Theme Developer Tutorial: 7. Wrapping up
This tutorial has been a whistle-stop tour through the process of creating a Discourse theme and experimenting with a few of the most common APIs. Of course, there’s plenty more to learn, so let’s map out some more places for you to explore.
Existing themes & theme component
One of the best resources when learning about theme development is to read through the code of existing themes. Check out the directories in #theme and #theme-component, or jump straight to our all-the-themes meta-repository for even more example code!
Sharing your themes
Once you have a theme or theme component you’re happy with, and it’s published on GitHub, it’s time to share it! Make a new topic in #theme or #theme-component and we’ll review/publish it.
How to ask for help
If you’re stuck on something that relates to themes, feel free to create a post in the Development category. Be sure to include as much information as you can and anything you’ve tried. The more effort you put into your question, the more likely you’ll get an answer. If you can include code snippets, or link out to a repository on GitHub, that would be great!
Other resources
This document is version controlled - suggest changes on github.
2 „Gefällt mir“
