What sets suppress_welcome_message for SSO logins
So for some users login in via SSO they are getting the ‘welcome_message’ each time they login. I think that it has something to do with
https://github.com/discourse/discourse/blob/master/app/models/discourse_single_sign_on.rb#L70
What I can not figure out is what should be setting ‘suppress_welcome_message’ It is possible that I have something setup incorrectly about the accounts that is causing this but I can not see what controls the value of suppress_welcome_message
I believe this is passed to DiscourseAPI - so wherever that is being called, the query param suppress_welcome_message needs to be set to true. I’ll try to find a practical example for you.
「いいね!」 1
That’s actually a method call, I believe.
We can see here that it’s one of the SSO payload fields:
https://github.com/discourse/discourse/blob/master/lib/single_sign_on.rb
「いいね!」 4
Hmm ok have added that to my cas_sso implementation and set it as false. I will see what the effected user experience.
That said can you think of any reason that some people would keep getting the new user message and others would not?
