I’m trying to configure my wordpress to be a sso client to my discourse.
Everything seems to be configured as the howto states but when I try to ‘login with discourse’, if the user doesn’t exist it gets created, and it returns failed login ‘Expired nonce’
thanks @simon I must admit that’s 1 file i’ve not checked yet!
I completely deleted the multisite install, and installed a fresh single site WP. I’ll see if there are any traces of the multi install in the .htaccess.
Thanks! That gives some idea of where the error is happening.
I went through the password reset process and can now access my account on your WordPress site. When I click on the WordPress password reset email that you site is sending out, I get a ‘connection refused’ error and can only access the site by enabling a VPN. Possibly that has something to do with the problem.
tried to bypass the firewall settings and whilst it did kick in, i reset the rules and still got an Expired Nonce whilst trying to connect to Discourse.
The password reset was successful but the link to discourse returned the same with nothing showing up in the iptables output, so the IPs weren’t getting blocked.
The problem seems to be that CURRENT_TIMESTAMP isn’t a valid default value for mysql < 5.6.5, hence the nonce table can’t be created (if you looks into logs, you’ll find „invalid value for added_on…).
Yup, need to upgrade. Probably there is a way of making this backwards compatible, but considering that 5.6 was released in 2012 i think this would be kind of useless.
