Bootstrap Error
Hi. I’m receiving this error after attempting to start Discourse:
docker: failed to create the container ID file: open cids/app_bootstrap.cid: no such file or directory
I’ve already done my research on the top and cannot find the problem.
Full Logs:
root@vmware:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
2.0.20240708-0023: Pulling from discourse/base
Digest: sha256:025e9c1f6848c4726544c6ae873d710c62f547b72afb7f537aaa44eb5377cb5c
Status: Image is up to date for discourse/base:2.0.20240708-0023
docker.io/discourse/base:2.0.20240708-0023
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
docker: failed to create the container ID file: open cids/app_bootstrap.cid: no such file or directory.
See 'docker run --help'.
cat: cids/app_bootstrap.cid: No such file or directory
bootstrap failed with exit code 127
Container name cannot be empty
Strange. Does docker work?
docker run hello-world
Yes. It appears that Docker is running normally and works.
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
 1. The Docker client contacted the Docker daemon.
 2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
    (amd64)
 3. The Docker daemon created a new container from that image which runs the
    executable that produces the output you are currently reading.
 4. The Docker daemon streamed that output to the Docker client, which sent it
    to your terminal.
I’ve seemed to fix this issue. I must have been using a outdated version of Docker!
