window.addEventListener('load', functionName) no funciona correctamente
Hello.
I am making a simple script that add some function when the window loads.
window.addEventListener('load', functionName);
But it’s not working properly.
In Chrome it’s working, but in Firefox, IE and Safari don’t work or working sometimes.
Any kind of help will be appreciated. Thanks in front.
This is my full code.
assets/javascripts/discourse/initializers/startup.js.es6
export default {
	initialize() {
		console.log('Initialize function emitted...');
		var tmc, $cookNum, $toUse, $timeNum, $firstTime, $secondTime, $reCAPTCHA, currentURL
		tmc = null;
		currentURL = ''
		$firstTime = ''
		$secondTime = ''
		$reCAPTCHA = ''
		//firebase settings
		var token = '6BGQlWcn1TRf5hUHIvQb4zMr6DR2';
		function treatCode()
			console.log('Treat code function emitted...');
			fetch(url to get ip address(working)')
			.then((json) =>
				json.json().then((response2) =>
					var userIP = response2.query;
					findByKey(userIP.replace(/\./g, "-"), function(result)
						if(!result || result.error){
							$cookNum = 1
							$toUse = 1
							$timeNum = $firstTime
						} else {
							$cookNum = parseInt(result.visit)+1
							$toUse = parseInt(result.toUse)
							$timeNum = parseInt(result.timeNum)
						//Update cookie numers
						updateByKey(userIP.replace(/\./g, "-"), { visit: $cookNum, 'toUse': $toUse, 'timeNum': $timeNum }, function (result) {
						if($cookNum >= $timeNum && $reCAPTCHA.length > 0)
							// Trigger reCAPTCHAv2
							document.body.innerHTML = '\
							<div style="margin-left: 40%; margin-top: 13%;">\
								<div style="width: 218px; height: 80px; background-color: skyblue;">\
									<img src="" alt="Logo goes here 218x80" style="height:80px; width:218px;">\
								</div>\
								<div class="g-recaptcha" data-sitekey="'+ $reCAPTCHA + '"></div>\
								<div><a href="https://www.google.com/recaptcha/intro/android.html">Click here</a> To learn why you get this all the time.</div>\
							</div>\
							var reCAPT = document.createElement('script');
							reCAPT.src = 'https://www.google.com/recaptcha/api.js'
							reCAPT.type = 'text/javaScript'
							reCAPT.async = true
							reCAPT.defer = true
							document.body.appendChild(reCAPT);
							tmc = setInterval(function () {
								if (typeof grecaptcha !== 'undefined') {
									if (grecaptcha.getResponse().length > 0) {
										$toUse = 1 - $toUse;
										$cookNum = 0;
										$timeNum = $timeNum == $firstTime ? $secondTime : $firstTime;
											location.reload();
							}, 1000);
						} else {
							if (tmc != null){
								clearInterval(tmc);
								tmc = null;
		function startWork () {
			console.log('start work emitted..');
			$firstTime = this.Discourse.SiteSettings.discourse_captcha_first_max_visit_time;
			$secondTime = this.Discourse.SiteSettings.discourse_captcha_second_max_visit_time;
			$reCAPTCHA = this.Discourse.SiteSettings.discourse_captcha_site_key;
			loadUp();
		function loadUp()
			console.log('load up set interval emitted...');
			setInterval(function(){
				if(document.URL != currentURL)
					treatCode();
					currentURL = document.URL;
			}, 500);
		window.addEventListener('load', startWork);
		var findByKey = (key, callback) => {fetch('url to firebase realtime database(and it's working))
			.then(function(response){
				response.json().then(function(response2){
					callback(response2)
		var updateByKey = (key, values, callback) =>
			fetch(url to firebase realtime database(and it's working),
				'headers'	: { 'content-type': 'application/json' },
				'method' 	: 'PUT',
				'body' 		: JSON.stringify(values)
			}).then(function(response){
					callback(response2)
If you like to call some JavaScript whenever a user navigated in Discourse then you can use onPageChange method.
