With the latest build the rebuild fails on my site, the only way to get it to rebuild succesfully is by removing the AI plugin, any ideas?
Error
Caused by:
PG::InsufficientPrivilege: ERROR: must be owner of extension vector (PG::InsufficientPrivilege)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/postgres/connection.rb:217:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `block in run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `block in with_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `with_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `run'
/var/www/discourse/lib/mini_sql_multisite_connection.rb:109:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/postgres/connection.rb:196:in `exec'
/var/www/discourse/plugins/discourse-ai/db/migrate/20240611170904_upgrade_pgvector_070.rb:10:in `up'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:989:in `public_send'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:989:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:970:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:969:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:227:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:968:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1178:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1529:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1580:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1528:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1503:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1503:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1448:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1600:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1448:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1274:in `up'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1249:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/tasks/database_tasks.rb:251:in `migrate'
/var/www/discourse/lib/tasks/db.rake:259:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:234:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
Tasks: TOP => db:migrate
I, [2024-09-26T02:33:15.511637 #1] INFO -- : gem install tokenizers -v 0.4.4 -i /var/www/discourse/plugins/discourse-ai/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed tokenizers-0.4.4-x86_64-linux
1 gem installed
gem install tiktoken_ruby -v 0.0.9 -i /var/www/discourse/plugins/discourse-ai/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed tiktoken_ruby-0.0.9-x86_64-linux
1 gem installed
gem install multipart-post -v 2.4.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed multipart-post-2.4.0
1 gem installed
gem install faraday-multipart -v 1.0.4 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed faraday-multipart-1.0.4
1 gem installed
gem install event_stream_parser -v 1.0.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed event_stream_parser-1.0.0
1 gem installed
gem install ruby-openai -v 7.0.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-openai-7.0.0
1 gem installed
gem install google_search_results -v 2.2.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed google_search_results-2.2.0
1 gem installed
gem install wikipedia-client -v 1.17.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed wikipedia-client-1.17.0
1 gem installed
gem install childprocess -v 5.0.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed childprocess-5.0.0
1 gem installed
gem install liquid -v 5.5.0 -i /var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed liquid-5.5.0
1 gem installed
gem install discourse_subscription_client -v 0.1.2 -i /var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed discourse_subscription_client-0.1.2
1 gem installed
gem install discourse_plugin_statistics -v 0.1.0.pre7 -i /var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed discourse_plugin_statistics-0.1.0.pre7
1 gem installed
gem install geocoder -v 1.8.2 -i /var/www/discourse/plugins/discourse-locations/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed geocoder-1.8.2
1 gem installed
gem install aws-sdk-translate -v 1.35.0 -i /var/www/discourse/plugins/discourse-translator/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed aws-sdk-translate-1.35.0
1 gem installed
== 20240611170904 UpgradePgvector070: migrating ===============================
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1936 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
981f5a5797fa920052c5f2e33e4a36d4e515a053d5e922ca91882d0712379d3b
x86_64 arch detected.
881912b282ea
Nothing to do, your container has already started!
