Discourse-reactions Github not found
I searched and couldn’t exactly find this issue, even after looking at other similar issues.
I wanted to enable discourse-reactions on my instance. After following the usual procedure and adding the repo URL to my app.yml, running git pull and ./launcher rebuild app, the bootstrap fails.
Following is the failure output:
FAILED
Pups::ExecError: cd /var/www/discourse/plugins && https://github.com/discourse/discourse-reactions.git failed with return #<Process::Status: pid 289 exit 127>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home/plugins", "cmd"=>["mkdir -p plugins", "git clone https://github.com/discourse/docker_manager.git", "git clone https://github.com/davidtaylorhq/discourse-whos-online.git", "git clone https://github.com/discourse/discourse-push-notifications.git", "git clone https://github.com/iunctis/discourse-formatting-toolbar.git", "git clone https://github.com/jannolii/discourse-topic-trade-buttons.git", "git clone https://github.com/discourse/discourse-voting.git", "git clone https://github.com/discourse/discourse-yearly-review.git", "https://github.com/discourse/discourse-reactions.git"]}
bootstrap failed with exit code 127
I scrolled up and the only error I found above that was this:
I, [2024-05-03T16:25:41.537553 #1]  INFO -- :
I, [2024-05-03T16:25:41.538494 #1]  INFO -- : > cd /var/www/discourse/plugins && https://github.com/discourse/discourse-reactions.git
sh: 1: https://github.com/discourse/discourse-reactions.git: not found
This seems odd since the Github page is easily viewable in a web browser. After commenting out the discourse-reactions, everything builds fine.
Any recommendations or tips for getting this working?
Cheers.
Edit: I tried rebuilding again and now see the following error:
2024-05-03 16:53:54.491 UTC [35] LOG:  database system is ready to accept connections
I, [2024-05-03T16:53:59.443099 #1]  INFO -- :
I, [2024-05-03T16:53:59.443248 #1]  INFO -- : > /usr/local/bin/create_db
2024-05-03 16:53:59.519 UTC [54] postgres@postgres ERROR:  database "discourse" already exists
2024-05-03 16:53:59.519 UTC [54] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
2024-05-03 16:53:59.595 UTC [57] postgres@discourse ERROR:  role "discourse" already exists
2024-05-03 16:53:59.595 UTC [57] postgres@discourse STATEMENT:  create user discourse;
NOTICE:  extension "hstore" already exists, skipping
NOTICE:  extension "pg_trgm" already exists, skipping
NOTICE:  extension "vector" already exists, skipping
Hello, welcome back :wave:
You miss a git clone before the URL, it would seem.
You should add the following:
- git clone https://github.com/discourse/discourse-reactions
For example, see the last line:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-knowledge-explorer
Thanks for the super quick reply and for the welcome!
You were absolutely correct. I had forgotten to include - git clone before the Github URL. I ran the build again and it completed the bootstrap without problems.
Thanks again.
