Uploads broken with subfolder installation
Similar to Uploaded avatars and Gravatar not working with subfolder installation…
All uploads are broken on my subfolder install. The uploads make it into the actual uploads directory, but when rendering the posts, all images get src="".
Making a post…
https://i.imgur.com/ofOUY4e.png
After posting…
https://i.imgur.com/EBmnD6e.png
Somewhat amazingly, if I then move to a different browser (chrome now), pull up the topic (where the image is still broken), but then click edit, the image renders in the edit preview once again!
https://i.imgur.com/3rQirhc.png
This confirms it’s successfully uploading to the server, which I’ve verified:
root@cs6991:/var/discourse# ./launcher enter app
x86_64 arch detected.
root@cs6991-app:/var/www/discourse# ls 'public/~cs6991/forum'
backups  uploads
root@cs6991-app:/var/www/discourse# ls 'public/~cs6991/forum/uploads'
default
root@cs6991-app:/var/www/discourse# ls 'public/~cs6991/forum/uploads/default/original/1X/'
08335563eac3a393e60a902d4d38cffdfa6d967d.png  3eee67e6460792667bab4f2248ad4643be4feae3.png
29e403dabcfee32379629fb6d844354193e278ba.png  42ecfcb27b534acc9f3436fa7d291c2fca106e57.png
But it just doesn’t seem to be rendering on the actual page.
Same issue occurs with other uploads, such as avatars.
Some info:
Subfolder: /~cs6991/forum
app.yml
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "128MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 2
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: 'cgi.cse.unsw.edu.au'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: '<<REDACTED>>'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: email-smtp.ap-southeast-2.amazonaws.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: <<REDACTED>>
  DISCOURSE_SMTP_PASSWORD: <<REDACTED>>
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  #DISCOURSE_SMTP_DOMAIN: discourse.example.com    # (required by some providers)
  DISCOURSE_NOTIFICATION_EMAIL: discourse@cs6991.email    # (address to send notifications from)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP address key for IP address lookup
  ## see https://meta.discourse.org/t/-/137387/23 for details
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
  DISCOURSE_RELATIVE_URL_ROOT: '/~cs6991/forum'
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
  - exec:
      cd: $home
      cmd:
        - mkdir -p public/~cs6991/forum
        - cd public/~cs6991/forum && ln -s ../../uploads && ln -s ../../backups
  - replace:
     global: true
     filename: /etc/nginx/conf.d/discourse.conf
     to: |
        rewrite ^/(.*)$ /~cs6991/forum/$1 break;
        proxy_pass http://discourse;
  - replace:
     to: |
        etag off;
        location /~cs6991/forum {
           rewrite ^/~cs6991/forum/?(.*)$ /$1;
  - replace:
       to: $http_your_original_ip_header
       global: true
Everything else, as far as I can tell, appears to be working correctly – just upload rendering that’s acting rather peculiar.
I’ve verified this behaviour on a completely fresh build – that is, rm -rf /var/discourse, completely nuking docker, and following cloud install + subfolder instructions.
If there’s further investigation I can pursue, I’m happy to take those steps. (sorry for imgur links – I’m not allowed 2+ image embeds here yet!)
Cheers!
