アップデートにエラーが発生しました
I, [2023-01-14T15:20:10.327274 #1] INFO -- :
I, [2023-01-14T15:20:10.327716 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-01-14T15:20:10.330613 #1] INFO -- :
I, [2023-01-14T15:20:10.337332 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2023-01-14T15:20:10.342856 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2023-01-14T15:20:10.348165 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2023-01-14T15:20:10.353384 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2023-01-14T15:20:10.353832 #1] INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2023-01-14T15:20:11.440692 #1] INFO -- :
I, [2023-01-14T15:20:11.440855 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2023-01-14T15:20:11.444036 #1] INFO -- :
I, [2023-01-14T15:20:11.444406 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-01-14T15:20:11.464894 #1] INFO -- :
I, [2023-01-14T15:20:11.465432 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-01-14T15:20:11.469254 #1] INFO -- :
I, [2023-01-14T15:20:11.469717 #1] INFO -- : > /root/upgrade_postgres
I, [2023-01-14T15:20:11.477575 #1] INFO -- :
I, [2023-01-14T15:20:11.478021 #1] INFO -- : > rm /root/upgrade_postgres
I, [2023-01-14T15:20:11.481636 #1] INFO -- :
I, [2023-01-14T15:20:11.484481 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-14T15:20:11.485291 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-14T15:20:11.488676 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-14T15:20:11.490278 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-14T15:20:11.491438 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-14T15:20:11.495023 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-14T15:20:11.497010 #1] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2023-01-14T15:20:11.502200 #1] INFO -- :
I, [2023-01-14T15:20:11.502943 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-14T15:20:11.503524 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-14T15:20:11.504876 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-14T15:20:11.505632 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/13/main/pg_hba.conf
I, [2023-01-14T15:20:11.506029 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-01-14T15:20:11.506514 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-01-14T15:20:11.506835 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2023-01-14T15:20:11.509874 #1] INFO -- : > sleep 5
2023-01-14 15:20:11.573 UTC [42] LOG: starting PostgreSQL 13.9 (Debian 13.9-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2023-01-14 15:20:11.575 UTC [42] LOG: listening on IPv4 address "0.0.0.0", port 5432
2023-01-14 15:20:11.576 UTC [42] LOG: listening on IPv6 address "::", port 5432
2023-01-14 15:20:11.578 UTC [42] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-01-14 15:20:11.585 UTC [45] LOG: database system was shut down at 2023-01-14 15:19:50 UTC
2023-01-14 15:20:11.597 UTC [42] LOG: database system is ready to accept connections
I, [2023-01-14T15:20:16.513351 #1] INFO -- :
I, [2023-01-14T15:20:16.513604 #1] INFO -- : > su postgres -c 'createdb discourse' || true
2023-01-14 15:20:16.571 UTC [55] postgres@postgres ERROR: database "discourse" already exists
2023-01-14 15:20:16.571 UTC [55] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
I, [2023-01-14T15:20:16.574150 #1] INFO -- :
I, [2023-01-14T15:20:16.574590 #1] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2023-01-14 15:20:16.629 UTC [59] postgres@discourse ERROR: role "discourse" already exists
2023-01-14 15:20:16.629 UTC [59] postgres@discourse STATEMENT: create user discourse;
I, [2023-01-14T15:20:16.631900 #1] INFO -- :
I, [2023-01-14T15:20:16.632313 #1] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2023-01-14T15:20:16.685250 #1] INFO -- : GRANT
I, [2023-01-14T15:20:16.685757 #1] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2023-01-14T15:20:16.738067 #1] INFO -- : ALTER SCHEMA
I, [2023-01-14T15:20:16.738570 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE: extension "hstore" already exists, skipping
I, [2023-01-14T15:20:16.795136 #1] INFO -- : CREATE EXTENSION
I, [2023-01-14T15:20:16.795668 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE: extension "pg_trgm" already exists, skipping
I, [2023-01-14T15:20:16.851832 #1] INFO -- : CREATE EXTENSION
I, [2023-01-14T15:20:16.852398 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2023-01-14T15:20:16.904659 #1] INFO -- : CREATE EXTENSION
I, [2023-01-14T15:20:16.905150 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2023-01-14T15:20:16.956892 #1] INFO -- : CREATE EXTENSION
I, [2023-01-14T15:20:16.957456 #1] INFO -- : > sudo -u postgres psql discourse
I, [2023-01-14T15:20:16.960638 #1] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2023-01-14T15:20:17.031056 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2023-01-14T15:20:17.034441 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2023-01-14T15:20:17.034712 #1] INFO -- : > echo postgres installed!
I, [2023-01-14T15:20:17.037047 #1] INFO -- : postgres installed!
I, [2023-01-14T15:20:17.042393 #1] INFO -- : File > /etc/service/redis/run chmod: +x chown:
I, [2023-01-14T15:20:17.047424 #1] INFO -- : File > /etc/service/redis/log/run chmod: +x chown:
I, [2023-01-14T15:20:17.052510 #1] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2023-01-14T15:20:17.053373 #1] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2023-01-14T15:20:17.054121 #1] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2023-01-14T15:20:17.055081 #1] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2023-01-14T15:20:17.058234 #1] INFO -- :
I, [2023-01-14T15:20:17.058837 #1] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2023-01-14T15:20:17.059492 #1] INFO -- : Replacing (?-mix:^bind .*$) with in /etc/redis/redis.conf
I, [2023-01-14T15:20:17.060470 #1] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2023-01-14T15:20:17.061549 #1] INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2023-01-14T15:20:17.062449 #1] INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2023-01-14T15:20:17.063413 #1] INFO -- : > echo redis installed
I, [2023-01-14T15:20:17.066313 #1] INFO -- : redis installed
I, [2023-01-14T15:20:17.066678 #1] INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2023-01-14T15:20:17.071544 #1] INFO -- : logfile ""
I, [2023-01-14T15:20:17.071867 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-01-14T15:20:17.073813 #1] INFO -- : > sleep 10
103:C 14 Jan 2023 15:20:17.082 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
103:C 14 Jan 2023 15:20:17.082 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=103, just started
103:C 14 Jan 2023 15:20:17.082 # Configuration loaded
103:M 14 Jan 2023 15:20:17.083 * monotonic clock: POSIX clock_gettime
103:M 14 Jan 2023 15:20:17.083 * Running mode=standalone, port=6379.
103:M 14 Jan 2023 15:20:17.083 # Server initialized
103:M 14 Jan 2023 15:20:17.084 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
103:M 14 Jan 2023 15:20:17.084 * Loading RDB produced by version 7.0.7
103:M 14 Jan 2023 15:20:17.084 * RDB age 2518 seconds
103:M 14 Jan 2023 15:20:17.084 * RDB memory usage when created 18.99 Mb
103:M 14 Jan 2023 15:20:17.144 * Done loading RDB, keys loaded: 4565, keys expired: 62.
103:M 14 Jan 2023 15:20:17.145 * DB loaded from disk: 0.060 seconds
103:M 14 Jan 2023 15:20:17.145 * Ready to accept connections
I, [2023-01-14T15:20:27.076638 #1] INFO -- :
I, [2023-01-14T15:20:27.077285 #1] INFO -- : > thpoff echo "thpoff is installed!"
I, [2023-01-14T15:20:27.083514 #1] INFO -- : thpoff is installed!
