Aiuto con il fallimento del ricostruzione di Discourse
Sto riscontrando un problema quando provo a ricompilare Discourse, ma non capisco qual è il problema. Qualcuno può aiutarmi?
Ecco l’output di ./launcher rebuild app:
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20241203-0251: Pulling from discourse/base
Digest: sha256:d5d4e6d361d56745e37f2609db58a6970cc9b3fcd26d0b2dcba23d0cb581f067
Status: Image is up to date for discourse/base:2.0.20241203-0251
docker.io/discourse/base:2.0.20241203-0251
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-12-17T20:04:51.340338 #1]  INFO -- : Reading from stdin
I, [2024-12-17T20:04:51.372817 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-12-17T20:04:51.380788 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-12-17T20:04:51.389047 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-12-17T20:04:51.398337 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2024-12-17T20:04:51.405124 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-12-17T20:04:51.406966 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-17T20:04:51.408283 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-17T20:04:51.409225 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-17T20:04:51.410158 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-17T20:04:51.410961 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-17T20:04:51.411604 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-17T20:04:51.412229 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-17T20:04:51.412891 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-17T20:04:51.413731 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-17T20:04:51.419815 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-12-17T20:04:51.420380 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-12-17T20:04:51.421094 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-12-17T20:04:51.421838 #1]  INFO -- : > if [ -f /root/install_postgres ]; then
  /root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
  socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
I, [2024-12-17T20:04:55.815863 #1]  INFO -- : Generating locales (this might take a while)...
  en_US.UTF-8... done
Generation complete.
I, [2024-12-17T20:04:55.816523 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-12-17T20:04:55.825934 #1]  INFO -- : File > /usr/local/bin/create_db  chmod: +x  chown:
I, [2024-12-17T20:04:55.834243 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-12-17T20:04:55.839156 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-12-17T20:04:55.839678 #1]  INFO -- : > sleep 5
2024-12-17 20:04:55.944 UTC [39] LOG:  starting PostgreSQL 13.18 (Debian 13.18-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
2024-12-17 20:04:55.945 UTC [39] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-12-17 20:04:55.945 UTC [39] LOG:  listening on IPv6 address "::", port 5432
2024-12-17 20:04:55.949 UTC [39] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-12-17 20:04:55.957 UTC [48] LOG:  database system was shut down at 2024-12-17 20:04:41 UTC
2024-12-17 20:04:55.969 UTC [39] LOG:  database system is ready to accept connections
I, [2024-12-17T20:05:00.843375 #1]  INFO -- :
I, [2024-12-17T20:05:00.843591 #1]  INFO -- : > /usr/local/bin/create_db
2024-12-17 20:05:01.014 UTC [58] postgres@postgres ERROR:  database "discourse" already exists
2024-12-17 20:05:01.014 UTC [58] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
2024-12-17 20:05:01.127 UTC [61] postgres@discourse ERROR:  role "discourse" already exists
2024-12-17 20:05:01.127 UTC [61] postgres@discourse STATEMENT:  create user discourse;
NOTICE:  extension "hstore" already exists, skipping
NOTICE:  extension "pg_trgm" already exists, skipping
NOTICE:  extension "vector" already exists, skipping
NOTICE:  version "0.8.0" of extension "vector" is already installed
I, [2024-12-17T20:05:02.768875 #1]  INFO -- : GRANT
ALTER SCHEMA
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
UPDATE 0
I, [2024-12-17T20:05:02.769783 #1]  INFO -- : > echo postgres installed!
I, [2024-12-17T20:05:02.772946 #1]  INFO -- : postgres installed!
I, [2024-12-17T20:05:02.780721 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-12-17T20:05:02.789261 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-12-17T20:05:02.797355 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-12-17T20:05:02.799315 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-12-17T20:05:02.801831 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-12-17T20:05:02.806036 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-12-17T20:05:02.817751 #1]  INFO -- :
I, [2024-12-17T20:05:02.819014 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-12-17T20:05:02.821066 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-12-17T20:05:02.823374 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-12-17T20:05:02.825686 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-12-17T20:05:02.827711 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-12-17T20:05:02.829965 #1]  INFO -- : > echo redis installed
I, [2024-12-17T20:05:02.833303 #1]  INFO -- : redis installed
I, [2024-12-17T20:05:02.833999 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-12-17T20:05:02.847791 #1]  INFO -- : logfile ""
I, [2024-12-17T20:05:02.848582 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-12-17T20:05:02.860731 #1]  INFO -- : > sleep 10
107:C 17 Dec 2024 20:05:02.909 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
107:C 17 Dec 2024 20:05:02.910 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=107, just started
107:C 17 Dec 2024 20:05:02.910 # Configuration loaded
107:M 17 Dec 2024 20:05:02.912 * monotonic clock: POSIX clock_gettime
107:M 17 Dec 2024 20:05:02.922 * Running mode=standalone, port=6379.
