תעודת SSL פגה ובעקבות כך - שגיאה 404 לא נמצא
Hello.
The paid SSL certificate has expired on the site and I uploaded a new one, but it did not work. I started trying to install the certificate according to tutorials Set up HTTPS support with Let’s Encrypt and Allow SSL / HTTPS for your Discourse Docker setup. After that, the site got a 404 Not Found error.
The site on discourse is in docker, there are two more sites on the server without docker.
Information from the file containers/app.yml:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
#expose:
# - "80:80"   # http
# - "443:443" # https
params:
  db_shared_buffers: "4096MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 8
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: domain.cc
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'domain@gmail.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: vmi358514.contaboserver.net
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: noreply@domain.cc
  DISCOURSE_SMTP_PASSWORD: "REDACTED"
  DISCOURSE_SMTP_ENABLE_START_TLS: true
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
 # LETSENCRYPT_ACCOUNT_EMAIL: di@gmail.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  DISCOURSE_USE_S3: true
  DISCOURSE_S3_REGION: eu-west-1
  DISCOURSE_S3_ACCESS_KEY_ID:
  DISCOURSE_S3_SECRET_ACCESS_KEY:
  DISCOURSE_S3_CDN_URL:
  DISCOURSE_S3_BUCKET:
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_assets_precompile:
    - exec:
        cd: $home
        cmd:
          - sudo -E -u discourse bundle exec rake s3:upload_assets
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-sitemap.git
run:
Command ./launcher logs app not displayed errors ssl. As I understand it, the ssl certificate works and the error is different. Help me please.
First step, set Cloudflare to “DNS only” in order to be able to troubleshoot better.
For all recodrs? Set for all now
