If you give certain members access to AI, what is stopping them from using it all the time for their work etc., is there any way to limit how many tokens they can use per day or week etc?
There isn’t such limitations when used Discourse AI, so the answer is plain nothing.
The other solution, Chatbot, has weekly limits how many request can be made.
So, you have to choose which one suits better for you. I use both. Chatbot for more general use inside my forum [1] and DAI is limited based by a group and (tuned) purposes using personas. So, I kind of exploit the best sides of both, because those two are only partly overlapping.
general means type of questions, otherwise it is tuned more specialized way ↩︎
Moving this to feature, we intend to add a quota system, it keeps popping up
I am thinking of just adding a group selectors with input/output counts and duration on each llm , so you can add optional quotas
