מאפיין `white-space` של נתוני ה-clipboard לא מכובד בעת הדבקה בעורך טקסט עשיר
סיכום מבוסס בינה מלאכותית
A bug report details how the Discourse rich text editor fails to respect the white-space: pre CSS property when pasting HTML-formatted clipboard content, causing whitespace collapse (e.g., turning multi-line text into a single line). The issue was reproducible using a test HTML file and confirmed in try.discourse.org with Chrome on Windows 11. The problem does not occur in Markdown editor mode or when pasting into code blocks. per1234 noted this affects users copying compiler output from Arduino Cloud Editor, where preserving line breaks is critical. renato proposed a fix in PR #35518 that respects line breaks as hard breaks instead of converting to code blocks, leveraging ProseMirror’s updated white-space: pre support. Additional issues were raised: (1) incidental Markdown/HTML syntax corruption (e.g., <iostream> stripped, __FILE__ rendered as bold), and (2) inappropriate HTML markup from Arduino IDE’s clipboard causing each line to become a separate code block. renato suggested escaping unsupported tags (e.g., rendering <iostream> as literal text) and proposed a Shift+Paste option to bypass Markdown parsing. The team acknowledges these edge cases but considers some outside Discourse’s scope, as they stem from source applications’ clipboard formatting.
Priority/Severity:
Medium
Platform:
Operating System
  • Windows 11
Browser
  • Google Chrome 139.0.7258.128
Discourse
028c90dd5e7a2799ea5b6e963f71fc0222681943
Description:
Text copied from some sources may be stored in the clipboard in a formatted form (text/html type) in addition to plaintext (text/plain).
When text is pasted into the composer, if a formatted data type is present in the clipboard then this data is used instead of the plaintext type.
By default, whitespace in HTML content is collapsed. This behavior can be controlled via the white-space CSS property.
:bug: When pasting in the composer when in “rich text editor” mode, the white-space CSS property of the clipboard data is not respected. This results in whitespace always being collapsed in the pasted content. In cases where the source content had a white-space property set to the pre value, this results in the pasted content being difficult to read, and incorrect in cases where the whitespace of the source content had technical significance.
Reproducible steps:
  1. Create an HTML file with the following content:
    <html>
      <body>
        <span style="white-space: pre">foo
    bar
        </span>
      </body>
    </html>
  2. Open the file in your web browser.
    Note that the whitespace of the page content is not collapsed:
    foo
    bar
  3. Copy the content of the web page.
  4. Open the post composer.
  5. Put the composer into the “rich text editor” mode.
  6. Paste the copied content.
:bug: Instead of having the same format as the copied content, the whitespace of the pasted content was collapsed:
foo bar
Additional context:
I see that ProseMirror does support white-space: pre:
The fault does not occur when using the composer in the “Markdown editor” mode.
The fault does not occur if the content is pasted into a code block instead of into the normal editor mode. It is true that in many cases it would be most appropriate to place the content that uses something like white-space: pre in a code block. However, it is fairly common for users to apply formatting retroactively by adding the content to the composer, selecting the content, then using the composer toolbar to apply the formatting (as opposed to the alternative approach of triggering a codeblock prior to adding the content).
I found this to be a useful tool for examining the raw data of the clipboard content:
I am able to reproduce the fault on try.discourse.org in “safe mode”.
Related
2 לייקים
Did you put the post composer into “rich text editor” mode before you pasted the content copied from the web page?
The fault still occurs.
Are you sure you followed the instructions exactly as written?
Please note that you must copy the content that is rendered from that HTML, so that the clipboard content is populated with text/html type data:
<html>
<body>
<!--StartFragment--><span style="color: rgb(0, 0, 0); font-family: &quot;Times New Roman&quot;; font-size: medium; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; white-space: pre; text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial; display: inline !important; float: none;">foo
bar
    </span><!--EndFragment-->
</body>
</html>
This is not about composing your post using HTML markup.
Ah good catch. I have a tendency to skim the post a bit too fast :sweat_smile:
לייק 1
תודה על הדיווח @per1234, אנחנו בודקים את זה.
