Understanding infinite scrolling
:bookmark: This is an explanation of what “infinite scrolling” is and how it is implemented in Discourse.
:person_raising_hand: Required user level: All users
Infinite scrolling is a feature designed to improve the user experience by automatically loading more content as you scroll down a page, instead of requiring manual page navigation.
Summary
In this documentation, we’ll cover:
  • The concept of infinite scrolling.
  • How Discourse implements infinite scrolling.
  • Key advantages of infinite scrolling in Discourse.
What is infinite scrolling?
Infinite scrolling refers to the automatic loading of additional content as the user nears the bottom of a web page. This eliminates the need for pagination and provides a seamless browsing experience. As new content is loaded dynamically, users can keep scrolling without any interruptions.
Discourse uses HTML5’s History API to implement infinite scrolling efficiently. Here’s how it works:
  1. Address Bar Update: As you scroll, the browser’s address bar updates in real-time to reflect your reading position.
  2. Back/Forward Button Integration: Browser back and forward buttons work as expected, allowing users to navigate through the content seamlessly.
  3. Timeline Navigation: Discourse’s timeline tells you how far along you are and lets you jump to any point in the content.
  4. Efficient Content Loading: Only JSON (JavaScript Object Notation) calls are made to fetch new content. No elements need to be redrawn, resulting in minimal bandwidth usage while providing a smooth experience.
Best practices
To further enhance your experience with Discourse’s infinite scrolling:
  • Use the timeline for quick navigation and easy placement within the content.
  • Leverage browser back and forward buttons for efficient article navigation without losing your place.
Common issues and solutions
Issue: Browser lagging or hanging while scrolling
Solution: Ensure you have a stable internet connection. If the problem persists, try clearing your browser cache or disabling unnecessary browser extensions.
Issue: Content fails to load
Solution: Refresh the page or check if there are any disruptions in your internet connection. If the issue is not resolved, report it to the forum administrator.
Additional resources