107:M 17 Dec 2024 20:05:02.922 # Server initialized
107:M 17 Dec 2024 20:05:02.923 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
107:M 17 Dec 2024 20:05:02.923 * Loading RDB produced by version 7.0.7
107:M 17 Dec 2024 20:05:02.923 * RDB age 23 seconds
107:M 17 Dec 2024 20:05:02.923 * RDB memory usage when created 46.73 Mb
107:M 17 Dec 2024 20:05:03.124 * Done loading RDB, keys loaded: 4401, keys expired: 3.
107:M 17 Dec 2024 20:05:03.124 * DB loaded from disk: 0.201 seconds
107:M 17 Dec 2024 20:05:03.124 * Ready to accept connections
I, [2024-12-17T20:05:12.882155 #1]  INFO -- :
I, [2024-12-17T20:05:12.882393 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-12-17T20:05:12.887354 #1]  INFO -- : thpoff is installed!
I, [2024-12-17T20:05:12.888009 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-12-17T20:05:13.019333 #1]  INFO -- :
I, [2024-12-17T20:05:13.019487 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-12-17T20:05:13.154482 #1]  INFO -- :
I, [2024-12-17T20:05:13.154685 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-12-17T20:05:13.293364 #1]  INFO -- :
I, [2024-12-17T20:05:13.293637 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-12-17T20:05:13.296993 #1]  INFO -- :
I, [2024-12-17T20:05:13.305524 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-12-17T20:05:13.313003 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-12-17T20:05:13.319105 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-12-17T20:05:13.324930 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-12-17T20:05:13.330478 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-12-17T20:05:13.335821 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-12-17T20:05:13.336043 #1]  INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
  rm /root/install_postgres
fi
sv start postgres || exit 1
 in /etc/service/unicorn/run
I, [2024-12-17T20:05:13.339445 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
Updating files: 100% (34959/34959), done.
I, [2024-12-17T20:05:18.887993 #1]  INFO -- : HEAD is now at 251333995 FEATURE: Show when a badge has been granted for a post (#29696)
I, [2024-12-17T20:05:18.888111 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-12-17T20:05:19.062676 #1]  INFO -- :
I, [2024-12-17T20:05:19.062865 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/0-a-extra-item-classes
 - [deleted]             (none)     -> origin/abstract_autocomplete_textarea
 - [deleted]             (none)     -> origin/add-plugin-wrapper-to-user-profile-avatar
 - [deleted]             (none)     -> origin/better-conflict-handling
 - [deleted]             (none)     -> origin/custom-flag-default-translation
 - [deleted]             (none)     -> origin/dependabot/bundler/sass-embedded-1.81.0
 - [deleted]             (none)     -> origin/dependabot/bundler/webrick-1.9.1
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/sass-1.81.0
 - [deleted]             (none)     -> origin/dev/ember-5-12
 - [deleted]             (none)     -> origin/feature/backup-cli-sql-only-option
 - [deleted]             (none)     -> origin/feature/block-ip-and-email-to-bulk-delete
 - [deleted]             (none)     -> origin/fix-undefined-controller
 - [deleted]             (none)     -> origin/fix/hide-profiles
 - [deleted]             (none)     -> origin/mobile-firefox-keyboard-fix
 - [deleted]             (none)     -> origin/relax-emoji-sanitization
 - [deleted]             (none)     -> origin/separate_upload_placeholder
 - [deleted]             (none)     -> origin/update-robots-desc
   251333995..8f26ae7b7  main                    -> origin/main
 * [new branch]          0-a-presence            -> origin/0-a-presence
 * [new branch]          add-devenv              -> origin/add-devenv
 + 8741e0f07...04bf23c03 br/directory            -> origin/br/directory  (forced update)
   07c91ff5b..1a3925b17  composer_toolbar_improv -> origin/composer_toolbar_improv
 * [new branch]          dependabot/bundler/mocha-2.7.1 -> origin/dependabot/bundler/mocha-2.7.1
 * [new branch]          dependabot/bundler/nokogiri-1.17.2 -> origin/dependabot/bundler/nokogiri-1.17.2
 * [new branch]          dependabot/bundler/sass-embedded-1.83.0 -> origin/dependabot/bundler/sass-embedded-1.83.0
 * [new branch]          dependabot/npm_and_yarn/jsuites-5.8.1 -> origin/dependabot/npm_and_yarn/jsuites-5.8.1
 * [new branch]          dependabot/npm_and_yarn/sass-1.83.0 -> origin/dependabot/npm_and_yarn/sass-1.83.0
