Replacing goo.gl links
goo.gl is shutting down (see Google URL Shortener links will no longer be available - Google Developers Blog). So links on your forum that include goo.gl links will be broken after August 25th, 2025.
I developed this script for a client. It took much, much longer than I billed him for and longer than I care to admit.
It finds all of the posts that contain goo.gl and then (if they aren’t maps.app.goo.gl or maps.goo.gl) attempts to replace them with the URL that goo.gl returns. It uses the post revisor, so you can see that it was updated and why and you can revert it if you want. I have tried to make it as failsafe as possible, but use at your own risk.
If you don’t know how to run this script, you probably should not do it yourself. If you need help making it work and have a budget, contact me or ask in Marketplace.
If you use it and have suggestions for how to make it better, you please reply and/or edit it as you see fit.
URL_CACHE ||= {}
def resolve_url_simple(short_url)
  uri = URI.parse(short_url)
  response = Net::HTTP.get_response(uri)
  if response.is_a?(Net::HTTPRedirection)
    response['location']
  else
    short_url # Return original if no redirection
rescue
  short_url # Return original if there was an error
def resolve_url(short_url)
  short_url.gsub!(/http:/,"https:")
  # Check if the URL is already in the cache
  return URL_CACHE[short_url] if URL_CACHE.key?(short_url)
  begin
    uri = URI.parse(short_url + "?si=1")
    # Resolve the URL if it's a redirection
    resolved_url = if response.is_a?(Net::HTTPRedirection)
                   else
    sleep 1
    # Store the resolved URL in the cache
    URL_CACHE[short_url] = resolved_url
    resolved_url
  rescue
    # Store the original URL in the cache in case of an error
    URL_CACHE[short_url] = short_url
    short_url
def replace_goo_gl_links(text)
  goo_gl_regex = %r{(?<=^|[\[\]\(\)\s])(https?://)?goo\.gl(/[a-zA-Z0-9]+)+}
  text.gsub(goo_gl_regex) do |match|
    if match.include?('maps.app.goo.gl')
      match
    else
      full_url = match.start_with?('http') ? match : "https://#{match}"
      print "FIXING!!: #{match} -----> "
      fixed = resolve_url(full_url)
      puts fixed
      fixed
def replace_all_goo_gl_links
  system_user= User.find(-1)
  goo_go = Post.where("raw LIKE '%goo.gl%'")
  total_posts = goo_go.count
  puts "Found #{total_posts} posts to check"
  count = 0
  goo_go.find_each do |post|
    count += 1
    # puts "Processing #{count}. #{Discourse.base_url}/t/#{post.topic_id}/#{post.post_number}"
    print "."
    # for reasons unclear, trying to update posts in these topics crashed rails
    # next if [145478,64885,84408].include? post.topic_id
    # find goo.gl links and the the URL to see what it redirects to
    new_raw = replace_goo_gl_links(post.raw)
    if new_raw != post.raw
      revision_options = {
        edit_reason: "Fix goo.gl links",
        bypass_bump: true
      begin
        puts "Revising (#{count}/#{total_posts}) #{Discourse.base_url}/t/#{post.topic_id}/#{post.post_number}"
        if !post.topic # posts in delted topics have no topic and break PostRevisor
           post.topic = Topic.with_deleted.find_by(id: post.topic_id)
           next if !post.topic
        PostRevisor.new(post).revise!(system_user, raw: new_raw, **revision_options)
      rescue => e
        puts "cannot revise (number: #{count} #{Discourse.base_url}/t/#{post.topic_id}/#{post.post_number}): #{e}"
      sleep 15
Why exclude those? These links won’t break?
And thanks for this script. I returned posts that contain these shortened links on my forums, and there are a bunch that will need to be fixed then. :+1:
Here’s what Google Maps is generating today: https://maps.app.goo.gl/Qz14oUZQv9aHCCfg6. I decided to guess that those domains they have decided to keep. :person_shrugging:
I’m also seeing https://goo.gl/maps and https://goo.gl/photos/ and expect those too will not be affected.
I don’t know. If they work now without a warning then I’d say you’re right.
I’m pretty sure that the script tries to replace those.
The page linked in the OP says:
Note that goo.gl links generated via Google apps (such as Maps sharing) will continue to function.
so presumably, yes, they will continue to work. Especially if no interstitials show up.
Do you have specific ones you can post? Possibly https://goo.gl/maps/ID can be replaced with https://maps.app.goo.gl/ID, though it doesn’t work in the other direction.
Regardless, there’s probably no harm in replacing them?
Hard to say. Probably?
I’m trying not to spend another 5 hours on this 2 hour job, but here are a couple
https://goo.gl/maps/bFFQr8eL4F62
https://goo.gl/maps/BPCy1us5GkJQ2zMX8 becomes
https://www.google.com/maps/place/SUZUKI%E9%91%AB%E6%BD%A4%E8%BB%8A%E6%A5%AD-%E9%B4%BB%E5%AF%B6%E5%8F%B0%E5%8C%97%E6%97%97%E8%89%A6%E5%BA%97/@25.0488943,121.5803302,16.17z/data=!4m5!3m4!1s0x3442ab9666e0cf09:0x7be03675872f9c63!8m2!3d25.051748!4d121.5809526?shorturl=1
So it’s probably safe to modify
to something like
    if match.include?('maps.app.goo.gl') || match.include?('goo.gl/maps')
And maybe also add the pictures one.
And I also just learned that you also need to rebake posts that onebox the replaced URLs.
I think a proper rake task with some specs is probably in order, but I’ve already got at least 3X the hours in this job that I billed for it.
I was only wondering if these were equivalent:
https://maps.app.goo.gl/bFFQr8eL4F62
but this is not the case.
All signs point to the former continuing to work anyways :+1:
Here’s one
https://goo.gl/photos/NBtTJoYjhrMqRdso9
A quick test suggests google no longer creates short links like these, using the subdomains instead.
So it’s probably not bad that the script un-shortens them.
I saw the bypass_bump: true and ran this thinking that it would not fill up my “Latest” view with hundreds of edits. But It is definitely filling up the “Latest” view. Happy to pay that price to fight link rot, but thought I’d give a heads-up to the next person.
It does turn out that “Reset bump date” takes them back out of the “Latest” view.
