Thanks for the intuitive UX in data explorer
I wrote a report nearly a year ago that I need to make some changes to. I did some commenting (and sane naming) at the time, but I still need to step through it and recreate my thinking.
Wondering where a subquery was re-used, I double-clicked the name, with a tiny hope that the UI would help me out. I was perfectly ready to be disappointed, but you came through for me, by highlighting the usage:
Thank you! :star_struck:
Also, with the AI plugin you can use an SQL helper that will write queries for you. Forget the syntax for a variable that can be filled in when they run the query? It’lll probably remember for you.
Edit: and now you can use Ask.discourse.com
