I’m experiencing an issue with my Discourse site after mistakenly adding an invalid GitHub repository to the app.yml
file. When I ran ./launcher rebuild app
, the process failed, and now the site won’t rebuild. Unfortunately, I have backups but they fail during the restore process. Below are the details of the issue, including the entire error log.
Steps Taken:
- I attempted to add DeepSeek LLM to my Discourse installation following the guidance from this post.
- I added the repository URL
https://github.com/deepseek-ai/DeepSeek-LLM
to theapp.yml
file. - Ran
, which failed and caused the site to become non-functional.
Full Error Log:
plaintext
CopyEdit
I, [2025-01-21T02:32:16.599723 #1] INFO -- : gem install multipart-post -v 2.4.0 -i /var/www/discourse/plugins/discourse-ai-topic-summary/gems/3.3.6 --no-document --ignore-dependencies --no-user-install
Successfully installed multipart-post-2.4.0
1 gem installed
gem install faraday-multipart -v 1.0.4 -i /var/www/discourse/plugins/discourse-ai-topic-summary/gems/3.3.6 --no-document --ignore-dependencies --no-user-install
Successfully installed faraday-multipart-1.0.4
1 gem installed
gem install event_stream_parser -v 1.0.0 -i /var/www/discourse/plugins/discourse-ai-topic-summary/gems/3.3.6 --no-document --ignore-dependencies --no-user-install
Successfully installed event_stream_parser-1.0.0
1 gem installed
gem install ruby-openai -v 7.0.0 -i /var/www/discourse/plugins/discourse-ai-topic-summary/gems/3.3.6 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-openai-7.0.0
1 gem installed
gem install tokenizers -v 0.4.4 -i /var/www/discourse/plugins/discourse-ai/gems/3.3.6 --no-document --ignore-dependencies --no-user-install
Successfully installed tokenizers-0.4.4-x86_64-linux
1 gem installed
gem install tiktoken_ruby -v 0.0.9 -i /var/www/discourse/plugins/discourse-ai/gems/3.3.6 --no-document --ignore-dependencies --no-user-install
Successfully installed tiktoken_ruby-0.0.9-x86_64-linux
1 gem installed
gem install ed25519 -v 1.2.4 -i /var/www/discourse/plugins/discourse-ai/gems/3.3.6 --no-document --ignore-dependencies --no-user-install
Building native extensions. This could take a while...
Successfully installed ed25519-1.2.4
1 gem installed
... (more gem installation logs) ...
I, [2025-01-21T02:32:16.600035 #1] INFO -- : Terminating async processes
I, [2025-01-21T02:32:16.600051 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 39
I, [2025-01-21T02:32:16.600103 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 107
2025-01-21 02:32:16.600 UTC [39] LOG: received fast shutdown request
107:signal-handler (1737426736) Received SIGTERM scheduling shutdown...
2025-01-21 02:32:16.602 UTC [39] LOG: aborting any active transactions
2025-01-21 02:32:16.604 UTC [39] LOG: background worker "logical replication launcher" (PID 54) exited with exit code 1
2025-01-21 02:32:16.605 UTC [49] LOG: shutting down
107:M 21 Jan 2025 02:32:16.612 # User requested shutdown...
107:M 21 Jan 2025 02:32:16.612 * Saving the final RDB snapshot before exiting.
2025-01-21 02:32:16.634 UTC [39] LOG: database system is shut down
107:M 21 Jan 2025 02:32:16.667 * DB saved on disk
107:M 21 Jan 2025 02:32:16.667 # Redis is now ready to exit, bye bye...
> FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 837 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
Challenges:
- I cannot restore the site from a backup.
- Rebuilding fails consistently, leaving the site inoperable.
Request for Help:
- How can I approach these issues, running the rebuild app must have created an erroneous plugin or similar?
- Are there any manual recovery steps?
- Any suggestions for safely rebuilding the site from this state?
I signed up for a hosted Discourse instance and uploaded a backup but the restore option does not appear even though the file uploaded normally.
I greatly appreciate any advice or guidance on how to proceed. Please let me know if further details are needed!