I, [2023-01-14T15:20:27.083985 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2023-01-14T15:20:27.173960 #1] INFO -- :
I, [2023-01-14T15:20:27.174760 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2023-01-14T15:20:27.255056 #1] INFO -- :
I, [2023-01-14T15:20:27.255629 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2023-01-14T15:20:27.337678 #1] INFO -- :
I, [2023-01-14T15:20:27.338146 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2023-01-14T15:20:27.341776 #1] INFO -- :
I, [2023-01-14T15:20:27.345358 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2023-01-14T15:20:27.350966 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2023-01-14T15:20:27.356572 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2023-01-14T15:20:27.362001 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2023-01-14T15:20:27.367247 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2023-01-14T15:20:27.373348 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2023-01-14T15:20:27.373683 #1] INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2023-01-14T15:20:27.374254 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-01-14T15:20:27.376856 #1] INFO -- : > cd /var/www/discourse && git reset --hard
131:C 14 Jan 2023 15:20:27.384 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
131:C 14 Jan 2023 15:20:27.384 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=131, just started
131:C 14 Jan 2023 15:20:27.384 # Configuration loaded
131:M 14 Jan 2023 15:20:27.385 * monotonic clock: POSIX clock_gettime
131:M 14 Jan 2023 15:20:27.385 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
131:M 14 Jan 2023 15:20:27.385 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (32637/32637), done.
I, [2023-01-14T15:20:30.195658 #1] INFO -- : HEAD is now at e775ed1c DEV: Properly include spec examples (#19532)
I, [2023-01-14T15:20:30.195797 #1] INFO -- : > cd /var/www/discourse && git clean -f
I, [2023-01-14T15:20:30.333643 #1] INFO -- :
I, [2023-01-14T15:20:30.334184 #1] INFO -- : > cd /var/www/discourse && git remote set-branches --add origin main
I, [2023-01-14T15:20:30.339433 #1] INFO -- :
I, [2023-01-14T15:20:30.339648 #1] INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2023-01-14T15:20:30.344719 #1] INFO -- :
I, [2023-01-14T15:20:30.345119 #1] INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
From https://github.com/discourse/discourse
* branch tests-passed -> FETCH_HEAD
* [new branch] tests-passed -> origin/tests-passed
I, [2023-01-14T15:20:33.500237 #1] INFO -- :
I, [2023-01-14T15:20:33.500424 #1] INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2023-01-14T15:20:34.338013 #1] INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2023-01-14T15:20:34.338160 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2023-01-14T15:20:34.343182 #1] INFO -- :
I, [2023-01-14T15:20:34.343477 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2023-01-14T15:20:34.347396 #1] INFO -- :
I, [2023-01-14T15:20:34.347503 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2023-01-14T15:20:34.351342 #1] INFO -- :
I, [2023-01-14T15:20:34.351730 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2023-01-14T15:20:34.355202 #1] INFO -- :
I, [2023-01-14T15:20:34.355301 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2023-01-14T15:20:34.358930 #1] INFO -- :
I, [2023-01-14T15:20:34.359319 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2023-01-14T15:20:34.362679 #1] INFO -- :
I, [2023-01-14T15:20:34.362778 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2023-01-14T15:20:34.367598 #1] INFO -- :
I, [2023-01-14T15:20:34.367713 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2023-01-14T15:20:34.372403 #1] INFO -- :
I, [2023-01-14T15:20:34.372784 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2023-01-14T15:20:34.377508 #1] INFO -- :
I, [2023-01-14T15:20:34.377830 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2023-01-14T15:20:34.382445 #1] INFO -- :
I, [2023-01-14T15:20:34.382540 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2023-01-14T15:20:34.387500 #1] INFO -- :
I, [2023-01-14T15:20:34.387730 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2023-01-14T15:20:34.392281 #1] INFO -- :
I, [2023-01-14T15:20:34.392564 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2023-01-14T15:20:34.505504 #1] INFO -- :
I, [2023-01-14T15:20:34.505907 #1] INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2023-01-14T15:20:34.511590 #1] INFO -- :
I, [2023-01-14T15:20:34.512078 #1] INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2023-01-14T15:20:34.513271 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2023-01-14T15:20:35.262697 #1] INFO -- :
I, [2023-01-14T15:20:35.262867 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-translator.git
Cloning into 'discourse-translator'...
I, [2023-01-14T15:20:35.700782 #1] INFO -- :
I, [2023-01-14T15:20:35.700943 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-adplugin.git
Cloning into 'discourse-adplugin'...
I, [2023-01-14T15:20:36.059316 #1] INFO -- :
I, [2023-01-14T15:20:36.059489 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-cakeday.git
Cloning into 'discourse-cakeday'...
I, [2023-01-14T15:20:36.406019 #1] INFO -- :
I, [2023-01-14T15:20:36.406147 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-patreon.git
Cloning into 'discourse-patreon'...
I, [2023-01-14T15:20:36.982984 #1] INFO -- :
I, [2023-01-14T15:20:36.983157 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
Cloning into 'discourse-solved'...
I, [2023-01-14T15:20:37.321593 #1] INFO -- :
I, [2023-01-14T15:20:37.322087 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-follow.git
Cloning into 'discourse-follow'...
I, [2023-01-14T15:20:37.642974 #1] INFO -- :
I, [2023-01-14T15:20:37.643458 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-assign.git
Cloning into 'discourse-assign'...
I, [2023-01-14T15:20:38.085929 #1] INFO -- :
I, [2023-01-14T15:20:38.086461 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-canned-replies.git
Cloning into 'discourse-canned-replies'...
I, [2023-01-14T15:20:38.443553 #1] INFO -- :
I, [2023-01-14T15:20:38.443760 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-checklist.git
Cloning into 'discourse-checklist'...
I, [2023-01-14T15:20:38.769904 #1] INFO -- :
I, [2023-01-14T15:20:38.770018 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-user-notes.git
Cloning into 'discourse-user-notes'...
I, [2023-01-14T15:20:39.092350 #1] INFO -- :
I, [2023-01-14T15:20:39.092555 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-calendar.git
Cloning into 'discourse-calendar'...
I, [2023-01-14T15:20:39.625377 #1] INFO -- :
I, [2023-01-14T15:20:39.625542 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-gamification.git
Cloning into 'discourse-gamification'...
I, [2023-01-14T15:20:39.961425 #1] INFO -- :
I, [2023-01-14T15:20:39.961591 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-saved-searches.git
Cloning into 'discourse-saved-searches'...
I, [2023-01-14T15:20:40.379340 #1] INFO -- :
I, [2023-01-14T15:20:40.379503 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-yearly-review.git
Cloning into 'discourse-yearly-review'...
I, [2023-01-14T15:20:40.675729 #1] INFO -- :
I, [2023-01-14T15:20:40.675914 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-bcc.git
Cloning into 'discourse-bcc'...
I, [2023-01-14T15:20:40.986527 #1] INFO -- :
I, [2023-01-14T15:20:40.986709 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/worldismine/PM-Scanner.git
Cloning into 'PM-Scanner'...
I, [2023-01-14T15:20:41.275315 #1] INFO -- :
I, [2023-01-14T15:20:41.275465 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-whos-online.git
Cloning into 'discourse-whos-online'...
I, [2023-01-14T15:20:41.557417 #1] INFO -- :
I, [2023-01-14T15:20:41.557921 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-reactions.git
Cloning into 'discourse-reactions'...
I, [2023-01-14T15:20:41.943399 #1] INFO -- :
I, [2023-01-14T15:20:41.943581 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-fingerprint.git
Cloning into 'discourse-fingerprint'...
I, [2023-01-14T15:20:42.238602 #1] INFO -- :
I, [2023-01-14T15:20:42.238793 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-perspective-api.git
Cloning into 'discourse-perspective-api'...
I, [2023-01-14T15:20:42.539596 #1] INFO -- :
I, [2023-01-14T15:20:42.539751 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-data-explorer.git
Cloning into 'discourse-data-explorer'...
