Moving conversations from chat to topics
The discussion centers on improving the transition of conversations from Discourse Chat to Forum Topics, addressing current limitations and proposing new features.
Current Workarounds and Limitations
Users frequently encounter valuable discussions in chat that are lost or lack SEO value once the chat dies off. The primary current method is using the “Quote in Topic” feature to create a new topic with quoted chat messages. However, users like dodesz and MerryMinstrel find this insufficient because:
  1. Attribution: Quotes do not retain the original author’s identity, making it unclear who said what.
  2. Readability: Long transcripts create unwieldy original posts.
  3. Engagement: Quoting feels like an “archive” rather than a living discussion, often causing users to disengage or continue the conversation in the chat stream instead.
  4. Manual Effort: Converting messages into individual, attributed posts requires tedious manual editing, changing ownership, and deleting original chat messages, which moderators describe as “purgatory” (Jagster).
Proposed Features
Several users advocate for a “Convert to Topic” or “Move to Topic” feature that would:
  • Automatically convert selected chat messages into individual posts within a topic.
  • Preserve original author attribution and reply chains.
  • Allow bulk selection and conversion of chat threads.
  • Optionally close the chat thread or add a redirect message (ludwikc).
Staff Response and Future Plans
Sam Saffron notes that mapping chat messages to posts is expensive and can result in noisy topics, recommending quoting or AI-generated summaries as alternatives. However, mcwumbly and merefield highlight the strong community need for this feature to improve SEO and user experience. mcwumbly commits to prioritizing the improvement of quote attribution so that quoted chat messages correctly attribute to the original author, similar to quoted posts. Other suggestions include AI summarization of chat transcripts (Mevo) and automatic rolling archives of channels to topics (Hanon_Ondricek).
When a conversation that starts in chat is worth continuing in a topic, what are the best ways to go about doing that currently?
What could be done to make it easier for people to make that transition more naturally when it feels like the right thing to do?
@Don wonders if converting messages to posts as an option would be better in some cases, and I shared some ideas for how to go about doing this today with chat transcripts using the “quote in topic” feature that exists today, while authoring a new post to kick off the continued discussion (as I’m attempting to do here).
Originally sent in chat feedback
dodesz
Hello, Is there any plan to bring back the (chat messages move to or convert to regular posts) feature for staff? We've run a support (quick Q&A) channel and our members really miss the mark as solution feature and there are so many good conversations in chat what we want to move to a regular topic so that it can be even more meaningful conversations and to get more attention but I think quoting is not the best option for this purpose. Sorry if I missed the answer about this. Thanks :slightly_smiling_face:
mcwumbly
@Don short answer is no, but maybe some other things we are planning to working on will help here? Not sure. I feel like I need to unpack this more with you to better understand the kind of behavior you're currently observing and why quote to topic doesn't feel right.
dodesz
Hi Dave, thanks for the answer. The reason I feel quote is not enough for this purpose: It won't keep the original author, I mean if I quote someone than the post will be mine rather then the original author's. If someone reply, like, etc… to it I will get the notification not the original author. The other thing if I quote more (lot) chat messages it will create a huge long OP (transcript). To reply a specific quoted message users only can with quote it again. Otherwise nobody knows which user's message replied. Quote is really good for example if I would like to create a new topic and I can use some chat messages to reference things. But If I just want to move or convert the conversation to a regular topic this is not the best I think because of these things. But maybe I have to thinking little different about it and there is a workaround or I just have to handle separate the chat and regular topics, posts. :slightly_smiling_face:
mcwumbly
The workaround I recommend is to think of chat transcripts as "context" for the new topic, but not the topic itself. Whoever creates the topic can/should summarize things in your own words. That could be you (as mod), or the user who started the chat discussion (possibly after a nudge from you).
I'll use this discussion as an opportunity to demonstrate what I'm talking about.
Quoting could probably be improved so if you quote part of a chat transcript in a topic, it attributes it to the original author (as we do for quoted posts).
Thanks Dave! I think I get it now… this is a kind of like Reply as linked topic feature. I think my use case is totally reachable with improving quotes. I have some ideas how would be improved it or make it more dynamic.
Chat quotes and the original chat messages could be synchronized each other and may contains some action buttons such as (reply, share or quick quote and maybe reactions) and users can interact more easily with the quoted chat messages and…
Something like :arrow_down_small:
I don’t know the difficulty level to make it synchronizable but probably not the easiest one. However synchronization is only use for reactions in this case :thinking: I think it can be omitted. So chat quotes only contains a share and reply button. Share is copy the original chat message link and reply is open composer with auto quote the quoted chat message or connect somehow to the quoted chat message. Just ideas… :slightly_smiling_face:
By the way, xenforo has another great feature - to respond to any post in a personal message. This solves the problem of creating side discussions in the topic
I think showing what reactions a quoted chat message has inline is worth considering…
And I can see the value in linking directly to each message somewhere, even if it’s not a “share” button. Interestingly, the first message’s timestamp is a link, but subsequent messages are not – they should probably all be links to aid in discoverability of that feature, at the very least…
I can see it being potentially useful to have a reply button, but I think the place for me to start still is to make quoting work the way it does for posts:
Just to illustrate what I mean by this further, below you can see the difference between how we currently handle quoting text that originally came from a quoted chat message vs. another quoted post.
quote-attribution
That’d be a significant improvement.
