Category Groups
:discourse2: Summary Category Groups allows you to assign categories to groups, which are then used to sort and collapse categories on the categories page.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-category-groups-component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
:information_source: Important things to note:
  • This theme component only works with the site setting desktop category page style set to boxes with subcategories (as it replaces that category page template).
  • The category collapsing works using your browser’s local storage, so the collapsed state will not be remembered between different devices.
Settings
Name Description
category groups This is how the groups are configured. Format as: Group name: category-slug, extra-link-id, category-slug-2 (The category slug is the name of the category as it’s seen in URLs. Usually all lowercase with no spaces)
extra links Extra links that can be mixed into category list. Add link ID in category_groups setting to render
show on mobile Show the collapsible category box groups on mobile
show ungrouped Display a group of categories that aren’t assigned to another group
fancy styling Turn on additional styling (These are some custom styles added. They stray from our defaults, so if you’re working on your own theme you may want to disable this)
hide muted subcategories When enabled, a non-muted parent category will not appear under the muted section if it has a muted subcategory
Theme Translations Default
ungrouped_categories_title Other
:discourse2: Hosted by us? Theme components are available to use on our Pro, Business and Enterprise plans.
I’ve just merged a refactor of this component. Functionality should remain the same overall, with some bug fixes.
Behind the scenes this uses some modernized Ember, and eliminates template overrides, which can be a little fragile as far as Discourse customizations go.
This should be fixed now
This is fixed now, the groups will no longer apply to the subcategory layouts
I’ve updated this, so category logos should be much more normally sized now
Is it possible to not show subcategories for a particular category? We have a category that’s organized in a particular way with nested subcategories and it’s causing the box to be quite large.
Maybe try the Category Hider in Theme component
Can you tell me if it’s possible to apply the category groupings to the sidebar? If not, I would like to put this in as a feature request. Thanks!
There is a problem on my website, subcategories hasn’t space between them.
Thanks for reporting it, an update should fix it now (fixed in UX: include gap for subcategories by awesomerobot Ā· Pull Request #19 Ā· discourse/discourse-category-groups-component Ā· GitHub).
It’s not possible, the sidebar would need a bigger change in Discourse to allow for this (request noted!)
Will be awesome if this grouping will be customizable by user, some people in our community wanted that.
Yeah, this needs a plugin, but a good idea I think
Any idea why the category width is so skinny? Is there a way to fix this?
is this in the Mint theme? I’ve just made a minor update that should fix it — there was a slight conflict between the CSS of that theme and this component
Yeah it was the mint, thank you
How do I prevent the boxes being outlined with the category colour? I’ve tried forking it, adding css, and also changing the <li style in the categories-groups.hbs
(Note that I am a dabbler, not a trained developer)
You can add a little CSS to your theme to remove the colorful borders:
.category-boxes .category-box {
  border-left: 2px solid var(--primary-low) !important;
or if you have the ā€œfancy stylingā€ setting turned on:
.custom-categories-groups .category-box {
    border: 2px solid var(--primary-low) !important;
Thanks Kris,
It appears I’m having a bigger problem. For some reason, whenever I try to update the Theme component, it doesn’t pick up the changes at all. So my css was good, it just wasn’t being loaded. Not something for this thread, I’ll have a search around to see if there is something dumb I’m doing
Would it be possible to have the fancy styling boxes with a latest section below the categories? In essence I want to do that same thing that the ā€œModern Categories + Group Boxesā€ component does in the Air Theme. You can select Categories with Latest for the desktop view and latest displays below the categories.
Im trying to edit my own version of the CSS but im no expert. Would this be an easy thing to do or might it be out of my skill set?
I have this use case, where we have many categories, and sub-categories that are enabled, and they make the landing page very crowded, hard to find what interests the user.
Because of this, we want to customize the Category Groups landing page in a way that it is more targeted for the users in specific interest areas (via the user-groups).
So, I propose adding a visibility option for each category group. If any defined, the category group would be made visible only to those user-groups enabled in its settings.
I so created a pull-request to demonstrate what I mean by all this. Please let me know what you think of this option. Would you use it? Does it apply to your Discourse site?
p.s. This proposed new option should not be considered as alternative access-control. It simply controls what category groups will be visible for the logged-in user based on their group memberships. The existing permissions will still be in affect.
Seems to not be showing after the latest Discourse updates, might need a update for this TC to work
I wonder why not enabling this style on mobile with default categories option?
They look wonderful with the component!