I, [2023-01-14T15:20:42.932603 #1] INFO -- :
I, [2023-01-14T15:20:42.932773 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-spoiler-alert.git
Cloning into 'discourse-spoiler-alert'...
I, [2023-01-14T15:20:43.239008 #1] INFO -- :
I, [2023-01-14T15:20:43.239675 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2023-01-14T15:20:43.244629 #1] INFO -- :
I, [2023-01-14T15:20:43.245055 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2023-01-14T15:20:43.248052 #1] INFO -- :
I, [2023-01-14T15:20:43.248481 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2023-01-14T15:20:43.251598 #1] INFO -- :
I, [2023-01-14T15:20:43.251976 #1] INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2023-01-14T15:20:43.252512 #1] INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2023-01-14T15:20:43.252965 #1] INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2023-01-14T15:20:43.253455 #1] INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2023-01-14T15:20:43.253905 #1] INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2023-01-14T15:20:43.254271 #1] INFO -- : > echo "done configuring web"
I, [2023-01-14T15:20:43.257069 #1] INFO -- : done configuring web
I, [2023-01-14T15:20:43.257491 #1] INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2023-01-14T15:20:43.794680 #1] INFO -- : Successfully installed bundler-2.4.1
1 gem installed
I, [2023-01-14T15:20:43.795215 #1] INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2023-01-14T15:20:47.388059 #1] INFO -- :
I, [2023-01-14T15:20:47.388692 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --production --frozen-lockfile && yarn cache clean'
warning " > @mixer/parallel-prettier@2.0.3" has unmet peer dependency "prettier@^2.0.0".
warning "eslint-config-discourse > eslint-plugin-lodash@7.1.0" has unmet peer dependency "lodash@>=4".
I, [2023-01-14T15:21:42.078520 #1] INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
$ yarn --cwd app/assets/javascripts/discourse $(node -e 'if(JSON.parse(process.env.npm_config_argv).original.includes(`--frozen-lockfile`)){console.log(`--frozen-lockfile`)}')
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
[4/4] Building fresh packages...
Done in 31.32s.
Done in 49.69s.
yarn cache v1.22.19
success Cleared cache.
Done in 4.61s.
I, [2023-01-14T15:21:42.079283 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
Bundler::PathError: The path `/var/www/discourse/vendor/bundle/ruby/3.1.0/bundler/gems/sprockets-f4d3dae71ef2` does not exist.
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source/path.rb:209:in `load_spec_files'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source/git.rb:205:in `load_spec_files'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source/path.rb:107:in `local_specs'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source/git.rb:172:in `specs'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/lazy_specification.rb:86:in `materialize_for_installation'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:195:in `map!'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:195:in `specs_for_dependency'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:33:in `block in for'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:22:in `loop'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:22:in `for'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:79:in `materialize'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/definition.rb:198:in `missing_specs'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/definition.rb:202:in `missing_specs?'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/installer.rb:253:in `resolve_if_needed'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/installer.rb:82:in `block in run'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/process_lock.rb:12:in `block in lock'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/process_lock.rb:9:in `open'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/process_lock.rb:9:in `lock'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/installer.rb:71:in `run'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/installer.rb:23:in `install'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli/install.rb:62:in `run'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli.rb:260:in `block in install'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/settings.rb:131:in `temporary'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli.rb:259:in `install'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli.rb:34:in `dispatch'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli.rb:28:in `start'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/exe/bundle:45:in `block in <top (required)>'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/exe/bundle:33:in `<top (required)>'
I, [2023-01-14T15:22:25.177096 #1] INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.4.1
Frozen, using resolution from the lockfile
The definition is missing dependencies, failed to resolve & materialize locally (https://github.com/rails/sprockets (at 3.x@f4d3dae) is not yet checked out. Run `bundle install` first.)
Frozen, using resolロックファイルからの解決
HTTP GET https://index.rubygems.org/versions
HTTP 206 Partial Content https://index.rubygems.org/versions
https://rubygems.org/ から gem メタデータを取得中
gems を検索中 ["actionmailer", "actionpack", "actionview", "actionview_precompiler", "active_model_serializers", "activejob", "activemodel", "activerecord", "activesupport", "addressable", "annotate", "ast", "aws-eventstream", "aws-partitions", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "aws-sigv4", "better_errors", "binding_of_caller", "bootsnap", "builder", "bullet", "byebug", "capybara", "cbor", "certified", "cgi", "chunky_png", "coderay", "colored2", "concurrent-ruby", "connection_pool", "cose", "cppjieba_rb", "crack", "crass", "css_parser", "debug_inspector", "diff-lcs", "diffy", "digest", "discourse-fonts", "discourse-seed-fu", "discourse_dev_assets", "docile", "ecma-re-validator", "email_reply_trimmer", "erubi", "excon", "execjs", "exifr", "fabrication", "faker", "fakeweb", "faraday", "faraday-net_http", "faraday-retry", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "globalid", "guess_html_encoding", "hana", "hashdiff", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "i18n", "image_optim", "image_size", "in_threads", "jmespath", "json", "json-schema", "json_schemer", "jwt", "kgio", "libv8-node", "listen", "literate_randomizer", "lograge", "logstash-event", "logstash-logger", "logster", "loofah", "lru_redux", "lz4-ruby", "matrix", "maxminddb", "memory_profiler", "message_bus", "method_source", "mini_mime", "mini_portile2", "mini