How do I make json_schema translatable?
Continuing the discussion from Make the settings descriptions of all official theme components translatable
I’m currently trying to make the settings of Category Groups translatable.
However, I’m having trouble finding the correct syntax to display the descriptions from locales/en.yml in the JSON editor. I’ve found Objects type for theme setting, which explains the syntax for the objects type setting. Is there something similar for the JSON schema?
I also tried to find an example, but even the descriptions in the calendar plugin aren’t translatable at the moment.
I did check, but I don’t think it’s possible unless I missed something. :thinking:
The json_schema will be deprecated in favor of the objects type.
I believe the official plugins and components will be converted at some point.
If I can, I will help as well!
