Проблемы с разрешениями при обновлении контейнера данных
I recently rebuilt a data container that was 2 years old. The new container expected different permissions than the old one did, presumably because the postgres user and group had new IDs in the current base OS.
I fixed it by running this inside the container:
 chown -R postgres:postgres /shared/postgres_*
Maybe in a single-container setup this isn’t necessary because a chown gets done in some other template?
The next rebuild failed because the discourse user was not allowed to enable the pgvector extension. I resolved this by running this query in postgres as the postgres user:
 ALTER USER discourse WITH SUPERUSER;
6 лайков
I think I saw a commit that likely fixed this, but I can’t find it now.
1 лайк
I’m not 100% sure what were the user and group IDs 2 years ago but going forward this will not change and will be fixed.
3 лайка
I just had to do this again. I think what needs to happen is that
Needs to be:
        chown postgres:postgres /shared/postgres_*
It doesn’t really matter if you chown postgres:postgres inside the container, right?
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