_racer", "mini_scheduler", "mini_sql", "mini_suffix", "minitest", "mocha", "msgpack", "multi_json", "multi_xml", "mustache", "net-http", "net-imap", "net-pop", "net-protocol", "net-smtp", "nio4r", "nokogiri", "oauth", "oauth-tty", "oauth2", "oj", "omniauth", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-oauth2", "omniauth-twitter", "openssl", "openssl-signature_algorithm", "optimist", "parallel", "parallel_tests", "parser", "pg", "prettier_print", "progress", "pry", "pry-byebug", "pry-rails", "public_suffix", "puma", "r2", "racc", "rack", "rack-mini-profiler", "rack-protection", "rack-test", "rails-dom-testing", "rails-html-sanitizer", "rails_failover", "rails_multisite", "railties", "rainbow", "raindrops", "rake", "rb-fsevent", "rb-inotify", "rbtrace", "rchardet", "redis", "redis-namespace", "regexp_parser", "request_store", "rexml", "rinku", "rotp", "rqrcode", "rqrcode_core", "rspec", "rspec-core", "rspec-expectations", "rspec-html-matchers", "rspec-mocks", "rspec-rails", "rspec-support", "rss", "rswag-specs", "rubocop", "rubocop-ast", "rubocop-discourse", "rubocop-rspec", "ruby-prof", "ruby-progressbar", "ruby-readability", "ruby2_keywords", "rubyzip", "sanitize", "sassc", "sassc-rails", "selenium-webdriver", "shoulda-matchers", "sidekiq", "simplecov", "simplecov-html", "simplecov_json_formatter", "snaky_hash", "sprockets-rails", "sshkey", "stackprof", "syntax_tree", "syntax_tree-disable_ternary", "test-prof", "thor", "tilt", "timeout", "tzinfo", "uglifier", "unf", "unf_ext", "unicode-display_width", "unicorn", "uniform_notifier", "uri", "uri_template", "version_gem", "web-push", "webdrivers", "webmock", "webrick", "websocket", "xorcist", "xpath", "yaml-lint", "zeitwerk"]
HTTP GET https://index.rubygems.org/info/aws-partitions
HTTP GET https://index.rubygems.org/info/bullet
HTTP 206 Partial Content https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/bullet
HTTP GET https://index.rubygems.org/info/cgi
HTTP GET https://index.rubygems.org/info/css_parser
HTTP 200 OK https://index.rubygems.org/info/cgi
HTTP 206 Partial Content https://index.rubygems.org/info/css_parser
HTTP GET https://index.rubygems.org/info/erubi
HTTP GET https://index.rubygems.org/info/excon
HTTP 206 Partial Content https://index.rubygems.org/info/excon
HTTP 206 Partial Content https://index.rubygems.org/info/erubi
HTTP GET https://index.rubygems.org/info/faker
HTTP 206 Partial Content https://index.rubygems.org/info/faker
HTTP GET https://index.rubygems.org/info/highline
HTTP 206 Partial Content https://index.rubygems.org/info/highline
HTTP GET https://index.rubygems.org/info/jwt
HTTP GET https://index.rubygems.org/info/libv8-node
HTTP 206 Partial Content https://index.rubygems.org/info/jwt
HTTP 206 Partial Content https://index.rubygems.org/info/libv8-node
HTTP GET https://index.rubygems.org/info/listen
HTTP 206 Partial Content https://index.rubygems.org/info/listen
HTTP GET https://index.rubygems.org/info/message_bus
HTTP GET https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/message_bus
HTTP 206 Partial Content https://index.rubygems.org/info/mini_portile2
HTTP GET https://index.rubygems.org/info/minitest
HTTP 206 Partial Content https://index.rubygems.org/info/minitest
HTTP GET https://index.rubygems.org/info/net-imap
HTTP GET https://index.rubygems.org/info/nokogiri
HTTP 206 Partial Content https://index.rubygems.org/info/net-imap
HTTP 206 Partial Content https://index.rubygems.org/info/nokogiri
HTTP GET https://index.rubygems.org/info/openssl
HTTP 206 Partial Content https://index.rubygems.org/info/openssl
HTTP GET https://index.rubygems.org/info/parser
HTTP 206 Partial Content https://index.rubygems.org/info/parser
HTTP GET https://index.rubygems.org/info/prettier_print
HTTP 200 OK https://index.rubygems.org/info/prettier_print
HTTP GET https://index.rubygems.org/info/pry
HTTP 206 Partial Content https://index.rubygems.org/info/pry
HTTP GET https://index.rubygems.org/info/puma
HTTP 206 Partial Content https://index.rubygems.org/info/puma
HTTP GET https://index.rubygems.org/info/racc
HTTP GET https://index.rubygems.org/info/rack
HTTP 206 Partial Content https://index.rubygems.org/info/racc
HTTP 206 Partial Content https://index.rubygems.org/info/rack
HTTP GET https://index.rubygems.org/info/redis-namespace
HTTP 206 Partial Content https://index.rubygems.org/info/redis-namespace
HTTP GET https://index.rubygems.org/info/rspec-expectations
HTTP GET https://index.rubygems.org/info/rspec-mocks
HTTP 206 Partial Content https://index.rubygems.org/info/rspec-expectations
HTTP 206 Partial Content https://index.rubygems.org/info/rspec-mocks
HTTP GET https://index.rubygems.org/info/rubocop
HTTP GET https://index.rubygems.org/info/rubocop-ast
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop-ast
HTTP GET https://index.rubygems.org/info/rubocop-discourse
HTTP GET https://index.rubygems.org/info/rubocop-rspec
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop-rspec
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop-discourse
HTTP GET https://index.rubygems.org/info/ruby-prof
HTTP 206 Partial Content https://index.rubygems.org/info/ruby-prof
HTTP GET https://index.rubygems.org/info/sidekiq
HTTP GET https://index.rubygems.org/info/simplecov
HTTP 206 Partial Content https://index.rubygems.org/info/sidekiq
HTTP 206 Partial Content https://index.rubygems.org/info/simplecov
HTTP GET https://index.rubygems.org/info/syntax_tree-disable_ternary
HTTP 200 OK https://index.rubygems.org/info/syntax_tree-disable_ternary
HTTP GET https://index.rubygems.org/info/unicode-display_width
HTTP GET https://index.rubygems.org/info/web-push
HTTP 206 Partial Content https://index.rubygems.org/info/unicode-display_width
HTTP 200 OK https://index.rubygems.org/info/web-push
gems を検索中 ["mail", "text-format", "erubis", "rails-deprecated_sanitizer", "rack-mount", "rack-cache", "sprockets", "journey", "jsonapi", "case_transform", "jsonapi-renderer", "activemodel-globalid", "bcrypt-ruby", "arel", "activerecord-deprecated_finders", "memcache-client", "thread_safe", "jamespath", "http-2", "aws-crt", "rouge", "snappy", "columnize", "debugger-linecache", "slop", "rb-readline", "culerity", "database_cleaner", "mime-types", "celerity", "functional-ruby", "ref", "safe_yaml", "rdoc", "rcov", "multipart-post", "faraday-excon", "faraday-net_http_persistent", "faraday-em_http", "faraday-em_synchrony", "faraday-httpclient", "faraday-patron", "faraday-rack", "faraday-multipart", "rake-compiler", "pastel", "tty-pager", "tty-screen", "tty-tree", "rb-appscript", "xattr", "ffi-xattr", "json_pure", "rdf", "termios", "stud", "rb-fchange", "rb-kqueue", "celluloid", "celluloid-io", "ruby_dep", "ruby_parser", "eventmachine", "thin", "libv8", "net-ftp", "metaclass", "io-wait", "strscan", "date", "ruby-hmac", "faraday-middleware", "httpauth", "rash_alt", "hoe", "weakling", "mini_portile", "pkg-config", "bigdecimal", "oa-core", "oa-oauth", "oa-openid", "oa-basic", "oa-enterprise", "oa-more", "ipaddr", "sexp_processor", "pry-doc", "win32console", "yard", "spoon", "escape_utils", "rails", "rack-ssl", "trollop", "redis-client", "base32", "webrat", "rspec-collection_matchers", "term-ansicolor", "backports", "powerpack", "astrolabe", "tins", "jaro_winkler", "psych", "hpricot", "nokogumbo", "bundler", "sass", "childprocess", "libwebsocket", "bourne", "compass", "sprockets-sass", "sinatra", "slim", "lockfile", "therubyracer", "archive-zip", "zip", "net_http_ssl_fix"]