 * [new branch]          dev-no-text-on-yields   -> origin/dev-no-text-on-yields
 * [new branch]          dev-refactor-can-check-emails-mixin -> origin/dev-refactor-can-check-emails-mixin
 * [new branch]          dev-update-svg-icon-subset-site-setting-help-text -> origin/dev-update-svg-icon-subset-site-setting-help-text
 + d5f594c07...cb2c55972 dev/admin-api-ui-guidelines -> origin/dev/admin-api-ui-guidelines  (forced update)
 * [new branch]          dev/admin-page-header-to-d-page-header -> origin/dev/admin-page-header-to-d-page-header
 * [new branch]          dev/admin-webhooks-ui-guidelines -> origin/dev/admin-webhooks-ui-guidelines
 * [new branch]          dev/settable-fields     -> origin/dev/settable-fields
 * [new branch]          embedding-ux            -> origin/embedding-ux
 + 2921205f2...52a38f358 feature/wizard-look-and-feel-improvements -> origin/feature/wizard-look-and-feel-improvements  (forced update)
 * [new branch]          fitzy/org-runners       -> origin/fitzy/org-runners
 * [new branch]          fix-chat                -> origin/fix-chat
 * [new branch]          fix-firefox-android-followup -> origin/fix-firefox-android-followup
 * [new branch]          fix-is-replying-when-offline -> origin/fix-is-replying-when-offline
 * [new branch]          fix-open-composer-error -> origin/fix-open-composer-error
 * [new branch]          fix/admin-permission-precedent-deleted-posts -> origin/fix/admin-permission-precedent-deleted-posts
 * [new branch]          fix/contact-url-about-page -> origin/fix/contact-url-about-page
 * [new branch]          i18n/banned-lint        -> origin/i18n/banned-lint
 * [new branch]          introduce_api_for_custom_rate_limiters -> origin/introduce_api_for_custom_rate_limiters
 * [new branch]          issue/allow-admin-to-use-reserved-usernames -> origin/issue/allow-admin-to-use-reserved-usernames
 + 50c0a90ba...56e8c5245 less_invasive_autocomplete -> origin/less_invasive_autocomplete  (forced update)
 * [new branch]          login-css               -> origin/login-css
 + 8834e37c4...d502d7c37 loic-enable-rspec-rule  -> origin/loic-enable-rspec-rule  (forced update)
 * [new branch]          loic-fix-services-delegate-with-class -> origin/loic-fix-services-delegate-with-class
 * [new branch]          mt/fix-poll-options     -> origin/mt/fix-poll-options
 + 1fc526eb4...9e46da1b7 mt/idb                  -> origin/mt/idb  (forced update)
 + 72f3215c0...eaded6223 mt/pr4                  -> origin/mt/pr4  (forced update)
 * [new branch]          multiple-drafts-dropdown -> origin/multiple-drafts-dropdown
 * [new branch]          permalink-settings      -> origin/permalink-settings
 * [new branch]          post-dup-event          -> origin/post-dup-event
 * [new branch]          post-list-component     -> origin/post-list-component
 * [new branch]          redo_sidekiq_heartbeat_checks -> origin/redo_sidekiq_heartbeat_checks
 * [new branch]          refactor-mobile-coposer-position -> origin/refactor-mobile-coposer-position
 * [new branch]          refactor-mobile-coposer-position-replace-actions -> origin/refactor-mobile-coposer-position-replace-actions
 * [new branch]          renato/pm               -> origin/renato/pm
 * [new branch]          signup-progress-edits   -> origin/signup-progress-edits
 * [new branch]          skip_compressing_assets_if_assets_is_already_on_s3 -> origin/skip_compressing_assets_if_assets_is_already_on_s3
   f5b108bf9..85a89e0e2  stable                  -> origin/stable
   251333995..8f26ae7b7  tests-passed            -> origin/tests-passed
 * [new branch]          topic-tracking-dmenu    -> origin/topic-tracking-dmenu
 * [new branch]          translations-from-crowdin-main -> origin/translations-from-crowdin-main
 * [new branch]          translations-from-crowdin-stable -> origin/translations-from-crowdin-stable
 * [new branch]          user-fields-plugin-outlets-update -> origin/user-fields-plugin-outlets-update
 * [new branch]          ux-create-tag-disabled  -> origin/ux-create-tag-disabled
 * [new branch]          vite                    -> origin/vite
 * [new branch]          wip-merged-topics       -> origin/wip-merged-topics
I, [2024-12-17T20:05:20.291566 #1]  INFO -- :
I, [2024-12-17T20:05:20.291729 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-12-17T20:05:25.030222 #1]  INFO -- : branch 'tests-passed' set up to track 'origin/tests-passed'.