אנו מבינים את הבעיה הכללית כאן, אנו רוצים להקל ככל האפשר על אנשים להדביק דוגמאות קוד.
2 לייקים
What would you expect from such an HTML clipboard?
foo
bar
Or, considering it’s a span tag, two inline code lines with a hard break between?
foo
bar
Or just that we respect the line breaks but in a regular paragraph, with a hard break between?
foo
bar
Thank you!
I’m not very knowledgeable in the subject of HTML, but I would expect this rendering:
From what I can tell, this is how Chrome browser renders it.
That said, in the specific use in which I encountered the problem, it is true that the code block rendering would be most appropriate. We get this type of clipboard content by clicking the “Copy Console Output” button in an online IDE named “Arduino Cloud Editor”:
This copies the output produced by the compiler and other tooling to the clipboard. This type of non-prose content is best formatted as a code block.
If the following procedure is used to share that copied output in a forum post:
  1. Put post composer into “rich text editor” mode.
  2. Paste the content into the composer.
  3. Select the pasted content.
  4. Click the </> icon on the composer toolbar.
The post ends up with the following formatting:
/run/arduino/sketches/asdf/asdf.ino:1:2: error: #error foo  #error foo   ^~~~~
(note that all the copied content is on a single line)
whereas we would expect this post formatting:
 #error foo
However, this preference for a code block is specific to our particular use case. It might be that in other use cases there are sources of clipboard content with a white-space: pre property for which a code block would not be appropriate. And even for our use case it is reasonable to put the responsibility of manually applying code block formatting on the user.
לייק 1
In this case, does it still use a span tag in its text/html clipboard output, or does it only output plain/text?
If I use the “Clipboard Inspector” tool to check what data is in my clipboard after I click that “Copy Console Output” button in Arduino Cloud Editor, it shows it contains the following “text/plain” type data:
 #error foo
as well as the following “text/html” type data:
<span style="color: rgb(0, 0, 0); font-family: &quot;Open Sans&quot;, &quot;Lucida Grande&quot;, lucida, verdana, sans-serif; font-size: 16px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: 0.16px; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; white-space: pre; text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial; display: inline !important; float: none;">/run/arduino/sketches/asdf/asdf.ino:1:2: error: #error foo
 #error foo
  ^~~~~</span>
I hope that answers your question. I’m happy to provide additional information if needed.
This should be fixed by FIX: [rich editor] convert newlines to hard breaks when parsed from HTML by renato · Pull Request #35518 · discourse/discourse · GitHub (not merged yet, it’s waiting a code review).
My first take was to convert it to a code block, but I think that would be too eager and cause some false positives. Instead, we just respect line breaks converting them to hard breaks within the context the HTML was pasted. (Thanks to Marijn’s improvement to prosemirror-model: When preserving whitespace, replace newlines with line break replacem… · ProseMirror/prosemirror-model@79e9f2b · GitHub)
With the recent improvements to the code toolbar button, users should be able to select this pasted section with the hard breaks and convert it to a code block, and the newlines should be carried over.
2 לייקים
Thanks so much for the fix @renato, and for taking the time to post an update here!
The recent bug fixes have brought the rich text editor’s functionality to the point where it can serve to make our forum more approachable to less technical users who aren’t already familiar with Markdown and not motivated to learn it.
There still are a couple of conditions under which the results are not expected, but these are things that are not reasonable to mitigate via the Discourse codebase:
Corruption due to incidental markup syntax
Posts may be corrupted in the case where there is content that incidentally resembles markup. This is due to the intentional decision to support markup in the rich text editor.
For our use case where those who wish to use markup are expected to use the Markdown editor, while the rich text editor is intended only for use by those with no interest in using markup, this is a very unfortunate decision. One of the most significant problems we have with non-technical users using the Markdown editor is post corruption due to incidental markup and I had great hopes that the rich text editor would provide a solution for that. However, for the use case where a forum will only provide a rich text editor, this design makes perfect sense as it still allows users fluent in Markdown to efficiently compose posts.