HTTP GET https://index.rubygems.org/info/mail
HTTP 206 Partial Content https://index.rubygems.org/info/mail
HTTP GET https://index.rubygems.org/info/pry-doc
HTTP 206 Partial Content https://index.rubygems.org/info/pry-doc
HTTP GET https://index.rubygems.org/info/redis-client
HTTP 206 Partial Content https://index.rubygems.org/info/redis-client
HTTP GET https://index.rubygems.org/info/bundler
HTTP 206 Partial Content https://index.rubygems.org/info/bundler
gems を検索中 ["text-hyphen", "abstract", "multimap", "hike", "treetop", "tlsmail", "jsonapi-parser", "bcrypt", "ZenTest", "RubyInline", "atomic", "snappy-jars", "ruby_core_source", "debugger-ruby_core_source", "cucumber", "database_cleaner-active_record", "mime-types-data", "net-http-persistent", "httpclient", "patron", "equatable", "tty-color", "tty-which", "verse", "strings", "spruz", "link_header", "hamster", "win32-api", "metriks", "timers", "facter", "celluloid-essentials", "celluloid-extras", "celluloid-fsm", "celluloid-pool", "celluloid-supervision", "dotenv", "nenv", "rspec-logsplit", "ParseTree", "daemons", "time", "rubyforge", "gemcutter", "rack-openid", "ruby-openid-apps-discovery", "restclient", "rest-client", "net-ldap", "rubyntlm", "pyu-ruby-sasl", "uuid", "XMLCanonicalizer", "activeresource", "actionwebservice", "actioncable", "activestorage", "actionmailbox", "actiontext", "curses", "sync", "jar-dependencies", "stringio", "sass-listen", "haml", "fssm", "compass-core", "compass-import-once", "sprockets-helpers", "mongrel", "mustermann", "temple", "io-like"]
gems を検索中 ["facets", "polyglot", "archive-tar-minitar", "gherkin", "multi_test", "cucumber-core", "gherkin3", "cucumber-wire", "event-bus", "cucumber-expressions", "cucumber-formatter-dots", "cucumber-gherkin", "cucumber-html-formatter", "cucumber-cucumber-expressions", "cucumber-messages", "sys-uname", "cucumber-create-meta", "cucumber-ci-environment", "database_cleaner-core", "unicode_utils", "strings-ansi", "test-unit", "hitimes", "rbtree", "faraday_middleware", "yajl-ruby", "avl_tree", "CFPropertyList", "sys-admin", "win32-dir", "windows-api", "windows-pr", "win32-security", "hocon", "celluloid-gems", "coveralls", "dotenv-deployment", "SexpProcessor", "net-scp", "ruby-openid", "netrc", "http-cookie", "http-accept", "macaddr", "log4r", "rails-observers", "activemodel-serializers-xml", "marcel", "mimemagic", "coffee-rails", "em-hiredis", "faye-websocket", "websocket-driver", "ruby-maven", "cgi_multipart_eof_fix", "fastthread", "gem_plugin", "tool"]
HTTP GET https://index.rubygems.org/info/cucumber-core
HTTP GET https://index.rubygems.org/info/cucumber-gherkin
HTTP 206 Partial Content https://index.rubygems.org/info/cucumber-core
HTTP 206 Partial Content https://index.rubygems.org/info/cucumber-gherkin
gems を検索中 ["c21e", "minitar", "minitar-cli", "os", "cucumber-tag_expressions", "cucumber-tag-expressions", "google-protobuf", "protobuf-cucumber", "power_assert", "configuration", "mkrf", "roauth", "libxml-ruby", "ffi-win32-extensions", "colorize", "net-ssh", "ruby-yadis", "domain_name", "sqlite3", "systemu", "coffee-script", "hiredis", "websocket-extensions", "maven-tools", "ruby-maven-libs"]
HTTP GET https://index.rubygems.org/info/cucumber-tag-expressions
HTTP GET https://index.rubygems.org/info/power_assert
HTTP 206 Partial Content https://index.rubygems.org/info/cucumber-tag-expressions
HTTP 206 Partial Content https://index.rubygems.org/info/power_assert
HTTP GET https://index.rubygems.org/info/libxml-ruby
HTTP 206 Partial Content https://index.rubygems.org/info/libxml-ruby
HTTP GET https://index.rubygems.org/info/sqlite3
HTTP 206 Partial Content https://index.rubygems.org/info/sqlite3
gems を検索中 ["powerbar", "middleware", "pattern-match", "needle", "jruby-pageant", "bcrypt_pbkdf", "rbnacl", "rbnacl-libsodium", "coffee-script-source", "virtus"]
gems を検索中 ["ansi", "descendants_tracker", "axiom-types", "coercible", "equalizer"]
gems を検索中 ["ice_nine", "adamantium"]
gems を検索中 ["memoizable"]
https://github.com/rails/sprockets を取得中
rake 13.0.6 を使用中
0: rake (13.0.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rake-13.0.6.gemspec
concurrent-ruby 1.1.10 を使用中
0: concurrent-ruby (1.1.10) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/concurrent-ruby-1.1.10.gemspec
minitest 5.17.0 を取得中
builder 3.2.4 を使用中
1: builder (3.2.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/builder-3.2.4.gemspec
erubi 1.11.0 を使用中
2: erubi (1.11.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/erubi-1.11.0.gemspec
crass 1.0.6 を使用中
1: crass (1.0.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/crass-1.0.6.gemspec
racc 1.6.2 を取得中
mini_mime 1.1.2 を使用中
1: mini_mime (1.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_mime-1.1.2.gemspec
rack 2.2.5 を取得中
timeout 0.3.1 を使用中
1: timeout (0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/timeout-0.3.1.gemspec
public_suffix 5.0.1 を使用中
1: public_suffix (5.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/public_suffix-5.0.1.gemspec
aws-eventstream 1.2.0 を使用中
1: aws-eventstream (1.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-eventstream-1.2.0.gemspec
aws-partitions 1.583.0 を使用中
1: aws-partitions (1.583.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-partitions-1.583.0.gemspec
jmespath 1.6.2 を使用中
1: jmespath (1.6.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/jmespath-1.6.2.gemspec
msgpack 1.6.0 を使用中
1: msgpack (1.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/msgpack-1.6.0.gemspec
bundler 2.4.1 を使用中
1: bundler (2.4.1) from /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source
byebug 11.1.3 を使用中
1: byebug (11.1.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/byebug-11.1.3.gemspec
cbor 0.5.9.6 を使用中
1: cbor (0.5.9.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cbor-0.5.9.6.gemspec
cgi 0.3.6 を取得中
cgi 0.3.6 (ネイティブ拡張あり) をインストール中
minitest 5.17.0 をインストール中
ネイティブ拡張をビルドしています。時間がかかる場合があります...
