This is an SQL version of the Dashboard Report for Consolidated Pageviews with Browser Detection.
This Data Explorer report provides a view of daily site pageviews with browser detection over a specified date range. The pageviews are categorized into four types:
- Logged In Browser
- Anonymous Browser
- Known Crawler
- Other pageviews
-- [params]
-- date :start_date
-- date :end_date
SELECT
ar.date::date AS "date",
SUM(CASE WHEN ar.req_type = 15 THEN count ELSE 0 END) AS "Logged In Browser",
SUM(CASE WHEN ar.req_type = 13 THEN count ELSE 0 END) AS "Anonymous Browser",
SUM(CASE WHEN ar.req_type = 6 THEN count ELSE 0 END) AS "Known Crawler",
SUM(
CASE WHEN ar.req_type = 8 THEN count
WHEN ar.req_type = 7 THEN count
WHEN ar.req_type = 13 THEN -count
WHEN ar.req_type = 15 THEN -count
ELSE 0
END
) AS "Other pageviews"
FROM
application_requests ar
WHERE
ar.date::date >= :start_date
AND ar.date <= :end_date
GROUP BY
ar.date
ORDER BY
ar.date ASC
SQL Query Explanation
- Parameters:
:start_date- The start date for the report.:end_date- The end date for the report.- Both date parameters accept the date format of
YYYY-MM-DD.
- SELECT Clause:
ar.date::date AS "date": Converts thedatefield to a date type and labels it as âdateâ.SUM(CASE WHEN ar.req_type = 15 THEN count ELSE 0 END) AS "Logged In Browser": Sums up the counts wherereq_typeis 15, labeling the result as âLogged In Browserâ.SUM(CASE WHEN ar.req_type = 13 THEN count ELSE 0 END) AS "Anonymous Browser": Sums up the counts wherereq_typeis 13, labeling the result as âAnonymous Browserâ.SUM(CASE WHEN ar.req_type = 6 THEN count ELSE 0 END) AS "Known Crawler": Sums up the counts wherereq_typeis 6, labeling the result as âKnown Crawlerâ.SUM(CASE WHEN ar.req_type = 8 THEN count WHEN ar.req_type = 7 THEN count WHEN ar.req_type = 13 THEN -count WHEN ar.req_type = 15 THEN -count ELSE 0 END) AS "Other pageviews": Sums up the counts for other types of requests, adjusting the counts forreq_type13 and 15 by subtracting them, and labels the result as âOther pageviewsâ.
- FROM Clause:
FROM application_requests ar: Specifies theapplication_requeststable as the source of the data, aliasing it asar.
- WHERE Clause:
ar.date::date >= :start_date AND ar.date <= :end_date: Filters the records to include only those where thedatefalls within the specified:start_dateand:end_daterange.
- GROUP BY Clause:
GROUP BY ar.date: Groups the results by thedatefield to aggregate the counts for each day.
- ORDER BY Clause:
ORDER BY ar.date ASC: Orders the results in ascending order by thedatefield.
Results
The results of this query will provide a daily breakdown of pageviews categorized by the type of browser or crawler. Each row in the result set will contain:
date: The specific date.Logged In Browser: The total count of pageviews from logged-in users.Anonymous Browser: The total count of pageviews from anonymous users.Known Crawler: The total count of pageviews from known crawlers.Other pageviews: The total count of other types of pageviews.
Example Results
| date | Logged In Browser | Anonymous Browser | Known Crawler | Other pageviews |
| 2024-05-02 | 1238 | 1085 | 2727 | 3983 |
| 2024-05-03 | 1039 | 1068 | 5718 | 3958 |
| 2024-05-04 | 572 | 628 | 3847 | 3761 |
| 2024-05-05 | 447 | 551 | 2093 | 3773 |
