User automatically to a Group
Hello,
if that possible?
I have created a costum userfield as Dropdown with
  1. Faction 1
  2. Faction 2
The user have to set the Faction on the Register and cant edit it.
Now he should automatically join the Group of his Faction.
Regards,
Imperator
I believe this is only supported by email address at the moment. People with certain email addresses (think @companyname.com) will automatically be added to groups as they join the site, if the group has that setting enabled.
yes that way i found :slight_smile: but i need that with that Faction from the userfields maybe someone have a idea
You will have to write a plugin if you want that feature right now.
This is now possible using the Automation plugin
