Generate User API Keys for testing
Continuing the discussion from User API keys specification:
I created a small utility script in order to test User API keys locally.
First install dependencies:
gem install addressable openssl base64 json
Then the script is here:
require 'addressable'
require 'openssl'
require 'base64'
require 'json'
PRIVATE_KEY = OpenSSL::PKey::RSA.new(2048)
PUBLIC_KEY = PRIVATE_KEY.public_key
puts 'What is the target site?'
site = STDIN.gets.chomp
template = Addressable::Template.new("#{site}/user-api-key/new{?query*}")
url = template.expand({
  query: {
    application_name: 'ruby',
    client_id: `hostname`,
    scopes: 'read',
    public_key: PUBLIC_KEY,
    nonce: 1
puts "navigate to #{url}."
puts
puts "copy the generated key in here"
puts
puts "press ENTER type end and press ENTER again"
puts
$/ = "end"
encoded_key = STDIN.gets.chomp
user_api_key = JSON.parse(PRIVATE_KEY.private_decrypt(Base64.decode64(encoded_key)))
puts "Your User API Key is #{user_api_key['key']}"