Some extra info – looks like the src is already stripped away before rendering, as it is missing in the production database:
# sudo -u postgres psql discourse
discourse=# select * from posts where id=13;
 id | user_id | topic_id | post_number |                             raw                             |                                                  cooked                                                  |        created_at         |        updated_at         | reply_to_post_number | reply_count | quote_count |         deleted_at         | off_topic_count | like_count | incoming_link_count | bookmark_count | score | reads | post_type | sort_order | last_editor_id | hidden | hidden_reason_id | notify_moderators_count | spam_count | illegal_count | inappropriate_count |      last_version_at       | user_deleted | reply_to_user_id | percent_rank | notify_user_count | like_score | deleted_by_id | edit_reason | word_count | version | cook_method | wiki |          baked_at          | baked_version | hidden_at | self_edits | reply_quoted | via_email | raw_email | public_version | action_code | locked_by_id | image_upload_id
 13 |       1 |        7 |           2 | ![ferris|690x459](upload://5YA5Y9vjz0iQmn2DErtUBrHCKng.png) | <p><img src="" alt="ferris" data-base62-sha1="5YA5Y9vjz0iQmn2DErtUBrHCKng" width="690" height="459"></p> | 2022-09-01 19:30:38.97281 | 2022-09-01 19:30:38.97281 |                      |           0 |           0 | 2022-09-01 19:47:34.612042 |               0 |          0 |                   0 |              0 |   0.2 |     1 |         1 |          2 |              1 | f      |                  |                       0 |          0 |             0 |                   0 | 2022-09-01 19:30:38.993775 | f            |                  |          0.5 |                 0 |          0 |             1 |             |          5 |       1 |           1 | f    | 2022-09-01 19:30:38.972751 |             2 |           |          0 | f            | f         |           |              1 |             |              |
Also from the network tab creating a reply with an image:
raw	"My+image+is+inserted+next:\n\n![ferris|690x459](upload://5YA5Y9vjz0iQmn2DErtUBrHCKng.png)\n\n\nThe+image+is+above."
unlist_topic	"false"
category	"4"
topic_id	"7"
is_warning	"false"
archetype	"regular"
typing_duration_msecs	"7500"
composer_open_duration_msecs	"14116"
featured_link	""
shared_draft	"false"
draft_key	"topic_7"
image_sizes[https://cgi.cse.unsw.edu.au/~cs6991/forum/uploads/default/original/1X/29e403dabcfee32379629fb6d844354193e278ba.png][width]	"1200"
image_sizes[https://cgi.cse.unsw.edu.au/~cs6991/forum/uploads/default/original/1X/29e403dabcfee32379629fb6d844354193e278ba.png][height]	"800"
nested_post	"true"
or the raw query string if preferred:
raw=My+image+is+inserted+next%3A%0A%0A!%5Bferris%7C690x459%5D(upload%3A%2F%2F5YA5Y9vjz0iQmn2DErtUBrHCKng.png)%0A%0A%0AThe+image+is+above.&unlist_topic=false&category=4&topic_id=7&is_warning=false&archetype=regular&typing_duration_msecs=7500&composer_open_duration_msecs=14116&featured_link=&shared_draft=false&draft_key=topic_7&image_sizes%5Bhttps%3A%2F%2Fcgi.cse.unsw.edu.au%2F~cs6991%2Fforum%2Fuploads%2Fdefault%2Foriginal%2F1X%2F29e403dabcfee32379629fb6d844354193e278ba.png%5D%5Bwidth%5D=1200&image_sizes%5Bhttps%3A%2F%2Fcgi.cse.unsw.edu.au%2F~cs6991%2Fforum%2Fuploads%2Fdefault%2Foriginal%2F1X%2F29e403dabcfee32379629fb6d844354193e278ba.png%5D%5Bheight%5D=800&nested_post=true`
the response seems to echo the post back, and you can see the src is already stripped by that point:
  "action": "create_post",
  "post": {
    "id": 16,
    "name": null,
    "username": "z.kologlu",
    "avatar_template": "/~cs6991/forum/letter_avatar_proxy/v4/letter/z/b9bd4f/{size}.png",
    "created_at": "2022-09-02T05:37:25.680Z",
    "cooked": "<p>My image is inserted next:</p>\n<p><img src=\"\" alt=\"ferris\" data-base62-sha1=\"5YA5Y9vjz0iQmn2DErtUBrHCKng\" width=\"690\" height=\"459\"></p>\n<p>The image is above.</p>",
    "post_number": 5,
    "post_type": 1,
    "updated_at": "2022-09-02T05:37:25.680Z",
    "reply_count": 0,
    "reply_to_post_number": null,
    "quote_count": 0,
    "incoming_link_count": 0,
    "reads": 0,
    "readers_count": 0,
    "score": 0,
    "yours": true,
    "topic_id": 7,
    "topic_slug": "welcome-to-discourse",
    "display_username": null,
    "primary_group_name": null,
    "flair_name": null,
    "flair_url": null,
    "flair_bg_color": null,
    "flair_color": null,
    "version": 1,
    "can_edit": true,
    "can_delete": true,
    "can_recover": false,
    "can_wiki": true,
    "user_title": null,
    "bookmarked": false,
    "raw": "My image is inserted next:\n\n![ferris|690x459](upload://5YA5Y9vjz0iQmn2DErtUBrHCKng.png)\n\n\nThe image is above.",
    "actions_summary": [
        "id": 3,
        "can_act": true
        "id": 4,
        "can_act": true
        "id": 8,
        "can_act": true
        "id": 7,
        "can_act": true
    "moderator": false,
    "admin": true,
    "staff": true,
    "user_id": 1,
    "draft_sequence": 12,
    "hidden": false,
    "trust_level": 1,
    "deleted_at": null,
    "user_deleted": false,
    "edit_reason": null,
    "can_view_edit_history": true,
    "wiki": false,
    "reviewable_id": null,
    "reviewable_score_count": 0,
    "reviewable_score_pending_count": 0
  "success": true
Tracked this issue down further to this function: discourse/app/models/post.rb at main · discourse/discourse · GitHub
Modified my local function:
  def cook(raw, opts = {})
    Rails.logger.info("Cooking post with raw: #{raw}")
