Webhooks: how best to differentiate a PM from a public post
The discussion revolves around differentiating private messages (PMs) from public posts in Discourse webhooks. johnaschroeder seeks a reliable method to filter PMs, noting that the reply_to_user field is inconsistent. simon suggests using the topic_id from the post webhook to query the topic’s archetype (e.g., private_message for PMs) via the topic webhook. codinghorror questions the need for topic_created events, as post_created with post_number = 1 indicates a new topic. tgxworld confirms the usefulness of including archetype and category_id in post webhooks and notes the current payload includes suggested_topics, which adds overhead. johnaschroeder considers calling the API to retrieve topic data as a workaround. surety agrees, highlighting the need for archetype in post webhooks for handling different post types, and codinghorror encourages a pull request, which surety submits to add the missing fields.
Hi All,
I’ve been scrutinizing the various JSON post results from our webhooks. We record and react to public posts that contribute to our common knowledge-base differently than PMs or discobot conversations. For example, it’s relatively easy to filter out posts from discobot using its userid; likewise with system posts and topics. However, I haven’t been able to identify a reliable way to filter posts back to discobot, or PMs between two users. At first I thought only PMs had a “reply_to_user” field, but it appears that some (but not all) posts have it also. Here is an example of what we are trying to filter out:
"post": {
    "id": 1296,
    "name": "Test User",
    "username": "testuser",
    "avatar_template": "/letter_avatar_proxy/v2/letter/c/stringhere/{size}.png",
    "created_at": "2017-12-14T21:11:30.992Z",
    "cooked": "\u003cp\u003e[quote=\"cutlery, post:11, topic:626\"]\u003cbr\u003eIf this is coffee, please bring me some tea; but if this is tea, please bring me some coffee\u003c/p\u003e",
    "post_number": 13,
    "post_type": 1,
    "updated_at": "2017-12-14T21:11:30.992Z",
    "reply_count": 0,
    "reply_to_post_number": 11,
    "quote_count": 1,
    "avg_time": null,
    "incoming_link_count": 0,
    "reads": 1,
    "score": 0,
    "yours": false,
    "topic_id": 626,
    "topic_slug": "robot-greetings",
    "topic_title": ":robot: Greetings!",
    "display_username": "Test User",
    "primary_group_name": null,
    "primary_group_flair_url": null,
    "primary_group_flair_bg_color": null,
    "primary_group_flair_color": null,
    "version": 1,
    "user_title": null,
    "reply_to_user": {
    "actions_summary": [{
        "id": 2,
        "can_act": true
        "id": 3,
        "can_act": true
        "id": 4,
        "can_act": true
        "id": 5,
        "hidden": true,
        "can_act": true
        "id": 6,
        "can_act": true
        "id": 7,
        "can_act": true
        "id": 8,
        "can_act": true
    "moderator": false,
    "admin": false,
    "staff": false,
    "user_id": 1234,
    "hidden": false,
    "hidden_reason_id": null,
    "trust_level": 0,
    "deleted_at": null,
    "user_deleted": false,
    "edit_reason": null,
    "can_view_edit_history": true,
    "wiki": false
It’s messy, but if you setup both a Post and a Topic webhook. When a message, or topic is first created, both hooks will be fired. You can use the topic_id that is sent with the Post webhook to get the topic archetype from the topic webhook data. It will be set to ‘private_message’ for messages, ‘regular’ for regular topics.
It would be great to get some topic data sent with the Post webhook - category_id and archetype would both be useful.
Thanks Simon, we’re also struggling with not getting consistent topic_created events. Instead we get post_created with post_number = 1 and no topic_created. We checked both our logs and API/webhooks - nothing. That changed today, which now leaves me at a loss. More here:
https://meta.discourse.org/t/webhooks-for-the-first-post-in-a-series-topic-or-post/76365
Why does it matter? post_created with post number 1 is definitely a new topic. What else could it be?
It didn’t, and we shrugged it off until we saw what we originally expected in the log today: topic_created and no post_created header with post_number = 1. Now we’ve seen both and I’m trying to understand why and what the expected behavior is. It matters because we missed an event that is one of the purposes of the webhook: record and reward users who create a new topic.
I see, @tgxworld can you comment on this please?
Yea those are definitely useful. Another thing that I noticed is that we’re sending the suggested_topics in the webhook payload. It adds quite abit of size to the payload and I don’t think alot of people are using that.
@tgxworld Based on Simon’s reply, is the best way to differentiate a PM to make a request back to the API at “topics/get a single topic by id” and pass the ID for every post? Then if the archetype comes back private_message we’ll filter it out, if it comes back “regular” we’ll use it. We seem to get either a post created with post_number = 1 or a topic_created with no post_created. We’ll check for both and that should cover our use cases.
Is there any documentation on the JSON fields, possible values, and meaning for topics, posts, and users? For example, are there other possible values for archetype? What does actions_summary signify with id=n? Alternatively, if you could point us to somewhere in the code base that builds the JSON objects passed in the webhooks that would be something. We poked around but couldn’t find the data itself, just the events and objects passed.
Any chance these might be topics that were moved or had ownership reassigned? Staged users?
I don’t think so. We have a very active group of veterinarians posting, but it’s very vanilla stuff. Topics and replies. To my knowledge no one has reassigned or moved a topic. We don’t stage users.
Мы столкнулись с похожей проблемой: в вебхуке сообщения отсутствует тип архетипа темы. Мы используем вебхук для создания тикетов в нашей системе поддержки, когда кто-то публикует публичный пост или отправляет нам личное сообщение. Проблема в том, что мы обрабатываем публичные посты и личные сообщения по-разному, поэтому нам нужно знать тип в обработчике вебхука.
Мы понимаем, что можно использовать API для обратного вызова и получения деталей темы, но это кажется излишней работой и накладными расходами, когда эта информация могла бы быть в полезной нагрузке события сообщения.
Есть ли шанс, что вы сможете это добавить? Вы были бы готовы рассмотреть запрос на включение (pull request), если мы его подготовим?
Pull-реквесты всегда приветствуются :wink:
PR отправлен. Добавлен архетип темы и слаг категории.
