Youtube embed doesn't work
Hi All,
Youtube embedding has stopped working for me, when you paste the youtube link, it shows in the preview, then when you click post it instantly disappears. What do I need to do to help analyse the issue? I can get you logs or whatever, I just don’t know where to look.
Thanks
Gav
Here’s a checklist :wink:
  • Are you on latest? If not, upgrade
  • Are you running any non-standard plugins? If yes, disable them and rebuild the docker container
  • Are there any errors that might be related in /logs? If yes, paste all the info & backtraces here
  • Has sidekiq too much work in the backlog? If yes, just wait…
1.I was on latest
2.I have only got 2 non standard plugins, so I am doing that now
3.I will run through errors after point 2
4.I don’t think so, its quite a well resourced box just for discourse and its been happening since thursday but I was at a gaming expo in the UK
Rebuild fixed it, thanks once again zogstrip. I will forever been in your debt.
