pfaffman
(Jay Pfaffman)
1
I just configured (by clicking the checkbox) Yahoo login for a customer and they got a white box. I did too.
I checked on https://try.discourse.org/ and had the same problem.
This is a different problem from Yahoo login doesn't seem to work - #22 by italophile.
إعجاب واحد (1)
Yahoo has a lot of availability issues, though, so make sure it’s not that. It works fine for me on try:
I just logged in fine to try.
إعجاب واحد (1)
8BIT
3
ah, was interested in this as well. will give it a go…!
إعجاب واحد (1)
pfaffman
(Jay Pfaffman)
4
Very. Very. Strange. Now I get
For the record, I got past the screen in your screen shot and after I’d logged in to Yahoo got the blank screen.
I think my solution will be to recommend that folks not use the Yahoo login.
إعجاب واحد (1)
The root cause of this problem (502 from nginx) has been identified and a fix is underway:
4 إعجابات
