Enabling "popular links" in topic details/ metadata
Hi folks! I couldn’t find by searching this community so hopefully I can get the answer here :slight_smile:
I’m looking to display the “popular links” that are autopopulated before the first post when a link is added to the topic thread, but I can’t seem to find the admin setting to enable this.
What I want the topic page to look like:
Welcome to Meta :wave:
I don’t think there is a setting to enable or disable the link section of the topic map.
I think the links are added when the click count isn’t 0, so after someone has clicked them. For example, right now this topic doesn’t have a link count, but after you (or someone else) click(s) here, there will be one link in the topic map.
Thanks Moin! What I was missing was the requirement to actually click on the links - really appreciate the advice! :slight_smile:
