Errore: il nome utente esiste già
Perché questo errore si verifica costantemente nel mio forum? È sicuro ignorarlo?
Eccezione del job: PG::UniqueViolation: ERRORE: valore chiave duplicato viola il vincolo di unicità "index_users_on_username"
DETTAGLIO: La chiave (username)=(ghazal1) esiste già.
Serve molto più contesto, qual è il backtrace, cosa c’è in env.
backtrace:
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/patches/db/pg.rb:69:in `async_exec_params'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/patches/db/pg.rb:69:in `exec_params'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/postgresql_adapter.rb:672:in `block (2 levels) in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/postgresql_adapter.rb:671:in `block in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract_adapter.rb:718:in `block (2 levels) in log'
/usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract_adapter.rb:717:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract_adapter.rb:708:in `log'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/postgresql_adapter.rb:670:in `exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/postgresql_adapter.rb:651:in `execute_and_clear'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:111:in `exec_delete'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract/database_statements.rb:174:in `update'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract/query_cache.rb:22:in `update'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation.rb:460:in `update_all'
/var/www/discourse/app/models/email_log.rb:25:in `block in <class:EmailLog>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:429:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:429:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:239:in `block in halting_and_conditional'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:518:in `block in invoke_after'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:518:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:518:in `invoke_after'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:136:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:827:in `_run_create_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/callbacks.rb:332:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/timestamp.rb:111:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/persistence.rb:906:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/callbacks.rb:328:in `block in create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:135:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:827:in `_run_save_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/callbacks.rb:328:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/timestamp.rb:129:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/persistence.rb:503:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/validations.rb:53:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/transactions.rb:319:in `block in save!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/transactions.rb:375:in `block in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract/database_statements.rb:281:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract/database_statements.rb:281:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/transactions.rb:366:in `with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/transactions.rb:319:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/suppressor.rb:48:in `save!'
/var/www/discourse/lib/email/sender.rb:217:in `send'
/var/www/discourse/app/jobs/regular/user_email.rb:60:in `execute'
/var/www/discourse/app/jobs/regular/critical_user_email.rb:15:in `execute'
/var/www/discourse/app/jobs/base.rb:232:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:63:in `with_connection'
/var/www/discourse/app/jobs/base.rb:221:in `block in perform'
/var/www/discourse/app/jobs/base.rb:217:in `each'
/var/www/discourse/app/jobs/base.rb:217:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:192:in `execute_job'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:165:in `block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:128:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:138:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:130:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:133:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:164:in `block in process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:137:in `block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:109:in `local'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:136:in `block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq.rb:37:in `block in <module:Sidekiq>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:132:in `block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:250:in `stats'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:127:in `block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/job_logger.rb:8:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:126:in `block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:74:in `global'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:125:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:48:in `with_context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:42:in `with_job_hash_context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:124:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:163:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:83:in `process_one'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:71:in `run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:16:in `watchdog'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:25:in `block in safe_thread'
ambiente:
hostname	talk-app
process_id	1581
application_version	a3157f0e38a2e4bed8af08ec3c8b0456840a7baa
current_db	default
current_hostname	talk.zabanshenas.com
job	Jobs::CriticalUserEmail
problem_db	default
time	1:30
opts
type	iscrizione
user_id	212749
email_token	22b8a53383a192d9f55753c11b2ed1ef
current_site_id	default
Non so se sia correlato o meno. Iscrivo gli utenti tramite API. Ottengo il nome utente dall’utente e verifico se esiste tramite API; se esiste, scelgo ciò che Discourse suggerisce. Tuttavia, molte volte il suggerimento è in realtà un nome utente reale di un utente che in qualche modo è rotto. Cioè, quando provo a visualizzare il loro profilo, ricevo una pagina di errore “non trovato”.
Comunque, ho segnalato questi utenti rotti qui:
