how can I change discourse timeline to a certain country?
Hi @yekta , welcome to the Meta!
Could you elaborate further on the problem you are facing?
Thanks!
hey there
I wanna change the dates, calender and time to my own country…
could you help me?
Hi there, you should be able to change your timezone by going to discourse.example.com/my/preferences/profile, scrolling down to Timezone and changing it from there.
Hope this helps!
You can edit translations too. In Finland Discourse’s way was a bit… foreign
so I changed those for fi-locale. Yeah I know, I should consider changing en, se etc, but because my forum is finnish only I didn’t bother.