I, [2024-12-17T20:05:25.030366 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-12-17T20:05:25.046403 #1]  INFO -- :
I, [2024-12-17T20:05:25.046548 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-12-17T20:05:25.055946 #1]  INFO -- :
I, [2024-12-17T20:05:25.056125 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-12-17T20:05:25.060509 #1]  INFO -- :
I, [2024-12-17T20:05:25.061466 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-12-17T20:05:25.067552 #1]  INFO -- :
I, [2024-12-17T20:05:25.067718 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-12-17T20:05:25.072718 #1]  INFO -- :
I, [2024-12-17T20:05:25.072873 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-12-17T20:05:25.133562 #1]  INFO -- :
I, [2024-12-17T20:05:25.133770 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-12-17T20:05:25.138158 #1]  INFO -- :
I, [2024-12-17T20:05:25.138341 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-12-17T20:05:25.144893 #1]  INFO -- :
I, [2024-12-17T20:05:25.145206 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-12-17T20:05:25.151921 #1]  INFO -- :
I, [2024-12-17T20:05:25.152276 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-12-17T20:05:25.159070 #1]  INFO -- :
I, [2024-12-17T20:05:25.159375 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-12-17T20:05:25.166058 #1]  INFO -- :
I, [2024-12-17T20:05:25.166378 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-12-17T20:05:25.172678 #1]  INFO -- :
I, [2024-12-17T20:05:25.172991 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-12-17T20:05:25.179373 #1]  INFO -- :
I, [2024-12-17T20:05:25.179636 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-12-17T20:05:25.417134 #1]  INFO -- :
I, [2024-12-17T20:05:25.417766 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-12-17T20:05:25.420544 #1]  INFO -- :
I, [2024-12-17T20:05:25.420997 #1]  INFO -- : Replacing # redis with if [ ! -d /shared/redis_data ]; then
fi
sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-12-17T20:05:25.422694 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-12-17T20:05:26.648646 #1]  INFO -- :
I, [2024-12-17T20:05:26.648966 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-data-explorer.git
Cloning into 'discourse-data-explorer'...
I, [2024-12-17T20:05:27.422032 #1]  INFO -- :
I, [2024-12-17T20:05:27.422303 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/timmmmyboy/docker-embed.git
Cloning into 'docker-embed'...
I, [2024-12-17T20:05:27.932386 #1]  INFO -- :
I, [2024-12-17T20:05:27.932658 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-chat-integration.git
Cloning into 'discourse-chat-integration'...
I, [2024-12-17T20:05:28.771301 #1]  INFO -- :
I, [2024-12-17T20:05:28.771587 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/cpradio/discourse-plugin-replygif.git
Cloning into 'discourse-plugin-replygif'...
I, [2024-12-17T20:05:29.886073 #1]  INFO -- :
I, [2024-12-17T20:05:29.886354 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-voting.git
Cloning into 'discourse-voting'...
I, [2024-12-17T20:05:30.594338 #1]  INFO -- :
I, [2024-12-17T20:05:30.594656 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
Cloning into 'discourse-solved'...
I, [2024-12-17T20:05:31.375552 #1]  INFO -- :
I, [2024-12-17T20:05:31.375879 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-bcc.git
Cloning into 'discourse-bcc'...
I, [2024-12-17T20:05:31.961928 #1]  INFO -- :
I, [2024-12-17T20:05:31.962216 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/DiscoTOC.git
Cloning into 'DiscoTOC'...
I, [2024-12-17T20:05:32.664375 #1]  INFO -- :
I, [2024-12-17T20:05:32.664727 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-whos-online.git
Cloning into 'discourse-whos-online'...
I, [2024-12-17T20:05:33.335177 #1]  INFO -- :
I, [2024-12-17T20:05:33.335457 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-fontawesome-pro.git
Cloning into 'discourse-fontawesome-pro'...
I, [2024-12-17T20:05:33.976652 #1]  INFO -- :
I, [2024-12-17T20:05:33.976989 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-chat.git
Cloning into 'discourse-chat'...
I, [2024-12-17T20:05:35.152614 #1]  INFO -- :
I, [2024-12-17T20:05:35.152879 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/paviliondev/discourse-custom-wizard.git
Cloning into 'discourse-custom-wizard'...
