It looks like this is the same known issue that causes problems with templates.
everyone-group-unable-to-see-private-templates
In this case, the ai-bot options appear, but the bot simply never responds.
Thanks for searching for prior issues!
I think the same applies here:
You can not give anonymous users access to the chat bot, so using trust_level_0 is an effective solution for your use case. ![]()
@Roman reading through the code in Discourse I think this works now.
Is it time to close this off and remove the backwards compat code?
Het is een beetje lastig. Ik heb oorspronkelijk de everyone-optie toegevoegd omdat we anonieme gebruikers gists wilden laten zien. Elke functie heeft zijn eigen regels, dus ik denk niet dat het instellen van de toegestane groepen van een Persona daarop de functie voor iedereen beschikbaar zal maken.
This is still an issue. If âAI bot allowed groupsâ is set to everyone, the bot does not respond.
I think the bug is here
return false if (SiteSetting.ai_bot_allowed_groups_map & post.user.group_ids).blank?
If the setting is everyone then this returns false, since 0 is not in post.user.group_ids
The correct pattern is !user.in_any_groups?(SiteSetting.ai_bot_allowed_groups_map)
which has a special case for everyone:
def in_any_groups?(group_ids)
group_ids.include?(Group::AUTO_GROUPS[:everyone]) ||
(is_system_user? && (Group.auto_groups_between(:admins, :trust_level_4) & group_ids).any?) ||
(group_ids & belonging_to_group_ids).any?
Does it make sense to disallow âeveryoneâ to be selected for that setting? Similar to how it was done in DEV: restrict everyone on whisper groups via a new disallowed_groups attr by renato · Pull Request #37515 · discourse/discourse · GitHub
Yeah we got to remove it⊠@martin has on his list to clean a lot of this up, but it may take a bit.
@martin should we close this one? just patch current?
Small PR here to do it, along with fixing this bug:
