This is an SQL version of the Dashboard Report for Consolidated Pageviews.
This SQL report provides a daily count of pageviews from logged in users, anonymous users, and crawlers on a Discourse site.
-- [params]
-- date :start_date
-- date :end_date
SELECT
    ar.date::date AS "date",
    SUM(ar.count) AS "Total Views",
    SUM(CASE WHEN ar.req_type=6 THEN ar.count ELSE 0 END) AS "Crawler Views",
    SUM(CASE WHEN ar.req_type=7 THEN ar.count ELSE 0 END) AS "Logged in User Views",
    SUM(CASE WHEN ar.req_type=8 THEN ar.count ELSE 0 END) AS "Anonymous User Views"
FROM application_requests ar
WHERE req_type IN (6,7,8)
    AND ar.date::date BETWEEN :start_date AND :end_date
GROUP BY date
ORDER BY date
SQL Query Explanation
The query operates on the application_requests table, which logs various types of requests made to the forum. It focuses on three specific types of requests identified by req_type values:
6: Crawler Views7: Logged in User Views8: Anonymous User Views
Here’s a step-by-step explanation of what the query does:
- Parameters: The query accepts two parameters,
:start_dateand:end_date, allowing the user to specify the date range for the report. Both date parameters accept the date format ofYYYY-MM-DD. - Selection: The query selects the date of the request (
ar.date) and casts it to adatetype. It also calculates the total views and the breakdown of views by type (crawler, logged-in user, and anonymous user) for each date within the specified range. - Summation: It sums up the
countcolumn for each type of view. TheCASEstatements are used to conditionally include counts in the sum based on thereq_type. - Filtering: The
WHEREclause filters the records to include only those withreq_typevalues of 6, 7, or 8 and with dates falling between the specified:start_dateand:end_date. - Grouping: The query groups the results by date, ensuring that the counts for each type of view are aggregated per day.
 - Ordering: The results are ordered by date to provide a chronological view of the traffic.
Example Results
| date | Total Views | Crawler Views | Logged in User Views | Anonymous User Views |
| 2023-11-18 | 5608 | 3052 | 565 | 1928 |
| 2023-11-19 | 9207 | 6564 | 470 | 2273 |
| 2023-11-20 | 6271 | 2631 | 1016 | 2924 |
