Unstiffening the tag system...?
The discussion is about potential changes to the tag system, focusing on flexibility. Renato_Mendes proposes an option to suggest certain groups of tags for users in specific categories, while still allowing the use of tags from other groups. Kartoon initially questions the need for this feature, suggesting that simply not blocking tags would achieve the same result. However, nathank supports the idea, explaining that it would provide a “softer” middle ground between forced and unrestricted tag usage, allowing for gentle encouragement rather than strict rules. Renato_Mendes agrees with nathank, hoping to clarify the concept for Kartoon.
Hey, guys! Hope you’re doing fine :slight_smile:
I’ve been thinking about the tag system and its stiffness (despite it being powerful).
Wouldn’t it be great if, instead of blocking the usage of certain tags in different categories, we had the option to suggest certain groups of tags for the user, but also allow them to use tags from other groups, just in case it makes sense?
This wouldn’t end the admin’s ability to actually block the usage of some tags in some categories, just a nice new possibility for forums that don’t have that great rigidity between smaller (tags) and larger themes (categories).
Thanks!
Isn’t this just the default tag system? Just don’t block any tags then no one needs to be “suggested” anything they can use whatever they want. It sounds like you’re trying to work backwards from not allowing>allowing, but the default action is already allowing nothing else is required?
I feel like I must not be understanding what function you’re actually suggesting though
I find that my users would benefit from suggested tags.
For example, I want to encourage (not force) them to use one tag from a group, and allow them to use tags from other groups (or ungrouped) with only a little friction.
At present, it is a bit of an all or nothing thing. I’d like a ‘softer’ middle ground, which is what I believe @Renato_Mendes is outlining.
You perfectly understood what I meant, Nathan! Does it make more sense to you now, @Kartoon?
