies are no longer allowed.