rack 2.2.5 をインストール中
racc 1.6.2 (ネイティブ拡張あり) をインストール中
0: minitest (5.17.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/minitest-5.17.0.gemspec
chunky_png 1.4.0 を使用中
0: chunky_png (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/chunky_png-1.4.0.gemspec
coderay 1.1.3 を使用中
0: coderay (1.1.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/coderay-1.1.3.gemspec
colored2 3.1.2 を使用中
0: colored2 (3.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/colored2-3.1.2.gemspec
connection_pool 2.3.0 を使用中
0: connection_pool (2.3.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/connection_pool-2.3.0.gemspec
openssl 3.0.2 を取得中
2: rack (2.2.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-2.2.5.gemspec
cppjieba_rb 0.4.2 を使用中
2: cppjieba_rb (0.4.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cppjieba_rb-0.4.2.gemspec
diffy 3.4.2 を使用中
2: diffy (3.4.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/diffy-3.4.2.gemspec
digest 3.1.1 を使用中
2: digest (3.1.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/digest-3.1.1.gemspec
discourse-fonts 0.0.9 を使用中
2: discourse-fonts (0.0.9) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/discourse-fonts-0.0.9.gemspec
regexp_parser 2.6.1 を使用中
2: regexp_parser (2.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/regexp_parser-2.6.1.gemspec
email_reply_trimmer 0.1.13 を使用中
2: email_reply_trimmer (0.1.13) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/email_reply_trimmer-0.1.13.gemspec
excon 0.96.0 を取得中
openssl 3.0.2 (ネイティブ拡張あり) をインストール中
excon 0.96.0 をインストール中
2: excon (0.96.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/excon-0.96.0.gemspec
execjs 2.8.1 を使用中
2: execjs (2.8.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/execjs-2.8.1.gemspec
exifr 1.3.10 を使用中
2: exifr (1.3.10) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/exifr-1.3.10.gemspec
faraday-net_http 3.0.2 を使用中
2: faraday-net_http (3.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/faraday-net_http-3.0.2.gemspec
ruby2_keywords 0.0.5 を使用中
2: ruby2_keywords (0.0.5) from /usr/local/lib/ruby/gems/3.1.0/specifications/default/ruby2_keywords-0.0.5.gemspec
fast_blank 1.0.1 を使用中
2: fast_blank (1.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/fast_blank-1.0.1.gemspec
fast_xs 0.8.0 を使用中
2: fast_xs (0.8.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/fast_xs-0.8.0.gemspec
fastimage 2.2.6 を使用中
2: fastimage (2.2.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/fastimage-2.2.6.gemspec
ffi 1.15.5 を使用中
2: ffi (1.15.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ffi-1.15.5.gemspec
fspath 3.1.2 を使用中
2: fspath (3.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/fspath-3.1.2.gemspec
gc_tracer 1.5.1 を使用中
2: gc_tracer (1.5.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/gc_tracer-1.5.1.gemspec
guess_html_encoding 0.0.11 を使用中
2: guess_html_encoding (0.0.11) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/guess_html_encoding-0.0.11.gemspec
hana 1.3.7 を使用中
2: hana (1.3.7) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/hana-1.3.7.gemspec
hashie 5.0.0 を使用中
2: hashie (5.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/hashie-5.0.0.gemspec
highline 2.1.0 を取得中
highline 2.1.0 をインストール中
2: highline (2.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/highline-2.1.0.gemspec
hkdf 1.0.0 を取得中
hkdf 1.0.0 をインストール中
2: hkdf (1.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/hkdf-1.0.0.gemspec
htmlentities 4.3.4 を使用中
2: htmlentities (4.3.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/htmlentities-4.3.4.gemspec
http_accept_language 2.1.1 を使用中
2: http_accept_language (2.1.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/http_accept_language-2.1.1.gemspec
image_size 3.2.0 を使用中
2: image_size (3.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/image_size-3.2.0.gemspec
in_threads 1.6.0 を使用中
2: in_threads (1.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/in_threads-1.6.0.gemspec
progress 3.6.0 を使用中
2: progress (3.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/progress-3.6.0.gemspec
json 2.6.3 を使用中
2: json (2.6.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/json-2.6.3.gemspec
uri_template 0.7.0 を使用中
2: uri_template (0.7.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/uri_template-0.7.0.gemspec
jwt 2.6.0 を取得中
jwt 2.6.0 をインストール中
2: jwt (2.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/jwt-2.6.0.gemspec
kgio 2.11.4 を使用中
2: kgio (2.11.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/kgio-2.11.4.gemspec
libv8-node 16.10.0.0 (x86_64-linux) を使用中
2: libv8-node (16.10.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/libv8-node-16.10.0.0-x86_64-linux.gemspec
method_source 1.0.0 を使用中
2: method_source (1.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/method_source-1.0.0.gemspec
thor 1.2.1 を使用中
2: thor (1.2.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/thor-1.2.1.gemspec
zeitwerk 2.6.6 を使用中
2: zeitwerk (2.6.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/zeitwerk-2.6.6.gemspec
logstash-event 1.2.02 を使用中
2: logstash-event (1.2.02) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/logstash-event-1.2.02.gemspec
logster 2.11.3 を使用中
2: logster (2.11.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/logster-2.11.3.gemspec
lru_redux 1.1.0 を使用中
2: lru_redux (1.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/lru_redux-1.1.0.gemspec
lz4-ruby 0.3.3 を使用中
2: lz4-ruby (0.3.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/lz4-ruby-0.3.3.gemspec
maxminddb 0.1.22 を使用中
2: maxminddb (0.1.22) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/maxminddb-0.1.22.gemspec
memory_profiler 1.0.1 を使用中
2: memory_profiler (1.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/memory_profiler-1.0.1.gemspec
redis 4.8.0 を使用中
2: redis (4.8.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/redis-4.8.0.gemspec
mini_sql 1.4.0 を使用中
2: mini_sql (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_sql-1.4.0.gemspec
multi_json 1.15.0 を使用中
2: multi_json (1.15.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/multi_json-1.15.0.gemspec
multi_xml 0.6.0 を使用中
2: multi_xml (0.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/multi_xml-0.6.0.gemspec
mustache 1.1.1 を使用中
2: mustache (1.1.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mustache-1.1.1.gemspec
uri 0.12.0 を使用中
2: uri (0.12.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/uri-0.12.0.gemspec
nio4r 2.5.8 を使用中
2: nio4r (2.5.8) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/nio4r-2.5.8.gemspec
version_gem 1.1.1 を使用中
2: version_gem (1.1.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/version_gem-1.1.1.gemspec
oj 3.13.14 を使用中
2: oj (3.13.14) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oj-3.13.14.gemspec
optimist 3.0.1 を使用中
2: optimist (3.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/optimist-3.0.1.gemspec
pg 1.4.5 を使用中
2: pg (1.4.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pg-1.4.5.gemspec
r2 0.2.7 を使用中
2: r2 (0.2.7) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/r2-0.2.7.gemspec
raindrops 0.20.0 を使用中
2: raindrops (0.20.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/raindrops-0.20.0.gemspec
rchardet 1.8.0 を使用中
2: rchardet (1.8.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rchardet-1.8.0.gemspec
rexml 3.2.5 を使用中
2: rexml (3.2.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rexml-3.2.5.gemspec
rinku 2.0.6 を使用中
2: rinku (2.0.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rinku-2.0.6.gemspec
rotp 6.2.2 を使用中
2: rotp (6.2.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rotp-6.2.2.gemspec
rqrcode_core 1.2.0 を使用中
2: rqrcode_core (1.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rqrcode_core-1.2.0.gemspec
rubyzip 2.3.2 を使用中
2: rubyzip (2.3.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rubyzip-2.3.2.gemspec
tilt 2.0.11 を使用中
2: tilt (2.0.11) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/tilt-2.0.11.gemspec
sshkey 2.0.0 を使用中
2: sshkey (2.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sshkey-2.0.0.gemspec
stackprof 0.2.23 を使用中
2: stackprof (0.2.23) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/stackprof-0.2.23.gemspec
unf_ext 0.0.8.2 を使用中
2: unf_ext (0.0.8.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/unf_ext-0.0.8.2.gemspec
