Data Explorer feature: SQL query to Admin Dashboard Widget
We already can build queries in the admin panel right from the Data Explorer plugin.
The idea is a simple checkbox addition: “Show in admin panel”, one per query.
If checked, query results are shown as a widget in the Admin Dashboard.
1개의 좋아요
Yup, we’ve talked this idea through and it is on the roadmap but won’t be in the first iteration of the dashboard redesign, which will launch with v2.0
5개의 좋아요
If not, or in addition to, widgets; I think having simple sparklines for some over-time data would be nice.
그 이후로 이 아이디어가 고려된 적이 있나요?
2개의 좋아요
그렇습니다. @markvanlan이 이 프로젝트를 오디션용으로 만들었습니다. Make data explorer available to moderators
4개의 좋아요
