Show a user's reputation/user level next to their name
Users are requesting a feature to display user reputation or statistics next to their name, such as post count, join date, or custom labels JJames. Some suggest using badges or auto-assigned titles, but this might be better suited as a plugin codinghorror.
Currently, user levels are not easily visible and require clicking on the username JJames. A possible solution could be displaying user statistics under the avatar using a plugin Mittineague.
A user-reputation-badge plugin exists P16, but users are looking for a plugin that displays more detailed user statistics Rainbowresidue.
One user has shared a hack to add user post count to the post template and user card, which could serve as inspiration for a plugin Overgrow.
First of all, I’ve been using discourse for about a couple of years now (since the pre 1.0 days). Great product and our community loves it.
My only gripe with it is that it doesn’t show any kind of statistics/reputation next to the person’s name. Right now it appears that everyone is at the same level; there’s no way to tell apart between the guy who’s been consistently posting for two years and a guy who just signed up yesterday.
I know that @codinghorror doesn’t want to go the typical forum route where they list “meaningless” stats such as number of posts created. While I understand that argument, I do want to show something next to the username so that others know who they’re dealing with. Perhaps display a user level, some kind of badge, etc.
I saw previous discussions relating to this, but they all seemed to have died down in 2013/2014.
Is something like this in the pipeline?
5 curtidas
Something like this when you click on the avatar or name?
2 curtidas
Two problems with this approach:
  1. It’s not easily visible. I want to look at a thread and quickly see who’s who without clicking on the user’s name.
It also took me sometime to realize that you can actually click on the username. I bet most users don’t bother clicking unless they need to contact the user for something.
  1. User levels (i.e., Member) as a metric are too coarse. I have users that are in Level 0, 1 and 2. Most of the active users are at Level 2. It doesn’t tell me anything when most of the active threads are being discussed by Level 2 people.
I think displaying something right next to the user’s avatar is the ideal solution. When I browse other forums, the user’s reputation/# of posts/custom label is the first thing that catches my eye when I try to figure out who the user is.
4 curtidas
I take it your forum has been online for somewhere between 20 and 45 days, then?
IMHO that’s probably the best reason for having the User Card vs. “always there”
If one is not interested in that information it is nothing but distracting visual noise and clutter.
If someone is interested, a simple click is all it takes.
That said, the post.hbs template has a plugin-outlet
{{plugin-outlet "poster-avatar-bottom"}}
which is located beneath the avatar of each post
So using a plugin to display stuff there should be easy enough if you really wanted it.
You could do something with badges and auto assigned titles. But probably this is plugin territory.
Can you mock up what you have in mind visually?
No, this new forum is live for about 7-8 months. I’m the only guy who’s at Level 3.
I do have some people that consistently start topics and add lots of value to the forum. So, perhaps I need to play with the settings to make sure they’re being rewarded/promoted properly.
2 curtidas
Sort of related: I’d still love to see a reputation system (trust levels mainly convey how long someone’s been around and not whether they’re a positive contributor):
https://meta.discourse.org/t/ability-to-block-or-mute-another-user/6001/26?u=adamcapriola
I’ve been meaning to come up with a full mockup/schematic … will try to draw something up in June. :pencil2:
2 curtidas
Isn’t there already a user CP option to change one’s title from ‘won’ badges?
3 curtidas
It’s been some time since I opened this thread, so I wanted to check if theres a way to attach certain statistics next to the username? As in how many threads they started, when they joined, etc.
Something like this would be ideal.
Is this something that can be done via a plugin? Or does it require a special hack?
I want everyone to know who’s new on the forum and who’s been heavily participating, etc.
1 curtida
I’m interested in getting the same thing for our forum under everyone’s avatar, many folks have asked for it.
Is there a working plugin?
Can someone please share?
@Rainbowresidue
1 curtida
Thanks so much, but I’m not looking for a plugin for a badge.
I’m looking for a plugin for something like this (to go under the avatar.), more like user stats.
I will be tackling that as it is a feature I want as well, but don’t have a timeline as of now.
2 curtidas
Great, if you figure it out, I’d love to try it out for you.
:smiley:
1 curtida
Hello, I just wanted to share my findings. Its not plugin ready, just quick hack to core files (sorry). But as inspiration for someone it may be handy…
Add User Post Count in post template and user-card
Use as example. It can be adjusted to display various user stats (post count, user_last_seen_at, etc.) in user-card and in post stream.
app/assets/javascripts/discourse/templates/user-card.hbs
{{user-reputation post_count=user.post_count}}
/assets/javascripts/discourse/components/user-reputation.js.es6
    export default Ember.Component.extend({
      tagName: 'div',
      classNames: ['user-reputation-user-card'],
      render: function(buffer) {
        const post_count = this.get('post_count');
        const contents = '<b>' + post_count + '</b>';
        buffer.push(contents);
/assets/javascripts/discourse/initializers/user-reputation-init.js.es6
    import { withPluginApi } from 'discourse/lib/plugin-api';
    import { includeAttributes } from 'discourse/lib/transform-post';
    import { h } from 'virtual-dom';
    export default {
      initialize(){
        withPluginApi('0.1', api => {
          api.includePostAttributes('user_last_seen_at');  // (automatically added to transform-post.js.es6)
          api.decorateWidget('poster-name:after', function(helper) {
            const attrs = helper.attrs;
            const user_custom_fields = attrs.user_title;
            const post_count = attrs.post_count;
            return [h('span', 'post_count ' + post_count)];
app/serializers/user_serializer.rb
                  :user_fields,
                  :topic_post_count,
                  :pending_count,
    +              :post_count,
                  :profile_view_count
app/serializers/post_serializer.rb
                  :via_email,
                  :is_auto_generated,
                  :action_code,
                  :action_code_who
    +              :post_count,
    +   def post_count
    +     object.try(:user).try(:post_count)
    +     #object.try(:user).try(:user_stat).try(:post_count)
    +  end
4 curtidas