I, [2024-12-17T20:05:36.348298 #1]  INFO -- :
I, [2024-12-17T20:05:36.348576 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/paviliondev/discourse-news.git
Cloning into 'discourse-news'...
I, [2024-12-17T20:05:36.903186 #1]  INFO -- :
I, [2024-12-17T20:05:36.903544 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-post-voting.git
Cloning into 'discourse-post-voting'...
I, [2024-12-17T20:05:37.671933 #1]  INFO -- :
I, [2024-12-17T20:05:37.672243 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-reactions
Cloning into 'discourse-reactions'...
I, [2024-12-17T20:05:38.435059 #1]  INFO -- :
I, [2024-12-17T20:05:38.435384 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-shared-edits
Cloning into 'discourse-shared-edits'...
I, [2024-12-17T20:05:39.134862 #1]  INFO -- :
I, [2024-12-17T20:05:39.135193 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-doc-categories
Cloning into 'discourse-doc-categories'...
I, [2024-12-17T20:05:39.845892 #1]  INFO -- :
I, [2024-12-17T20:05:39.846259 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/29th/discourse-user-by-id
Cloning into 'discourse-user-by-id'...
I, [2024-12-17T20:05:40.396893 #1]  INFO -- :
I, [2024-12-17T20:05:40.397186 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-reactions
fatal: destination path 'discourse-reactions' already exists and is not an empty directory.
I, [2024-12-17T20:05:40.402942 #1]  INFO -- :
I, [2024-12-17T20:05:40.403829 #1]  INFO -- : Terminating async processes
I, [2024-12-17T20:05:40.403968 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 39
I, [2024-12-17T20:05:40.404084 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 107
2024-12-17 20:05:40.404 UTC [39] LOG:  received fast shutdown request
107:signal-handler (1734465940) Received SIGTERM scheduling shutdown...
2024-12-17 20:05:40.406 UTC [39] LOG:  aborting any active transactions
2024-12-17 20:05:40.410 UTC [39] LOG:  background worker "logical replication launcher" (PID 54) exited with exit code 1
2024-12-17 20:05:40.426 UTC [49] LOG:  shutting down
107:M 17 Dec 2024 20:05:40.427 # User requested shutdown...
107:M 17 Dec 2024 20:05:40.427 * Saving the final RDB snapshot before exiting.
2024-12-17 20:05:40.476 UTC [39] LOG:  database system is shut down
107:M 17 Dec 2024 20:05:40.657 * DB saved on disk
107:M 17 Dec 2024 20:05:40.657 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-reactions failed with return #<Process::Status: pid 441 exit 128>
exec failed with the params {"cd"=>"$home/plugins", "cmd"=>["git clone https://github.com/discourse/docker_manager.git", "git clone https://github.com/discourse/discourse-data-explorer.git", "git clone https://github.com/timmmmyboy/docker-embed.git", "git clone https://github.com/discourse/discourse-chat-integration.git", "git clone https://github.com/cpradio/discourse-plugin-replygif.git", "git clone https://github.com/discourse/discourse-voting.git", "git clone https://github.com/discourse/discourse-solved.git", "git clone https://github.com/discourse/discourse-bcc.git", "git clone https://github.com/discourse/DiscoTOC.git", "git clone https://github.com/discourse/discourse-whos-online.git", "git clone https://github.com/discourse/discourse-fontawesome-pro.git", "git clone https://github.com/discourse/discourse-chat.git", "git clone https://github.com/paviliondev/discourse-custom-wizard.git", "git clone https://github.com/paviliondev/discourse-news.git", "git clone https://github.com/discourse/discourse-post-voting.git", "git clone https://github.com/discourse/discourse-reactions", "git clone https://github.com/discourse/discourse-shared-edits", "git clone https://github.com/discourse/discourse-doc-categories", "git clone https://github.com/29th/discourse-user-by-id", "git clone https://github.com/discourse/discourse-reactions"]}
bootstrap failed with exit code 128
8583d802d54ae22f3b827ec739724277851f99186b4e6caf1fcf2951f9b6744f
Sembra che ci sia qualcosa che non va in un plugin. Ti suggerirei di modificare (con cautela) il tuo file yml (probabilmente app.yml) per rimuovere quel plugin. Fai prima una copia di backup del file. (Dovresti sempre fare un backup pulito di tutto, incluso il file yml, prima di ricostruire.)
Avevo accidentalmente incluso il plugin Reactions due volte in app.yml. La rimozione di una delle righe ha risolto il problema.
Grazie per il rapido aiuto!