    # For some posts, for example those imported via RSS, we support raw HTML. In that
    # case we can skip the rendering pipeline.
    return raw if cook_method == Post.cook_methods[:raw_html]
    options = opts.dup
    options[:cook_method] = cook_method
    post_user = self.user
    options[:user_id] = post_user.id if post_user
    options[:omit_nofollow] = true if omit_nofollow?
    if self.with_secure_media?
      each_upload_url do |url|
        uri = URI.parse(url)
        if FileHelper.is_supported_media?(File.basename(uri.path))
          raw = raw.sub(
            url, Rails.application.routes.url_for(
              controller: "uploads", action: "show_secure", path: uri.path[1..-1], host: Discourse.current_hostname
    cooked = post_analyzer.cook(raw, options)
    Rails.logger.info("Cooked into: #{cooked}")
    new_cooked = Plugin::Filter.apply(:after_post_cook, self, cooked)
    if post_type == Post.types[:regular]
      if new_cooked != cooked && new_cooked.blank?
        Rails.logger.debug("Plugin is blanking out post: #{self.url}\nraw: #{raw}")
      elsif new_cooked.blank?
        Rails.logger.debug("Blank post detected post: #{self.url}\nraw: #{raw}")
    Rails.logger.info("New cooked into: #{new_cooked}")
    new_cooked
Output:
Completed 200 OK in 335ms (Views: 0.4ms | ActiveRecord: 0.0ms | Allocations: 78316)
done
done
Cooking post with raw: ![ferris|690x459](upload://5YA5Y9vjz0iQmn2DErtUBrHCKng.png)
Started POST "/~cs6991/forum/presence/update" for 127.0.0.1 at 2022-09-02 05:55:33 +0000
Processing by PresenceController#update as */*
  Parameters: {"client_id"=>"16308337827949548cb8b156301a493b", "leave_channels"=>["/discourse-presence/reply/7"]}
Completed 200 OK in 19ms (Views: 0.2ms | ActiveRecord: 0.0ms | Allocations: 6182)
done
Cooked into: <p><img src="" alt="ferris" data-base62-sha1="5YA5Y9vjz0iQmn2DErtUBrHCKng" width="690" height="459"></p>
New cooked into: <p><img src="" alt="ferris" data-base62-sha1="5YA5Y9vjz0iQmn2DErtUBrHCKng" width="690" height="459"></p>
done
Managed to track post uploads down to this exact line:
https://github.com/discourse/discourse/blob/main/app/assets/javascripts/pretty-text/addon/sanitizer.js#L23
in particular,
  // relative urls
  if (/^\/[\w\.\-]+/i.test(href)) {
    return href;
breaks because since my forum URL is being served out of an apache user-webdir (which I don’t have control over), it starts with a ~, which breaks that regex.
I’ve confirmed that modifying the character class to include ~ (as [\w\.\-~]) fixes the post uploads, but painfully avatar uploads are still broken!
…aaand the other broken regex:
same ordeal – needs a ~ in the character class
which fixes my avatars
If Core is not so keen on a PR, you could probably permanently resolve that with a custom plugin for your specific site.