Is it also possible to notify users whose chat messages were quoted in a topic, just as is done when you @mention someone? In this case, for example, mcwumbly and dodesz should receive a notification.
Hi! I did try to search in the forum for an answer but did not find anything.
Is it possible somehow to move messages from a chat to create a new topic? Except making a long quote with all of the messages in the first message of the new topic.
I am encountering a situation where my users sometimes start really great discussion tread in a chat room which would work great as a topic in our forum. The problem is that in a chat these discussions will die off after a day or two and they will not get indexed by search engines. I’m really missing a feature to promote great discussions into a new topic.
If you are asking can you create a full topic with comments without showing quotes, then you can’t. Or you can, with a quite much manual labour, editing and changing ownerships.
I’m not talking only of creation of a new topic with chat messages as comments. Ideally I would remove chat massages from the chat room and move everything into a topic. Problem with quoting is that users can continue discussion within the chat like nothing has happened.
Seems like right now we can wait for the discussion to die down and archive it in a topic using quoting. :person_shrugging:
Well if it is something a moderator can’t do from a web interface it is as good as impossible.
I don’t know how other community managers feel, but I find that chats are great for naturally generating great topics. Especially if your user base do not like to create topics but loves to chat and comment.
It would be a dream to have seamless chat and forum integration. Back in the day we used a really long topics for chatting purposes, but sadly it was not good enough compared to something like Discord. Either way I’m happy to see that Discourse is incorporating chatting it the engine and I’m hopeful that some day it could become seamless chat and forum hybrid.
I don’t see any solution where you can stop that.
I move selected messages to a topic. Then I will delete those messages from channel (and that is a bit pain in the tender places because we can’t do it by bulk without lame tricks). And the last piece is telling what I did and giving link to that topic at that channel, with a humble request continuing discussion there.
It is just editing a topic, so?
Meaning what in practise?
Oh, did you meant something like this?
  • You create a post and paste one quote from a chat
  • You change posts owner to the user who did make original quote
Even if moderators can do it, it sounds like hell.
I did enable Discourse chat only yesterday so I’m not up to speed with the current limitations. Right now I see that there is clear separation between chat messages and posts - chat channels and topics. When we want to create a new conversation right now we need to make a choice either it will be a chat channel or topic. We can’t change this choice or go back afterwards.
To call chat and forum integration seamless I would like to just create a topic and decide afterwards should this be a chat room or should it stay as a topic. Ability to convert topic into chat channels and vice versa.
Don’t get me wrong Discourse chat is still better than using a completely separate chat platform with some sort of login gateway or even worse without it.
Hell is a bit ovetstatement. I would like to describe it like purgatory, 7th level :rofl:
Yeah. Cleaning off all chattiness signs hasn’t balanced benefit/work ratio.
I’m guessing depedency between categories and channels may disapper at some point, but I would guess too that just a bit easier moving of messages to topics would achieve (almost) same goal.
But… this direction is more off topic here and should go to Contribute > Feature.
I asked the same and it’s not possible.
It seems to be that chat are used only for trivial things and we was thinking to use the whole forum (with chat system) for great ones.
I suspect this will be revised sooner or later :slightly_smiling_face:
We do this constantly on the CDCK private instance. And that’s how we do it, as you described above.
For us it works; we summarize the discussion so far, and bring up why we’d like to take it to long form to discuss further.
Short form vs. long form discussions have a different expectation and flow to them, so it does take a bit of effort to curate the discussion and transition to a different communication mode.
It’s an act of preservation of sorts.
Why do you feel quoting into a post is insufficient? I feel it acknowledges and respects the original mode of discussion in which it took place.
I don’t know how Daniel sees it, but linking to channel and showing quotes works as an ad for chats at the quotation time. After some time, like a month or year later it just doesn’t matter any more, but makes reading a bit harder.
Please, don’t take this too seriously, but I did one small test. I know quite good how my active members act and react, so I trust on this (well… not trust-trust, but I don’t know english enough and I’m missing a word I want to use; a positive gut feeling)
If I do an ordinary copying from chat to topic (a starter or comment, no matter) that discussion is over. If I spend time and split those quotations to single comments plus I change ownerships to right persons, that discussion will continue.
So, there must be somekind mental block and lack of… personal touch/feel when users see longer quote instead of ordinary topic.
How to solve that? I don’t know. I love my free time more than needed work of manually editing topics :wink: and creating such automation would be too expensive for CDCK and defenetly too expensive for me. Because after all — that is kind of another edge case.
So basically you’ve proven there is a need for a Chat Messages to be converted to Posts on occasion ?
Perhaps a bulk select feature and a “convert to Topic” command that does all that work for you?
And perhaps the same with “Move to Topic” to allow you to append converted Messages as Posts on the end of existing Topics?
(Going to be cheeky and move this to Contribute > Feature )
You know I’d love to move some valuable complex personal chats to PMs!
Yes. But I’m not totally sure if it would be a critical need — for me anyway. But we (in the meaning I :wink: ) defenetly need ability to delete (copied messages) in bulk.
I would guess it depends. If a forum
  • uses mostly topics and chat is… minor one, then moving messages as a real topic is important, because majority of discussion happends on topic-level
  • has adopted chat really hard then copying as mass quote is enough, because it serves only searching and archieving
Given the need to feed the SEO monster I think this would be a great feature.
One major reluctance for me in activating chat is losing that valuable search exposure.
I think it was also raised by @Don in this Contribute > Feature topic Moving conversations from chat to topics
