Wat is de beste/veiligste branch om de productiesite niet te breken?
The discussion revolves around choosing the safest branch for updating a Discourse production site without breaking it. CGenie asks about the best branch for stability, prompting a response from JammyDodger and others. Most users recommend the tests-passed branch for a balance of stability and updates, though some prefer stable for predictable, minor fixes and security patches merefield. The stable branch avoids major changes between versions, making it ideal for sites with customizations that may not be compatible with frequent updates. ljpp supports this, emphasizing that stable allows for better planning and testing. CGenie also clarifies that discourse_docker uses tests-passed by default, which is a reasonable choice for balancing new features and stability.
Maybe this is a silly question, but I haven’t found an answer: what should be the default branch for safe updates? I don’t want to break my production server by having some random failiures due to main branch issues? Should I just follow the latest tag? I.e. v3.2.0 currently?
Hello and welcome @CGenie :slight_smile:
I think the majority of people use the default tests-passed branch, though some will use beta or stable. There’s a bit more info on the differences in Configure a supported tracking branch to get Discourse software updates
Understanding Discourse release channels also explains the differences.
The answer, imho, is stable as it receives minor bug fixes and security patches without changing most of the code significantly, usually resulting in greater compatibility as you upgrade through each patch.
The downside is that moving a minor version increase to, say 3.3.0 (in the future) might involve more significant changes you will have to deal with in “one go” instead of as a drip feed. This can especially impact customisations, e.g. bespoke plugins, that were built with the prior minor version in mind, but not tested on the new 3.3.x series of beta releases.
On balance I’d suggest going stable if you don’t mind missing out on the very latest features.
Though I think even on tests-passed you’re in control of your own updates and can defer until you have time to check out any new features (possibly on a staging site if needed).
OK so another silly question: I use discourse_docker to deploy the server. It seems discourse is set up with main branch. How can I change that to tests-passed?
Aah, ok, version in containers/app.yml is by default on tests-passed. So I guess this is a sane config between stability and new features?
Word. And this is based on several years of experience in running a large-ish forum as self host. While beta or test-passed receives fixes and new features faster, the stable branch is predictable.
You know when major changes happen (version upgrades) and that in between versions the changes are minor. This way you can plan your own resources, prepare for some necessary testing effort, and potential breakage of your customizations (custom themes etc.).