webrick 1.7.0 を取得中
webrick 1.7.0 をインストール中
2: webrick (1.7.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/webrick-1.7.0.gemspec
xorcist 1.1.3 を使用中
2: xorcist (1.1.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/xorcist-1.1.3.gemspec
i18n 1.12.0 を使用中
2: i18n (1.12.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/i18n-1.12.0.gemspec
tzinfo 2.0.5 を使用中
2: tzinfo (2.0.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/tzinfo-2.0.5.gemspec
mail 2.8.0.edge from https://github.com/discourse/mail.git (at main@5b700fc) を使用中
2: mail (2.8.0.edge) from /var/www/discourse/vendor/bundle/ruby/3.1.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
net-protocol 0.2.1 を使用中
2: net-protocol (0.2.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-protocol-0.2.1.gemspec
addressable 2.8.1 を使用中
2: addressable (2.8.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/addressable-2.8.1.gemspec
aws-sigv4 1.5.0 を使用中
2: aws-sigv4 (1.5.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sigv4-1.5.0.gemspec
bootsnap 1.15.0 を使用中
2: bootsnap (1.15.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/bootsnap-1.15.0.gemspec
rack-test 2.0.2 を使用中
2: rack-test (2.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-test-2.0.2.gemspec
request_store 1.5.1 を使用中
2: request_store (1.5.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/request_store-1.5.1.gemspec
message_bus 4.3.2 を取得中
message_bus 4.3.2 をインストール中
2: message_bus (4.3.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/message_bus-4.3.2.gemspec
rack-mini-profiler 3.0.0 を使用中
2: rack-mini-profiler (3.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-mini-profiler-3.0.0.gemspec
rack-protection 3.0.5 を使用中
2: rack-protection (3.0.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-protection-3.0.5.gemspec
sprockets 3.7.2 from https://github.com/rails/sprockets (at 3.x@f4d3dae) を使用中
2: sprockets (3.7.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/bundler/gems/sprockets-f4d3dae71ef2/sprockets.gemspec
ecma-re-validator 0.4.0 を使用中
2: ecma-re-validator (0.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ecma-re-validator-0.4.0.gemspec
uglifier 4.2.0 を使用中
2: uglifier (4.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/uglifier-4.2.0.gemspec
faraday 2.7.2 を使用中
2: faraday (2.7.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/faraday-2.7.2.gemspec
mini_suffix 0.3.3 を使用中
2: mini_suffix (0.3.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_suffix-0.3.3.gemspec
omniauth 1.9.2 を使用中
2: omniauth (1.9.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-1.9.2.gemspec
sassc 2.0.1 を使用中
2: sassc (2.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sassc-2.0.1.gemspec
image_optim 0.31.2 を使用中
2: image_optim (0.31.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/image_optim-0.31.2.gemspec
mini_racer 0.6.3 を使用中
2: mini_racer (0.6.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_racer-0.6.3.gemspec
pry 0.14.2 を取得中
pry 0.14.2 をインストール中
2: pry (0.14.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pry-0.14.2.gemspec
logstash-logger 0.26.1 を使用中
2: logstash-logger (0.26.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/logstash-logger-0.26.1.gemspec
sidekiq 6.5.8 を使用中
2: sidekiq (6.5.8) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sidekiq-6.5.8.gemspec
net-http 0.3.2 を使用中
2: net-http (0.3.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-http-0.3.2.gemspec
oauth-tty 1.0.5 を使用中
2: oauth-tty (1.0.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oauth-tty-1.0.5.gemspec
snaky_hash 2.0.1 を使用中
2: snaky_hash (2.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/snaky_hash-2.0.1.gemspec
puma 6.0.2 を取得中
puma 6.0.2 (ネイティブ拡張あり) をインストール中
1: cgi (0.3.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cgi-0.3.6.gemspec
redis-namespace 1.9.0 を使用中
1: redis-namespace (1.9.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/redis-namespace-1.9.0.gemspec
rbtrace 0.4.14 を使用中
1: rbtrace (0.4.14) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rbtrace-0.4.14.gemspec
rqrcode 2.1.2 を使用中
1: rqrcode (2.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rqrcode-2.1.2.gemspec
rss 0.2.9 を使用中
1: rss (0.2.9) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rss-0.2.9.gemspec
unf 0.1.4 を使用中
1: unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/unf-0.1.4.gemspec
unicorn 6.1.0 を使用中
1: unicorn (6.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/unicorn-6.1.0.gemspec
activesupport 7.0.3.1 を使用中
1: activesupport (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activesupport-7.0.3.1.gemspec
net-imap 0.3.1 を使用中
1: net-imap (0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-imap-0.3.1.gemspec
net-pop 0.1.2 を使用中
1: net-pop (0.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-pop-0.1.2.gemspec
net-smtp 0.3.3 を使用中
1: net-smtp (0.3.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-smtp-0.3.3.gemspec
css_parser 1.13.0 を取得中
css_parser 1.13.0 をインストール中
1: css_parser (1.13.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/css_parser-1.13.0.gemspec
aws-sdk-core 3.130.2 を使用中
1: aws-sdk-core (3.130.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-core-3.130.2.gemspec
json_schemer 0.2.23 を使用中
1: json_schemer (0.2.23) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/json_schemer-0.2.23.gemspec
faraday-retry 2.0.0 を使用中
1: faraday-retry (2.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/faraday-retry-2.0.0.gemspec
oauth2 1.4.11 を使用中
1: oauth2 (1.4.11) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oauth2-1.4.11.gemspec
pry-byebug 3.10.1 を使用中
1: pry-byebug (3.10.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pry-byebug-3.10.1.gemspec
pry-rails 0.3.9 を使用中
1: pry-rails (0.3.9) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pry-rails-0.3.9.gemspec
mini_scheduler 0.15.0 を使用中
1: mini_scheduler (0.15.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_scheduler-0.15.0.gemspec
oauth 1.1.0 を使用中
1: oauth (1.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oauth-1.1.0.gemspec
globalid 1.0.0 を使用中
1: globalid (1.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/globalid-1.0.0.gemspec
activemodel 7.0.3.1 を使用中
1: activemodel (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activemodel-7.0.3.1.gemspec
aws-sdk-kms 1.56.0 を使用中
1: aws-sdk-kms (1.56.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-kms-1.56.0.gemspec
aws-sdk-sns 1.53.0 を使用中
1: aws-sdk-sns (1.53.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-sns-1.53.0.gemspec
omniauth-oauth2 1.7.3 を使用中
1: omniauth-oauth2 (1.7.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-oauth2-1.7.3.gemspec
activejob 7.0.3.1 を使用中
1: activejob (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activejob-7.0.3.1.gemspec
active_model_serializers 0.8.4 を使用中
1: active_model_serializers (0.8.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/active_model_serializers-0.8.4.gemspec
activerecord 7.0.3.1 を使用中
1: activerecord (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activerecord-7.0.3.1.gemspec
omniauth-oauth 1.2.0 を使用中
1: omniauth-oauth (1.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-oauth-1.2.0.gemspec
aws-sdk-s3 1.114.0 を使用中
1: aws-sdk-s3 (1.114.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-s3-1.114.0.gemspec
discourse-seed-fu 2.3.12 を使用中
1: discourse-seed-fu (2.3.12) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/discourse-seed-fu-2.3.12.gemspec
omniauth-facebook 9.0.0 を使用中
1: omniauth-facebook (9.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-facebook-9.0.0.gemspec
omniauth-github 1.4.0 を使用中
1: omniauth-github (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-github-1.4.0.gemspec
omniauth-google-oauth2 0.8.2 を使用中
1: omniauth-google-oauth2 (0.8.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
omniauth-twitter 1.4.0 を使用中
1: omniauth-twitter (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-twitter-1.4.0.gemspec
3: racc (1.6.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/racc-1.6.2.gemspec
nokogiri 1.14.0 (x86_64-linux) を取得中
nokogiri 1.14.0 (x86_64-linux) をインストール中
1: nokogiri (1.14.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/nokogiri-1.14.0-x86_64-linux.gemspec
rails-dom-testing 2.0.3 を使用中
3: rails-dom-testing (2.0.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails-dom-testing-2.0.3.gemspec
