User gets 500 after authentication
Hello guys, one of my users experienced following error:
He enters login, password, push 'Login" and get this:
I’ve checked out forum logs and here is what I found:
NoMethodError (undefined method `enable_quoting' for nil:NilClass)
/var/www/discourse/app/serializers/current_user_serializer.rb:54:in `enable_quoting'
(eval):18:in `_fast_attributes'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:467:in `rescue in attributes'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:455:in `attributes'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:479:in `_serializable_hash'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:361:in `serializable_hash'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:349:in `as_json'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/multi_json-1.11.2/lib/multi_json/adapters/oj.rb:21:in `dump'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/multi_json-1.11.2/lib/multi_json/adapter.rb:25:in `dump'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/multi_json-1.11.2/lib/multi_json.rb:136:in `dump'
/var/www/discourse/app/controllers/application_controller.rb:348:in `preload_current_user_data'
/var/www/discourse/app/controllers/application_controller.rb:203:in `preload_json'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:432:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:164:in `block in halting'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:504:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:504:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:504:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.2/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionview-4.2.5.2/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.9.2/lib/mini_profiler/profiling_methods.rb:76:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/routing/route_set.rb:74:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/routing/route_set.rb:43:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/routing/mapper.rb:49:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/routing/route_set.rb:815:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.3.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/conditionalget.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:129:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.2/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.2/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.2/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-1.1.1/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.2/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.2/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:10:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.2/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.9.2/lib/mini_profiler/profiler.rb:167:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/message_bus-2.0.0.beta.5/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.2/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.2/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.2/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.2/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/lib/unicorn/http_server.rb:562:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/lib/unicorn/http_server.rb:658:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/lib/unicorn/http_server.rb:508:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/lib/unicorn/http_server.rb:132:in `start'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `<main>'
I’m using the last version of Discourse, can anybody help me with this error? What should I do to fix this error?
Thanks in advance.
Let me sort this out, I know what it is
Fixed per:
It will take up to 8 hours for the fix to take place after upgrading.
