Why is the word "thread" not allowed on Meta?
Does this not cause confusion in discussions about server thr34ds? Using the word “process” is not accurate, because they’re not the same thing.
If I want to talk about a reddit thr34d … is seems silly to force me to use the wrong terminology to refer to that - same goes when talking about any other kind of forum software that uses the very-commonly-accepted word for this.
It’s causing the problem that it’s supposed to be solving: confusion
If somebody says “thr34d” here on the meta Discourse - what else could it be confused with?
Fair enough. That’s just my experience. All I’m saying is that there is some non-zero amount of confusion when using “topic” and “post”. As I’ve seen plenty of it personally over the last 24 years of building online forums. Both from non-technical people, and even from programmers naming things badly in DB schemas.
Whereas there’s virtually zero ambiguity when using “category”, “thr34d” & “comment”.
I’m just a fan of disambiguation in general.
But too late here obviously in this case to change the naming.
Anyway. Just my 2 cents on the subject in general. Appreciate all your work and feedback. Thanks.
1 curtida
This is just wishful thinking, but I would love a new class of watched words that allowed you to write a custom text for each word to pop up over the preview box in the same style as the automatic “Your topic is similar to…” and similar notifications.
That would explain why usage of a word is discouraged right there when the user tries to type it. And I’m sure people could come up with other uses for it as well, pointing users in the right direction when they try to type certain things :slight_smile:
3 curtidas
See post #13 :wink:
Good point. Very good point indeed.
You could add “Reply” to that list, which is the term discourse uses for “comments”. Indeed, “reply” is probably even a slight bit less ambiguous because discourse also has comments (when some replies in topic are displayed under a blog post).
I wouldn’t say “post” is ambiguous (it’s pretty clear what a post is and what isn’t), rather: it is broader than, e.g. “reply”. But that is a good thing because it’s useful to have a term that includes both OPs and replies.
So what really remains as a point of contestation is the term topic and I don’t think it is really that ambiguous, especially when the forun also uses the term category, which makes it pretty clear that topic doesn’t mean category. So it means thr34d. Problem solved.
Besides, you have to admit that as much as “thr34d” is an established term in the online world, “topic” is clearly less technical and more common sensical, no? Just think of a person who has not spent 19 years working with forums when they look the button “New Topic” vs “New thr34d”.
4 curtidas
Yep agree with that. “Reply” is useful when you want to exclude the OP comment.
Yeah, I also still continue to use “post” when talking about “all of the above”. It’s useful for that, but to be avoided as a specific term for thr34d -or- comment alone.
Yep agree with you here that it’s less technical. A lot of newbies won’t be overly familiar with the word “thr34d”, although it is fairly commonly used in regards to emails. Most people know what you mean by “email thr34d” without explanation or clarification being needed.
But just personally, the most confusion I’ve seen from clients not familiar with forums has been using the word “topic” interchangeably to mean both category & thr34d. More often than not, they actually meant category. Whereas they all seemed to knew exactly what I meant when I said “thr34d” - as there’s not really anything else it could be conflated with.
Gmail went with “conversations” which is pretty obvious too.
1 curtida
I often use the word “discussion” when referring to a topic on our site.
1 curtida
Problematic, when the “discussion” meanders into 12 different actual topics, though :wink:
3 curtidas