Incorrect formatting due to inappropriate markup in clipboard content
We have a case where the “text/html” type content added to the clipboard when copying from a specific application has inappropriate HTML markup, which results in incorrect formatting when the content is pasted into the rich text editor outside a code block.
This is of course a bug in the application and Discourse is acting 100% correctly by formatting the content as indicated by the markup.
לייק 1
Thanks heaps @per1234
Can you expand a bit on examples where corruption can occur? We still have a few edge cases around nodes that we do not know how to render, but we try to ban switching to the rich editor in cases like this.
Regarding clipboard, we certainly want to improve. It is is a tough problem any exact repros here would be very helpful.
Sure. I’m glad if the information can be useful. I would like to reiterate my previous statement:
However, I’d be happy to be wrong about that :slightly_smiling_face:.
  1. Copy the following C++ code:
    #include <iostream>
    int main() {
      std::cout << __FILE__;
  2. Open the post composer.
  3. Put the composer into the “rich text editor” mode.
  4. Paste the copied content into the composer.
:slightly_frowning_face: The content is corrupted:
#include
int main() {
std::cout << FILE;
(note that the <iostream> has been suppressed due to resembling an unsupported HTML tag, and the __FILE__ has been treated as bold markup)
This could be seen as user error, since it could be avoided by triggering a code block prior to pasting the non-prose content. However, we might expect that the alternative workflow of applying code block formatting retroactively to pasted content would be equally valid (as it is when using the Markdown editor).
Equipment
  • Any Arduino board (whether official or 3rd party)
Instructions
  1. Install Arduino IDE 2.3.6, which can be downloaded from the “Software” page of the Arduino website:
    https://www.arduino.cc/en/software/#ide-download-section
  2. Start Arduino IDE.
  3. Select File > New Sketch from the Arduino IDE menus.
  4. Replace the content of the new sketch with the following code:
    void setup() {
      Serial.begin(9600);
      while (!Serial) {}  // Wait for serial port to be opened.
      delay(500);         // Some boards require a delay after serial port initialization.
      Serial.println("foo");
      Serial.println("bar");
    void loop() {}
  5. Select Tools > Serial Monitor from the Arduino IDE menus to open the Serial Monitor view, if it is not already open.
  6. Select “9600” from the baud rate menu in the Serial Monitor view.
  7. Upload the sketch to your Arduino board.
  8. Select the serial output from the field in the Serial Monitor view.
  9. Copy the selected content.
  10. Open the Discourse post composer.
  11. Put the composer into the “rich text editor” mode.
  12. Paste the copied content into the composer.
:slightly_frowning_face: Each line of the copied content is placed in a separate code block:
foo
bar
If you inspect the clipboard content, you will see that, in addition to the expected “text/plain” type content:
foo
bar
It also contains the following “text/html” type content:
<div style="color: rgb(78, 91, 97); font-family: monospace; font-size: 13px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; white-space: nowrap; background-color: rgb(255, 255, 255); text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial; position: absolute; left: 0px; top: 0px; height: 18px; width: 1862px;"><pre style="margin: 0px;">foo
</pre></div><div style="color: rgb(78, 91, 97); font-family: monospace; font-size: 13px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; white-space: nowrap; background-color: rgb(255, 255, 255); text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial; position: absolute; left: 0px; top: 18px; height: 18px; width: 1862px;"><pre style="margin: 0px;">bar</pre></div>
Since the Arduino IDE 2.x Serial Monitor incorrectly wraps each line of the “text/html” type copied content in <pre> tags, the rendering of each line of the pasted content as a separate code block by the Discourse rich text editor is correct and expected.
As with the other problem I described above, the unexpected formatting can be avoided by proactively triggering code block formatting prior to pasting the content.
2 לייקים
We parse pasted plain/text as Markdown, which is expected and not doing it would be a worse experience IMO, but any practical suggestions are welcome. Maybe supporting the SHIFT modifier as a “paste without parsing as Markdown” could help?
This can be changed, one possibility we have is to escape it to <iostream> instead of stripping.
I believe the other point you raised isn’t actionable as you mentioned.
Is there anything else that you still struggle with related to this topic?
This topic was automatically closed after 64 days. New replies are no longer allowed.
