Error de actualización [ChatBot]
Hi. Trying to upgrade self-hosted Discourse. The procedure executed from /admin gave the following error:
== 20231026010114 CreatePgVectorChatbotPostEmbeddingsIndex: migrating =========
-- execute("      CREATE INDEX pgv_hnsw_index_on_chatbot_post_embeddings ON chatbot_post_embeddings USING hnsw (embedding vector_l2_ops)\n      WITH (m = 32, ef_construction = 64);\n")
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:209:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:108:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/commands/runner/runner_command.rb:43:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.0/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.0/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.0/lib/thor.rb:527:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/command/base.rb:87:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/command.rb:48:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/commands.rb:18:in `<main>'
<internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:38:in `require'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.17.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require'
bin/rails:18:in `<main>'
Spinning up 7 Unicorn worker(s) that were stopped initially
After that, any HTTP request  HTTP Error 500.
I've tried to rebuild Discourse application. Got the following error:
2023-11-14 07:42:30.147 UTC [2301] discourse@discourse ERROR:  unrecognized parameter "ef_construction"
2023-11-14 07:42:30.147 UTC [2301] discourse@discourse STATEMENT:        CREATE INDEX pgv_hnsw_index_on_chatbot_post_embeddings ON chatbot_post_embeddings USING hnsw (embedding vector_l2_ops)
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled: (StandardError)
PG::InvalidParameterValue: ERROR:  unrecognized parameter "ef_construction"
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.1.1/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.1.1/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:48:in `block (2 levels) in execute'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/dependencies/interlock.rb:41:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:47:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract_adapter.rb:752:in `block in log'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract_adapter.rb:743:in `log'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:46:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:932:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:900:in `block in say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:900:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:921:in `method_missing'
/var/www/discourse/plugins/discourse-chatbot/db/migrate/20231026010114_create_pg_vector_chatbot_post_embeddings_index.rb:5:in `up'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:873:in `public_send'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:873:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:854:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:853:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/connection_pool.rb:215:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:852:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1046:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1360:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/database_statements.rb:316:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/transactions.rb:209:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1411:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1359:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1333:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1333:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1282:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1432:in `block in with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1447:in `with_advisory_lock_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1428:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1282:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1117:in `up'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1092:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/tasks/database_tasks.rb:262:in `migrate'
/var/www/discourse/lib/tasks/db.rake:255:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:230:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/exe/rake:27:in `<top (required)>'
Caused by:
ActiveRecord::StatementInvalid: PG::InvalidParameterValue: ERROR:  unrecognized parameter "ef_construction" (ActiveRecord::StatementInvalid)
Caused by:
PG::InvalidParameterValue: ERROR:  unrecognized parameter "ef_construction" (PG::InvalidParameterValue)
Tasks: TOP => db:migrate
I, [2023-11-14T07:42:30.249857 #1]  INFO -- : gem install multipart-post -v 2.3.0 -i /var/www/discourse/plugins/discourse-ai-topic-summary/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed multipart-post-2.3.0
1 gem installed
gem install faraday-multipart -v 1.0.4 -i /var/www/discourse/plugins/discourse-ai-topic-summary/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed faraday-multipart-1.0.4
1 gem installed
gem install ruby-openai -v 5.1.0 -i /var/www/discourse/plugins/discourse-ai-topic-summary/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-openai-5.1.0
1 gem installed
gem install tokenizers -v 0.3.3 -i /var/www/discourse/plugins/discourse-ai/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed tokenizers-0.3.3-x86_64-linux
1 gem installed
gem install tiktoken_ruby -v 0.0.5 -i /var/www/discourse/plugins/discourse-ai/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed tiktoken_ruby-0.0.5-x86_64-linux
1 gem installed
gem install aws-eventstream -v 1.2.0 -i /var/www/discourse/plugins/discourse-ai/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed aws-eventstream-1.2.0
1 gem installed
gem install iso8601 -v 0.13.0 -i /var/www/discourse/plugins/discourse-automation/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed iso8601-0.13.0
1 gem installed
gem install rrule -v 0.4.4 -i /var/www/discourse/plugins/discourse-automation/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed rrule-0.4.4
1 gem installed
gem install multipart-post -v 2.3.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
1 gem installed
gem install faraday-multipart -v 1.0.4 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
1 gem installed
gem install ruby-openai -v 5.1.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
1 gem installed
gem install google_search_results -v 2.2.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed google_search_results-2.2.0
1 gem installed
gem install wikipedia-client -v 1.17.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed wikipedia-client-1.17.0
1 gem installed
gem install childprocess -v 4.1.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed childprocess-4.1.0
1 gem installed
gem install safe_ruby -v 1.0.4 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed safe_ruby-1.0.4
1 gem installed
gem install stripe -v 5.29.0 -i /var/www/discourse/plugins/discourse-subscriptions/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed stripe-5.29.0
1 gem installed
== 20231011152903 EnsureNotificationsConsistency: migrating ===================
== 20231011152903 EnsureNotificationsConsistency: migrated (62.2778s) =========
I, [2023-11-14T07:42:30.251425 #1]  INFO -- : Terminating async processes
I, [2023-11-14T07:42:30.251569 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
2023-11-14 07:42:30.251 UTC [42] LOG:  received fast shutdown request
I, [2023-11-14T07:42:30.251788 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 111
111:signal-handler (1699947750) Received SIGTERM scheduling shutdown...
2023-11-14 07:42:30.253 UTC [42] LOG:  aborting any active transactions
2023-11-14 07:42:30.256 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2023-11-14 07:42:30.294 UTC [46] LOG:  shutting down
111:M 14 Nov 2023 07:42:30.299 # User requested shutdown...
111:M 14 Nov 2023 07:42:30.299 * Saving the final RDB snapshot before exiting.
2023-11-14 07:42:30.385 UTC [42] LOG:  database system is shut down
111:M 14 Nov 2023 07:42:30.655 * DB saved on disk
111:M 14 Nov 2023 07:42:30.655 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 2210 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
c472b75fb1460239c00a387e5800279dfbbe7bf7300f6c3efa03635586ca7f1b
Am i understanding correctly, that the problem is in discourse-chatbot plugin?
¿Intentaste reconstruir desde la línea de comandos? (Si no, por favor hazlo)
Hubo un cambio importante hace unos días
https://meta.discourse.org/t/discourse-chatbot-now-smarter-than-chatgpt/256652/600?u=moin
Chicos, si sospechan de un plugin específico, lean su Tema del plugin, nunca se sabe qué información podrían descubrir :thinking: :wink:
(gracias @Moin )
Esto se resolvió: solo se trataba de reconstruir con un solo comando en after_code:
    - exec:
        cd: $home
        cmd:
          - su postgres -c 'psql discourse -c "ALTER EXTENSION vector UPDATE;"'
(y luego eliminar esto después de la compilación exitosa).
