@marcospreviato you mean you want your users to post and create threads based on their levels?
This is possible, since we are using groups. You can create a link for discourseforum.com/groups/basic for Basic users for example where they can go to and participate as a group. Also, there is this plugin that creates a button that is only visible to a specific group:
@marcospreviato Got it. Actually I was going to be working on this tomorrow for my forum
Its going to be very simple for me though - something like this:
Its from a game called 8 Ball Pool Multiplayer (great game btw). So we have a bar divided into five areas, for the five levels. Whatever level you are at, the bar is filled to that level. I will post it here as soon as I have it done. I also plan to add a points system, which computes the level + badges + other stats to a number. Do you have any suggestions?
@marcospreviato No Ill be sticking with just the badge below the user avatar. The forum is almost done and should be live later this month.
Putting the level bar can be done as well, although it might be tricky. Let me finish the bar and the points system, then Ill see if I can get it to work below the avatars.
For my forum, what I am doing is having three buttons on the header. The left button opens a category slide in menu which shows the categories and search bar. The right button is a slide in user menu which includes the messages in it as well. The middle menu is a drop down that shows the user card, with the avatar, points, level bar, badge, etc.
