Why are my avatar thumbnails so low res?
Hi!
This is the way my avatar thumbnails look.
Yet on everything else they look like the original res.
What is causing this? I didn’t do anything to the compression, and avatars display perfectly fine everywhere else.
You need Avatar Size and Shape when using non-standard avatar sizes.
Thanks, how do I include pre configured components with themes? I know it’s possible
In the component settings you will find this setting Include component on these themes where you can select your main theme(s)
Ohh I mean something else, how cna I include it with themes?