loofah 2.19.1 を使用中
3: loofah (2.19.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/loofah-2.19.1.gemspec
ruby-readability 0.7.0 を使用中
3: ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ruby-readability-0.7.0.gemspec
sanitize 6.0.0 を使用中
3: sanitize (6.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sanitize-6.0.0.gemspec
rails-html-sanitizer 1.4.4 を使用中
3: rails-html-sanitizer (1.4.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails-html-sanitizer-1.4.4.gemspec
actionview 7.0.3.1 を使用中
3: actionview (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionview-7.0.3.1.gemspec
actionpack 7.0.3.1 を使用中
3: actionpack (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionpack-7.0.3.1.gemspec
actionview_precompiler 0.2.3 を使用中
3: actionview_precompiler (0.2.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionview_precompiler-0.2.3.gemspec
actionmailer 7.0.3.1 を使用中
3: actionmailer (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionmailer-7.0.3.1.gemspec
railties 7.0.3.1 を使用中
3: railties (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/railties-7.0.3.1.gemspec
sprockets-rails 3.4.2 を使用中
3: sprockets-rails (3.4.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sprockets-rails-3.4.2.gemspec
lograge 0.12.0 を使用中
3: lograge (0.12.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/lograge-0.12.0.gemspec
rails_failover 0.8.1 を使用中
3: rails_failover (0.8.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails_failover-0.8.1.gemspec
rails_multisite 4.0.1 を使用中
3: rails_multisite (4.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails_multisite-4.0.1.gemspec
sassc-rails 2.1.2 を使用中
3: sassc-rails (2.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sassc-rails-2.1.2.gemspec
2: puma (6.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/puma-6.0.2.gemspec
0: openssl (3.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/openssl-3.0.2.gemspec
openssl-signature_algorithm 1.2.1 を使用中
3: openssl-signature_algorithm (1.2.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/openssl-signature_algorithm-1.2.1.gemspec
web-push 3.0.0 を取得中
cose 1.3.0 を使用中
2: cose (1.3.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cose-1.3.0.gemspec
web-push 3.0.0 をインストール中
3: web-push (3.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/web-push-3.0.0.gemspec
バンドル完了! 135個のGemfile依存関係、171個のgemがインストールされました。
'test'および'development'グループのgemはインストールされませんでした。
バンドルされたgemは`./vendor/bundle`にインストールされます。
I, [2023-01-14T15:22:25.177577 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2023-01-14T15:22:26.935503 #1] INFO -- : PM-Scannerはすでに最新互換バージョンです
discourse-adpluginはすでに最新互換バージョンです
discourse-assignはすでに最新互換バージョンです
discourse-bccはすでに最新互換バージョンです
discourse-cakedayはすでに最新互換バージョンです
discourse-calendarはすでに最新互換バージョンです
discourse-canned-repliesはすでに最新互換バージョンです
discourse-checklistはすでに最新互換バージョンです
discourse-data-explorerはすでに最新互換バージョンです
discourse-fingerprintはすでに最新互換バージョンです
discourse-followはすでに最新互換バージョンです
discourse-gamificationはすでに最新互換バージョンです
discourse-patreonはすでに最新互換バージョンです
discourse-perspective-apiはすでに最新互換バージョンです
discourse-reactionsはすでに最新互換バージョンです
discourse-saved-searchesはすでに最新互換バージョンです
discourse-solvedはすでに最新互換バージョンです
discourse-spoiler-alertはすでに最新互換バージョンです
discourse-translatorはすでに最新互換バージョンです
discourse-user-notesはすでに最新互換バージョンです
discourse-whos-onlineはすでに最新互換バージョンです
discourse-yearly-reviewはすでに最新互換バージョンです
docker_managerはすでに最新互換バージョンです
I, [2023-01-14T15:22:26.936443 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rakeが中止されました!
NameError: 初期化されていない定数 ChatMessage
Object.const_get(camel_cased_word)
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.3.1/lib/active_support/inflector/methods.rb:280:in `const_get'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.3.1/lib/active_support/inflector/methods.rb:280:in `constantize'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.3.1/lib/active_support/core_ext/string/inflections.rb:74:in `constantize'
/var/www/discourse/lib/plugin/instance.rb:327:in `rescue in block in add_model_callback'
/var/www/discourse/lib/plugin/instance.rb:324:in `block in add_model_callback'
/var/www/discourse/lib/plugin/instance.rb:1320:in `reloadable_patch'
/var/www/discourse/lib/plugin/instance.rb:322:in `add_model_callback'
/var/www/discourse/plugins/PM-Scanner/plugin.rb:12:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:503:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:501:in `each'
/var/www/discourse/lib/plugin/instance.rb:501:in `notify_after_initialize'
/var/www/discourse/config/application.rb:228:in `each'
/var/www/discourse/config/application.rb:228:in `block (2 levels) in <class:Application>'
/var/www/discourse/lib/plugin.rb:6:in `initialization_guard'
/var/www/discourse/config/application.rb:228:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.3.1/lib/active_support/lazy_load_hooks.rb:79:in `block in execute_hook'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.3.1/lib/active_support/lazy_load_hooks.rb:72:in `with_execution_control'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.3.1/lib/active_support/lazy_load_hooks.rb:77:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.3.1/lib/active_support/lazy_load_hooks.rb:63:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.3.1/lib/active_support/lazy_load_hooks.rb:62:in `each'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.3.1/lib/active_support/lazy_load_hooks.rb:62:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.3.1/lib/rails/application/finisher.rb:87:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.3.1/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.3.1/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.3.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.3.1/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.3.1/lib/rails/application.rb:372:in `initialize!'
/var/www/discourse/config/environment.rb:7:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.15.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/zeitwerk-2.6.6/lib/zeitwerk/kernel.rb:38:in `require'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.3.1/lib/rails/application.rb:348:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.3.1/lib/rails/application.rb:511:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
原因:
/var/www/discourse/lib/plugin/instance.rb:325:in `block in add_model_callback'
タスク: TOP => db:migrate => db:load_config => environment
(--traceでタスクを実行すると完全なトレースを表示します)
I, [2023-01-14T15:22:30.598254 #1] INFO -- : gem install rrule -v 0.4.4 -i /var/www/discourse/plugins/discourse-calendar/gems/3.1.3 --no-document --ignore-dependencies --no-user-install
rrule-0.4.4 のインストールに成功しました
1 gemがインストールされました
gem install aws-sdk-translate -v 1.35.0 -i /var/www/discourse/plugins/discourse-translator/gems/3.1.3 --no-document --ignore-dependencies --no-user-install
aws-sdk-translate-1.35.0 のインストールに成功しました
1 gemがインストールされました
I, [2023-01-14T15:22:30.598778 #1] INFO -- : 非同期プロセスを終了中
I, [2023-01-14T15:22:30.598898 #1] INFO -- : HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42 に INT を送信
I, [2023-01-14T15:22:30.599111 #1] INFO -- : exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 103 に TERM を送信
2023-01-14 15:22:30.599 UTC [42] LOG: 高速シャットダウンリクエストを受信しました
103:signal-handler (1673709750) SIGTERM を受信し、シャットダウンをスケジュールしています...
2023-01-14 15:22:30.610 UTC [42] LOG: アクティブなトランザクションを中止しています
2023-01-14 15:22:30.614 UTC [42] LOG: バックグラウンドワーカー "logical replication launcher" (PID 51) が終了コード 1 で終了しました
2023-01-14 15:22:30.616 UTC [46] LOG: シャットダウン中
2023-01-14 15:22:30.644 UTC [42] LOG: データベースシステムはシャットダウンしました
103:M 14 Jan 2023 15:22:30.644 # ユーザーがシャットダウンをリクエストしました...
103:M 14 Jan 2023 15:22:30.644 * 終了前に最終RDBスナップショットを保存しています。
103:M 14 Jan 2023 15:22:30.743 * DBがディスクに保存されました
103:M 14 Jan 2023 15:22:30.743 # Redisは現在終了の準備ができました、さようなら...
失敗しました
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' が #<Process::Status: pid 1428 exit 1> で失敗しました
失敗箇所: /usr/local/lib/ruby/gems/3.1.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec がパラメータ {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]} で失敗しました
ブートストラップは終了コード 1 で失敗しました
** ブートストラップに失敗しました ** 上にスクロールして以前のエラーメッセージを確認してください。1つ以上のエラーがある可能性があります。
./discourse-doctor が問題の診断に役立つかもしれません。
4c51c030c0d917cc3e186cec3af5a9ab7d2d3fafd9e4a3e57243aa5a03ecdc6b
