How to create local Discourse with only http (no https)?
I’m trying to install discourse on my laptop to do some tests before making changes on my real version. (writing scripts that will run on the real docker instance)
My laptop has no domain name, so I can’t get a let’s encrypt SSL certificate.
How does one go about installing a http only instance?
I comment out SSL lines in app.yaml and try to bypass ssl in ./discourse-setup --skip-connection-test but the bootstrap fails:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3649 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
This is not suitable for a local install. The standard install is meant for cloud deployment.
Use a dev-install
It should be possible somehow as I have an install running on localhost on my desktop computer, but can’t remember how I did it.
I’m trying to get it done on my laptop before I go on a trip.
I see no value in wasting time here. Go the well trodden path and use a Dev install. There’s even a docker one!
I managed to get this working. In the YAML file comment out lines relating to port 443 and Let’s encrypt. Then use ./discourse-setup --skip-connection-test
I set it up with localhost as the hostname and it worked. I think last time, it didn’t work because I forgot to comment out the Let’s encrypt lines.
