RGJ introduces the User Response Times plugin, which calculates and displays a user’s average response time to private messages on their user card. The plugin uses data from the last 60 days by default, excluding admin users, and allows configuration of the calculation mode (percentile or average) and the specific percentile used. The feature was sponsored by @WorldIsMine.
Truest asks if the feature can be restricted to staff only, but RGJ explains that the plugin’s purpose is to share this information among all users, making staff-only access contrary to its design, though they would accept a PR for such a feature. Olle11 raises GDPR concerns, but Jagster argues that response times do not identify users and are not sensitive data. RGJ agrees, noting that the data is derived from existing activity, averaged, and no more privacy-invasive than general forum activity.
The discussion also touches on user behavior, with merefield and Heliosurge joking about users “gaming” the system to appear more responsive. Finally, Roi reports a deprecation notice regarding the use of the deprecated .hbs extension, prompting RGJ to promise a refactor to .gjs in the coming weeks.
The response times are recalculated on a daily basis and are based on the time a user takes to respond to their PMs over a certain time interval. Admin users are excluded.
Configuration
Setting
What it does
user response times mode
Determines the algorithm used. Either percentile or average. Default percentile.
user response times percentile
Used with mode percentile. Determines the percentile used in the calculation. Range 1-100. 100 is the maximum response time. 50 is the median. Recommended (and default) value is 80.
user response times days
The number of days that the calculation looks back. Default 60.
When you change these values you need to manually trigger the Jobs::UpdateResponseTimes job (or wait up to 24 hours).
What do you mean by that? That isn’t such piece of data that GDPR controls, but if you like you can tell to users why it is collected, why it is needed, how it is stored and for what it is needed. If you have legit reason for all those point everything is GDPR friendly.
Those points should be considered anyway, because the answer tells right away if it is really needed or would it be just another decorative add from class nice to have, but no one isn’t actually interested
But still — knowing response time is not such data that can or would use identify a user.
However, it uses information that is already there, it’s not storing extra data. It’s not more or less GDPR-friendly than the other activity of a user on a forum. And the data is averaged, it does not give away concrete data points.
The whole idea about the plugin is to make the information available between users, so making it available to staff only is outside of what I think would be meaningful use. I would accept a PR.
[PLUGIN discourse-user-response-times] DEPRECATION NOTICE: The file ‘discourse/plugins/discourse-user-response-times/discourse/connectors/user-card-metadata/discourse-user-response-times.hbs’ uses the deprecated .hbs extension. Refactor it to use ‘.gjs’ instead. [deprecation id: discourse.hbs-extension] [info: Deprecating .hbs file extension in themes and plugins]
